Old Oct 02, 2012, 07:59 AM
limodune is online now
Find More Posts by limodune
limodune's Avatar
Australia, QLD, Toowoomba
Joined Oct 2011
The model comes double boxed and in a foam container with pockets for parts, no damage what so ever HK to Aus, some nice upgrades with a removable hatch to get to the EDF units, the pylons are plastic and extend into the inside of the narcells and fan out to form a top canopy--nice and strong, the speed controllers go into pocket's in the belly of the wings so they will have plenty of airflow
The wings look to have two carbon rods inside, one full length at the forward edge and another farther back in the middle, they joint together with 2 short rods, the struts are all alloy with suspension very nice, it all pushed/fitted together well, the detail is very good, wings are painted light grey with a darker gray for corogard and the leading edges are silver, nercelles also have a silver leading edge and on the rear, on a side note the wings are thick enough to add retracts to though pads would have to be added for a base
Only minor thing the top hatch sits a little high at one end ( I know I am picky) but can be easy trimmed to lower it flush, the instruction sheet has full instruction's and lots of pictures, it's very well done
Mr Ming IT IS A WONDERFUL MODEL
limodune is online now Find More Posts by limodune
Old Oct 02, 2012, 10:38 AM
Ming is offline
Find More Posts by Ming
Ming's Avatar
Hong Kong
Joined Jun 2002
A kind remind please don't use the T-plus for battery plus,
The amp to drawing is over 50 may melt the T-plug.
Ming Lou
Ming is offline Find More Posts by Ming
Site Sponsor
Old Oct 03, 2012, 01:08 PM
rob737 is offline
Find More Posts by rob737
United States, CT, Guilford
Joined Nov 2008
wow, it looks great! mine should arrive in a few days.
what exactly is the "t-plus?"
thanks.........rob
rob737 is offline Find More Posts by rob737
Old Oct 03, 2012, 01:14 PM
Smokin_Joes is offline
Find More Posts by Smokin_Joes
What tree??.......Doh!!
Smokin_Joes's Avatar
USA, WA, Seattle
Joined Aug 2007
Mike!
Are the main wings thick enough to install servoless retract?
Thanks for the unboxing and pics! Very helpful!
Neil
Smokin_Joes is offline Find More Posts by Smokin_Joes
Old Oct 03, 2012, 05:22 PM
limodune's Avatar
Joined Oct 2011
Hi Joe
Yes thick enough though foam mounting pad's would have to be added to make the struts sit 90* to the ground, I have done this mod recently to my A320 it's not hard, it's on my to do list also full lighting and larger wheels for grass, I have just put my order in with Callie for decals, I can't wait to get it all together
Old Oct 06, 2012, 11:04 PM
rob737 is offline
Joined Nov 2008
mine arrived today. wow! it's a beauty. should be able to get it built this weekend (and post some pictures).
Old Oct 08, 2012, 03:31 AM
Ming is offline
Ming's Avatar
Hong Kong
Joined Jun 2002
Kind remain the CG should be 5mm after the wing middle panel line.
Ming Lou
Site Sponsor
Old Oct 09, 2012, 02:35 PM
Wing Jockey is offline
Find More Posts by Wing Jockey
Joined Oct 2012
Hi!
There have to be a German or Swiss distributor! It would be much easier for me to buy one. In the vids above it looks really fast. How does it react in slow flight?
Cheers Konrad
Wing Jockey is offline Find More Posts by Wing Jockey
Old Oct 09, 2012, 02:58 PM
Ming is offline
Ming's Avatar
Hong Kong
Joined Jun 2002
Please just place your order on my website, the shipping we change is very cheap.
I can ship tomorrow if you place order within next 10 hours.
Ming Lou
Site Sponsor
Old Oct 10, 2012, 12:48 AM
Hawaiian Flyin is offline
Find More Posts by Hawaiian Flyin
Hawaiian Flyin's Avatar
United States, HI
Joined Dec 2007
Wing Jockey. Just order direct from Ming. Shipping is very reasonable. I have ordered several planes from him. Ming's service is top notch.
I just got my 777 delivered today. Took just over a week to get here. Thanks Ming. Now just need to find time to put it together. Still working on my number 3 737!
Hawaiian Flyin is offline Find More Posts by Hawaiian Flyin
Old Oct 10, 2012, 11:59 AM
Joined Oct 2012
Ming Lou
There's one problem which can't be solved: my age .In 4 long months I will turn 18. I can't do nothing at the moment. It's just to annoying for me. I don't like to let my parents sign every small thing.
I will order then.
Few reasons to wait:
Here in Switzerland the winter's on the way. Heavy rainfalls and gusty winds, no flying possible the next months!
When I turn 18, one of the first things i will do is to get Paypal and a creditcard.
Back to topic : do you produce the T7 as long as the 737? I hope you don't do a limited edition as it was announced with the concorde!
When not I will order one in spring!
Greets Konrad
Old Oct 14, 2012, 06:31 PM
rob737 is offline
Joined Nov 2008
here's a picture of my finished fuselage. should have the rest of the model completed later in the week (a friend is changing out the esc connectors to deans for me).
Old Oct 14, 2012, 07:35 PM
United States, HI
Joined Dec 2007
Just started to work on mine today. Some sanding & painting. Going to try for a FedEX look. Everything seems to fit good so shouldn't be too hard to put together. Will post pics shortly
Rob. Is that a 1600mm Skyraider in the background?
Old Oct 14, 2012, 08:19 PM
rob737 is offline
Joined Nov 2008
no, actually it's the 1100mm durafly skyraider from hobbyking. it's loaded with rotating retracts, lights, and flaps. flys like a dream and is a favorite in the fleet! good luck on the fedex livery. i went for the air france to get a scale look with out painting. hope you post pictures!
rob
Old Oct 14, 2012, 09:35 PM
United States, HI
Joined Dec 2007
I have the 1600mm Raider. Retracts failed after the second flight. Got a new set from PWC-RC. They work better except that one side has a tendency to rotate 90 degrees as soon as I touch down. Tightened the set screw but did it again on the next landing too. I'll figure it out later. Mine flies good too. Never tried the air brakes yet though. Too chicken!
Ran into one snag on the 777 today. When I plugged in the servo on the right elevator the servo arm is not centered. Tried to pull the servo out but it's glued in good. Don't think I can pull it out without breaking something. Thinking of cutting a little away so I can get to the screw and move the arm over a notch. Then some minor body work.
Build Log Boeing 777 200LR foam and tape RC Airliners (Commercial, Cargo, Troop Carrier) 317 Jan 27, 2013 06:01 PM
Wanted Wtb: Windrider boeing 737 hi2nr Aircraft - Electric - Jets (FS/W) 0 Jun 08, 2012 01:36 PM
Discussion Boeing 777-200LR Twin 90mm project NickM91 Scratchbuilt EDFs 20 Jul 10, 2011 09:40 AM
Boeing 777-200/300 Sections Guybo Fuel Jet Talk 3 Jun 15, 2002 08:04 PM
boeing 777 nacelle jermaine Electric Ducted Fan Jet Talk 1 May 20, 2002 02:24 AM
