Old Jul 11, 2012, 03:56 AM
talkthetorque is offline
Find More Posts by talkthetorque
Joined Nov 2007
Question
Help with elogger V3 and GPS expander V3
Hi
I have an eLogger V3 and a GPS Expander V3 that I bought in 2009. I have upgraded the software yesterday to 10.04 as I could not get what I was trying to achieve to work.
I bought this equipment for some FPV flying at that time but I now want to use it to record my flight path of my aerobatic flights and look at them in 3D on Google Earth as a training aid.
Is this possible? After I download the data from the eLogger onto the data recorder software I have tried to "Save for Google Earth..." and also tried to "Save for Google Earth track...". Both give me unwanted results
When trying "Save for Google Earth..." it seems to just draw a semi dotted line around the equator on Google Earth
When trying "Save for Google Earth track..." it gives me a flat path on the ground and does not show any elevation. My other problem with this option is its also not accurate and jumps to areas way off where I have gone. I'm not sure if this is because some of the flight is inverted and the GPS expander is now also inverted. A friend of mine is doing this in his patternship with his hitec radio and GPS module and not having any problems even though his GPS is stuck to the undercarriage inside the plane. My GPS is sitting in the cockpit area and can be seen though the canopy.
I'm not much of a electrics guru so if someone can please help me.
Thank you for any help
talkthetorque is offline Find More Posts by talkthetorque
Old Jul 14, 2012, 11:38 AM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hi, I think that if you upgrade to our latest "beta" software from here, the issue will be solved. Google Earth made some changes that requires our new software.
billpa is offline Find More Posts by billpa
Site Sponsor
Old Jul 15, 2012, 03:23 PM
Joined Nov 2007
Thank you very much this seems to have helped and I now have elevation in Google Earth. I'm still having a problem as discussed with the accuracy and jumping around. Is this because the GPS is going upside down at times? Is there a solution to this problem?
Thanks again for your help
Old Jul 18, 2012, 02:11 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi, would you be able to post a screenshot of the jumping around? I'd need to see that (or get a .FDR file) to determine what the cause might be.
Site Sponsor
Old Jul 21, 2012, 04:11 PM
Joined Nov 2007
Hi Bill.
The first image is the track and the 2nd image is a 3D image. The tags on the 1st image are showing points where I didnt go and there are many of those points I did not tag. The lowest tag is actually behind me and I definitively didnt go there. This is a e-flite brio I used for the test so I didnt fly far. I started by taking off and then doing some basic aerobatics, loops, square loops, triangle loops, stall turns etc. But when I follow the flight path it doesnt look similar to the order of my flight. Maybe I'm doing this wrong, should I redo a flight after I update the sofware or can I use an existing flight recorded? Is there any electronics I should keep the elogger and GPS away from? I had it mounted on top of my 3s 2200mah lipo. Not much space in the mini Brio. Thanks
http://www.rcgroups.com/forums/showa...=5026272&stc=1
http://www.rcgroups.com/forums/showa...=5026273&stc=1
Old Jul 23, 2012, 02:29 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi, and thanks for posting the images. Most likely, based on the data, the issue is with the sensitivity of the GPS V3. The GPS V4 (shipping for a couple of years now) is based on a newer generation chipset, which has improved sensitivity, and additional noise filtering.
But, another factor could be the position of the satellites when you flew, assuming you only flew once. GPS satellites move around a lot, so I'd try another flight before considering a hardware change.
Site Sponsor
Old Jul 28, 2012, 09:26 AM
Joined Nov 2007
Thanks Bill
I will run some more tests first
I appreciate all your help
regards
Sold Eagle tree osd pro elogger v3 gps expander v3 Squatter Aircraft - General - Miscellaneous (FS/W) 2 Nov 27, 2009 09:12 PM
Sold Eagle tree osd pro elogger v3 gps expander v3 Squatter Aircraft - General - Miscellaneous (FS/W) 14 Nov 27, 2009 08:58 PM
Question Memory expander or realtime GPS data compression for the eLogger V3? nexus665 Eagle Tree Systems 16 Oct 05, 2009 07:45 AM
Sold EagleTree 5Hz GPS Expander Module for eLogger V3! $100 shipped! edge5foamy Aircraft - General - Miscellaneous (FS/W) 2 Jan 13, 2009 08:44 AM
Discussion Problems with 5Hz GPS Expander V3 and eLogger V3! Geni Eagle Tree Systems 7 Aug 14, 2008 12:08 AM
