Old Dec 27, 2012, 10:02 PM
bamaguy is offline
Find More Posts by bamaguy
Don't Move I've Dropped My Nut
bamaguy's Avatar
United States, AL, Huntsville
Joined Feb 2009
Originally Posted by F-86FLIER4LIFE View Post
Hey Ming, or anyone for that matter, was wondering what would be a good replacement fan? I was thinking the Delta V480
The Delta fans are very good and are well made. I don't have the 480, but am using a pair of 70mm V15's in my Airbus A320.
bamaguy is offline Find More Posts by bamaguy
Old Dec 27, 2012, 10:07 PM
F-86FLIER4LIFE is offline
Find More Posts by F-86FLIER4LIFE
Landin' On The Canopy BAD
F-86FLIER4LIFE's Avatar
Lee's Summit, MO
Do you think I would still get a decent flight time using 2 of those on a single 3S 3300? I had one in my old eflite f16, have the V15 in my F86 and they always sound good, but am worried that it would bring me down to about a 3 minute flight at most
F-86FLIER4LIFE is offline Find More Posts by F-86FLIER4LIFE
Old Dec 27, 2012, 10:10 PM
bamaguy is offline
bamaguy's Avatar
Joined Feb 2009
As you probably know, a lot depends on the motor that you put in it....
Old Dec 27, 2012, 10:18 PM
Lee's Summit, MO
Well, I was going to use the 4800kv version for good 3s operations
Old Dec 27, 2012, 10:24 PM
bamaguy is offline
bamaguy's Avatar
Joined Feb 2009
With each motor drawing over 50A, yes, very short flight times..a bit of an overkill, IMO
http://www.horizonhobby.com/products...EFLDF480B:eek:
This one might be better suited.... http://www.horizonhobby.com/products...0kv-EFLM1340DF
Old Dec 27, 2012, 10:26 PM
Lee's Summit, MO
what does the current system pull? It's hard to get new fans if you don't know the specs of the old ones!
Old Dec 27, 2012, 10:35 PM
Lee's Summit, MO
http://www.horizonhobby.com/products...0kv-EFLM1340DF okay, so I was thinking putting one of these in the V480 would be a suitable power system for this plane, what is your opinion bamaguy?
bamaguy is offline
bamaguy's Avatar
Joined Feb 2009
Correct...I think the supplied ESC's are 30 or 40amp...so my guess is around 30amp motors?? I don't have my assembled far enough to measure current (maybe tomorrow).
I'm sure some will chime in with motor data before I can
Old Dec 27, 2012, 10:42 PM
bamaguy is offline
bamaguy's Avatar
Joined Feb 2009
I think the 3800kv would be a good choice....much closer to stock, but better quality
Old Dec 27, 2012, 10:46 PM
Doug W is offline
Find More Posts by Doug W
Doug W's Avatar
United States, WA, Seattle
Joined Jul 2010
Originally Posted by Ming View Post
Please don't use the T style battery plug on 777, two motor draw over 50A may melt the plug.
Ming Lou
Can you show me a pick f what you are referring to Ming ("T-style battery plug")? That's I think what I use on all my models, including 737 with no issues whatsoever...
Also, couldn't I just upgrade the ESCs to a higher rating and solve any issues?
Doug W is offline Find More Posts by Doug W
Old Dec 27, 2012, 10:47 PM
Lee's Summit, MO
Yeah, when I saw it only takes about 20-40 amps, I felt like it would be a better match, still in search for the fan unit though
Old Dec 27, 2012, 10:51 PM
bamaguy is offline
bamaguy's Avatar
Joined Feb 2009
He may be referring to the Chinese copy of the real "Deans" plug. The real Deans are rated for up to 90amps. I have never had a problem with genuine Deans.
Most of my connections use XT60 http://www.hobbyking.com/hobbyking/s...Nylon_XT60_Con
nectors_Male_Female_5_pairs_GENUINE.html NEVER had any issues with them!
I just received some 90amp rated XT90's for future use... http://www.hobbyking.com/hobbyking/s..._Nylon_XT90_Co
nnectors_Male_5pcs_bag_.html
Old Dec 28, 2012, 11:45 AM
Plankdriver6 is offline
Find More Posts by Plankdriver6
United States, OK, Lawton
Joined Dec 2012
Ming
I have read the ESC's provided with the kits are Hobbywing. I have a Hobbywing ESC programmer that I will use. Is there an online manual for the 30 A esc you provide with the kit can I assume it's the Hobbywing Fun Fly 30 A ESC. I want to be sure the ESC is compatable with the programmer can you provide detailed data on the ESC?
Ron
Plankdriver6 is offline Find More Posts by Plankdriver6
Old Dec 28, 2012, 11:47 AM
Ming is offline
Find More Posts by Ming
Ming's Avatar
Hong Kong
Joined Jun 2002
Send me email to ming@windrider.com.hk
I just got 2 pcs spare stock fan for 777.
Ming
Ming is offline Find More Posts by Ming
Site Sponsor
Old Dec 28, 2012, 06:43 PM
bamaguy is offline
bamaguy's Avatar
Joined Feb 2009
Originally Posted by Plankdriver6 View Post
Ming
Ron
They may be made by HobbyWing, but are not compatable with the "Turnigy" program card.....tried mine, no go Did you ever get any ESC info from Ming?
Build Log Boeing 777 200LR foam and tape RC Airliners (Commercial, Cargo, Troop Carrier) 317 Jan 27, 2013 05:01 PM
Wanted Wtb: Windrider boeing 737 hi2nr Aircraft - Electric - Jets (FS/W) 0 Jun 08, 2012 12:36 PM
Discussion Boeing 777-200LR Twin 90mm project NickM91 Scratchbuilt EDFs 20 Jul 10, 2011 08:40 AM
Boeing 777-200/300 Sections Guybo Fuel Jet Talk 3 Jun 15, 2002 07:04 PM
boeing 777 nacelle jermaine Electric Ducted Fan Jet Talk 1 May 20, 2002 01:24 AM
