Old Aug 05, 2012, 05:03 PM
Rockytop448 is offline
Find More Posts by Rockytop448
Rockytop448's Avatar
Joined Oct 2009
Got the FBL100 yesterday. I'm a little confused about the battery position. My mcp has the battery inserted from rear to front. The book with the FBL shows it being inserted from the front. That means every I change batteries I have to take the canopy off. Am I right?
Rockytop448 is offline Find More Posts by Rockytop448
Old Aug 05, 2012, 05:04 PM
stonerscolony is offline
Find More Posts by stonerscolony
stonerscolony's Avatar
The Netherlands, NH, Enkhuizen
Joined Jul 2007
no your wrong its exactly the same as the mcp
stonerscolony is offline Find More Posts by stonerscolony
Old Aug 05, 2012, 05:05 PM
Joined Jul 2007
and to be clear why that's the way it is, the book also says to put on throttle hold before connecting lipo then fails to show or say in text which way is on/off
Old Aug 05, 2012, 05:29 PM
Joined Oct 2009
So making sure I understand...I should insert the battery from rear to front. The reason I ask is that the Hisky pics show it in place with the connector towards the front of the aircraft. Of all the helis I own, none of the little ones do this.
Old Aug 05, 2012, 05:39 PM
Joined Jul 2007
the HiSky... hmm mine is Turnigy but the config after some searching looks to be the same, however on ours there's a wire to connect to lipo where as yours doesn't.
http://www.rcgroups.com/forums/showthread.php?t=1589305
There's a picture on that thread shows on your model I'm wrong, yes it goes in from the front.. odd.
Old Aug 05, 2012, 05:49 PM
Joined Oct 2009
Mine is Turnigy as well from the SOB's @ HK. The big difference I see is that my BAT wires are soldered on the back side of the 3n1 board. Gonna try to fly it as you say. If the CG is effected I'll know fast enough. The thread on helifreak says that these tow are the same heli's. It also says that 90% of the parts are interchangeable with the MPX. I appreciate your input stonerscolony.
Old Aug 05, 2012, 05:55 PM
Joined Jul 2007
Check the photos above, I directly compared parts with the mcp and most are. The canopy holes for mounting are 3MM wider on mcp to FBL100 and tail rotor + motor are different, almost everything else is identical.
Old Aug 06, 2012, 09:24 PM
airbagit13 is offline
Find More Posts by airbagit13
Plane Destroyer / Life Enjoyer
airbagit13's Avatar
Miami, FL
Joined May 2009
Definitely not the same heli the FBL100 is much much more powerful.
airbagit13 is offline Find More Posts by airbagit13
Old Aug 07, 2012, 12:00 AM
papernkero is offline
Find More Posts by papernkero
papernkero's Avatar
Sydney, Australia
Joined Jul 2008
The battery slides in from the back on my FBL-100. - the same as the MCPX. The batteries are interchangeable with the MCPX
Also my FBL-100 has a more solid head with larger ball joints than the one on the MCPX that my flying buddy has so you couldn't interchange individual parts within the head (such as the linkages) although you could probably swap the entire head assembly with that of the MCPX if you needed to. The FBL-100 head looks much stronger.
papernkero is offline Find More Posts by papernkero
Old Aug 07, 2012, 12:03 AM
Joined Jul 2007
I agree papernkero the head is much stronger as is the tail rotor. However it's worth mentioning the FBL100 lipos have 100mAh more standard than the mcpx standards 300mAh vs 200mAh.
My friend seen my packs and is now ordering his own lol.
Old Aug 07, 2012, 04:21 AM
asanado is offline
Find More Posts by asanado
Israel
Joined Jan 2011
Parts are now available at HobbyKing...
asanado is offline Find More Posts by asanado
Old Aug 07, 2012, 07:39 AM
freezywilly is offline
Find More Posts by freezywilly
Joined Jan 2012
I also got a FBL100. Manual is quetionable and the transmitter likewise.
As an off the wall idea how about swaping the board for the mcpx board?
Would like to use a programmable transmitter.
What say all?
freezywilly is offline Find More Posts by freezywilly
Old Aug 07, 2012, 01:52 PM
Joined Jul 2007
I wrote a review comparison you can find here:
http://www.fatedev.com/Forum?Do=Topi...CPX+comparison
Old Aug 07, 2012, 02:30 PM
Joined Jan 2012
@stonerscolony Points well taken. Still wonder if a programmable tx might
be somewhere in the pipeline. The word for the day is change and if you look at the various threads on FBL heli's the next month or two are going to be interesting.
Old Aug 08, 2012, 12:35 PM
zadaw is online now
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
There is a programmable transmitter available that comes with a more expensive package.
http://www.hobbycool.com/hisky-fbl-1...ery-p-507.html
There will also soon be transmitter modules available.
I suppose you could try using the MCPx board. However, it is not clear whether the board can provide enough current to the motor which is reported to be 50% more powedrful than the MCPx motor.
zadaw is online now Find More Posts by zadaw
Wanted Want Mini CP / Genius CP / m CP X v2 for trade / cash GrandpappyToke Aircraft - Electric - Helis (FS/W) 2 Jul 07, 2012 07:18 PM
New Product HiSky FBL100 erdnuckel2 Micro Helis 3 May 08, 2012 10:06 AM
Discussion IP, HK, Spektrum and here come the clones angelfood Electric Plane Talk 15 Sep 08, 2010 11:44 PM
Discussion post blade Cp- Blade CP Pro pix here leliommarino Micro Helis 0 Jan 22, 2008 01:33 PM
Anthony from WORLD_HOBBY (HK) Seller here.... world_hobby Vendor Talk 119 Jan 07, 2006 12:30 PM
