Old Dec 28, 2012, 08:47 PM
Landin' On The Canopy BAD
F-86FLIER4LIFE's Avatar
Lee's Summit, MO
Originally Posted by bamaguy View Post
Yes, 3S only....,I recall that Ming addressed that question a while back
A pair of these will do nicely on 4S..... http://www.hobbypartz.com/75m91-duct...ProductReviews
seems like that would result in a short flight time though
F-86FLIER4LIFE is offline Find More Posts by F-86FLIER4LIFE
Old Dec 28, 2012, 08:49 PM
Don't Move I've Dropped My Nut
bamaguy's Avatar
United States, AL, Huntsville
Joined Feb 2009
Originally Posted by Doug W View Post
OK, stupid question, as I am an aerodynamicist, not an EDF guy...can I just put bigger (higher amp) ESCs such as 60Amps and run the 777 on 4S? Or will the stock motors not handle it? I want more power but I don't want to blow $300 on more power for a daily flyer.
Doug, It will be quite a challenge to fit a 4S in that small compartment. My GensAce 3S3800 required some hogging of foam to move it fore about 1.5 inches past the front of the battery bay cutout.
bamaguy is offline Find More Posts by bamaguy
Old Dec 28, 2012, 08:59 PM
Lee's Summit, MO
alright, so i think I have put together a full replacement system in case the motors end up not fitting the fans that I want to get. I'll be getting these motors http://www.hobbypartz.com/75m93-ducted-2210-3800.html with http://www.hobbyking.com/hobbyking/s...inch_64mm.html these fans and a couple 40 amp ESCs to run on 3S.
bamaguy's Avatar
Joined Feb 2009
About 2.75 minutes at WOT with a 25C/3800/4S (IF you can fit the battery! )
Old Dec 28, 2012, 09:14 PM
Lee's Summit, MO
I'm sure they will fit, but we don't know their kv.....I've sent an e-mail to Ming about that and about programming info on those 30amp ESC's.
If the kv is 4200 to 4400, they should be fine. It will take a few more amps to turn that 7 blade rotor than the stock rotor, most likely.
Ming said the Kv on the motors is 3800, is that to low?
Old Dec 28, 2012, 09:32 PM
bamaguy's Avatar
Joined Feb 2009
Probably, you should read the comments and discussion about the fan that users have posted on the unit....with different motors and cells. Go back and click the HK link you posted earlier. There is better info there than I can provide.
Old Dec 28, 2012, 09:37 PM
Lee's Summit, MO
Yeah I looked at it. I think I've landed on this little combo, looks like I should be able to hook it right up to the 30 amp ESC's just fine http://www.hobbypartz.com/88e-adf64-300l-kv4300.html
Old Dec 28, 2012, 09:42 PM
bamaguy's Avatar
Joined Feb 2009
Kool! Let us know how it works out
Old Dec 29, 2012, 02:22 AM
limodune's Avatar
Australia, QLD, Toowoomba
Joined Oct 2011
This is the information I have regarding motor size 4200kv ???
limodune is offline Find More Posts by limodune
Old Dec 29, 2012, 04:51 AM
Ming's Avatar
Hong Kong
Joined Jun 2002
Sorry, that should be 4200kv, I mixup to another 737 motor.
Ming Lou
Ming is offline Find More Posts by Ming
Site Sponsor
Old Dec 29, 2012, 12:45 PM
bamaguy's Avatar
Joined Feb 2009
3C3800 GensAce Does Fit!
Ran up the stock equipment again today....each motor draws about 28 amps/305 watts at WOT. Simulated a flight working throttle for taxi/WOT for take off and varying between 2/3 and half power for about 4 minutes. "landed" when battery cell voltages reached about 3.5 volts. ESC's got very warm, bordering on HOT. May replace them with 40 amp Dynam/Detrum units. later. Too darn cold and windy here for a maiden!!
UpDate: Replaced 3200mAh, used 84% of Battery...oooops!
As you know, most all size of battery have to be moved forward to achieve new CG of 200mm. For the GensAce 3800, I only had to dig out about 1.25 inches of foam at the front of the compartment. Width was fine, as is. Also added small plywood piece for other end of battery and the velcro hold down strap. All glued in place with Gorilla Glue (the newer, faster dry-clear, but dries white type) Balances perfectly at 200mm.
Last edited by bamaguy; Dec 29, 2012 at 10:14 PM. Reason: Added Battery Bay Mod Info/Photos
Old Dec 29, 2012, 04:06 PM
Hawaiian Flyin's Avatar
Maui, Hawaii
Joined Dec 2007
Went to the field today and got a few flights in. First two went real nice. Nice flight nice landings. Third flight disaster struck. Upon landing I did a bounce and when it came back down the wings weren't level. Left engine hit the runway and shattered the foam nacelle and destroyed the impeller and cracked the housing. So will need to replace those.
Ming; Can these parts be ordered? Some glue will fix the foam pieces but if I can get a new one would rather do that. The fan and shroud are beyond repair. At least my decal survived!
Hawaiian
Hawaiian Flyin is offline Find More Posts by Hawaiian Flyin
Old Dec 29, 2012, 08:49 PM
Ming's Avatar
Hong Kong
Joined Jun 2002
Hawaiian
Please email me, I have few spare EDF able to ship.
Ming Lou
Site Sponsor
Old Dec 30, 2012, 06:29 PM
limodune's Avatar
Joined Oct 2011
Looks like it is not a good week for the B777
I have damaged my airliner on a second attempted take of, was in the air for a second or two like previous but came down, it has suffered a damaged nacelle and broken plastic and cracked the fuselage a couple of inches back from the wing and now it's a little out of shape and the front strut lean's back about 30* and is lose in the foam
This happened xmas morning, not a good start to the day
Old Dec 30, 2012, 07:39 PM
bamaguy's Avatar
Joined Feb 2009
Ouch! Sorry to hear, Mike
Good thing that I decided not to maiden my 777 today. About 38*...a bit nippy for old thumbs on a new airplane. So, I flew my Great Planes Cherokee, which I'd converted to E-Power and my Dynam Pitts12, instead.
Build Log Boeing 777 200LR foam and tape RC Airliners (Commercial, Cargo, Troop Carrier) 317 Jan 27, 2013 05:01 PM
Wanted Wtb: Windrider boeing 737 hi2nr Aircraft - Electric - Jets (FS/W) 0 Jun 08, 2012 12:36 PM
Discussion Boeing 777-200LR Twin 90mm project NickM91 Scratchbuilt EDFs 20 Jul 10, 2011 08:40 AM
Boeing 777-200/300 Sections Guybo Fuel Jet Talk 3 Jun 15, 2002 07:04 PM
boeing 777 nacelle jermaine Electric Ducted Fan Jet Talk 1 May 20, 2002 01:24 AM
