Old Dec 07, 2012, 10:07 PM
Hawaiian Flyin is offline
Find More Posts by Hawaiian Flyin
Hawaiian Flyin's Avatar
United States, HI
Joined Dec 2007
Managed to get another flight in today. Moved the battery back a bit. Was able to lift off quicker and fly a bit slower BUT it seemed less responsive while turning. May just go back to the original setting. Also noticed after just 3 flights the wheels showing some significant wear. Might be from the rough asphalt runway or just my not so smooth landings.
Video can be seen here.:
GOPR0148222 (5 min 59 sec)
Ming:
Has my 787 shipped yet? If it has can you give me a tracking number? I will be going on vacation next week so will have my neighbor looking for it. Dont want to have it delivered and sitting on my driveway for days on end.
Hawaiian
Hawaiian Flyin is offline Find More Posts by Hawaiian Flyin
Old Dec 08, 2012, 02:22 PM
AMARC is offline
Find More Posts by AMARC
Joined Jun 2012
We have short grass, but had to hand launch, as it wouldnt pick up enough speed on the ground.
Was a bit hairy, on the edge of stall and dropping the wings for the first 20 metres of the climb.
Had to put in a fair bit of up elevator to trim her out, maybe a bit nose heavy, but is spot on 5mm from wing line.
Also a bit of left alieron trim, as if the wing is slightly twisted, but could be the fact there was a little packing damage to the right wingtip.
Slips through the air nicely when up to speed and looks very scale, but battery got pretty hot and needs full throttle 90% of a flight ( so only 5 mins flight time ).
I think its a fly once or twice in the summer plane, as its a pain having to hand launch.
AMARC is offline Find More Posts by AMARC
Old Dec 08, 2012, 04:56 PM
United States, HI
Joined Dec 2007
What battery are you using? I flew mine for a little over 4 minutes at 2/3 to 3/4 throttle and the battery was not too hot at the end of the flight. Put it on my battery checker and showed 39 percent of the battery capacity left.
Old Dec 08, 2012, 06:17 PM
AMARC is offline
Joined Jun 2012
Brand new Gens Ace 3300 3S 30C, which had 36% left after 5 mins.
Try not to go under 30% for longer service life.
Old Dec 08, 2012, 06:36 PM
United States, HI
Joined Dec 2007
Weird. I'm using a Turnigy 3S 3300 30-40c discharge pack thats about a year old and my plane flew ok.
Old Dec 08, 2012, 06:56 PM
bamaguy is offline
Find More Posts by bamaguy
Don't Move I've Dropped My Nut
bamaguy's Avatar
United States, AL, Huntsville
Joined Feb 2009
You might put battery thru 3 or 4 charge/discharge cycles before you use it in the plane again Did you check the ESC's programming.....especially the throttle endpoints?
bamaguy is offline Find More Posts by bamaguy
Old Dec 09, 2012, 05:16 AM
limodune is online now
Find More Posts by limodune
limodune's Avatar
Australia, QLD, Toowoomba
Joined Oct 2011
Just a quick update, one of the 70mm edf's is in tested and running smooth, it was a shoe horn fit, should get the second one fitted by Tuesday and a maiden-test flight Wednesday
limodune is online now Find More Posts by limodune
Old Dec 09, 2012, 07:16 PM
United States, HI
Joined Dec 2007
Good luck. Post some video of the flight. Really curious as to how it flies with the 70mm fans. should be fast!
Old Dec 10, 2012, 05:36 AM
AMARC is offline
Joined Jun 2012
Will the supplied motors take 4S voltage ?
I need more thrust if i am to get this off the grass, cant keep hand launching and fighting for control for 10 seconds, will end in tears.
Old Dec 10, 2012, 09:20 AM
bamaguy is offline
bamaguy's Avatar
Joined Feb 2009
Suggest that you e-mail Ming with the question
Old Dec 10, 2012, 09:28 AM
Ming is offline
Find More Posts by Ming
Ming's Avatar
Hong Kong
Joined Jun 2002
Please check how many amps to draw from battery.
Ming Lou
Ming is offline Find More Posts by Ming
Site Sponsor
Old Dec 10, 2012, 12:07 PM
AMARC is offline
Joined Jun 2012
so motors will be ok on 14.4V, but the ESC are the limiting item ( 30a ? each ) if current draw is to high
Old Dec 10, 2012, 07:23 PM
Ming is offline
Ming's Avatar
Hong Kong
Joined Jun 2002
Can't run 4 cells on this motor.
The same motor and esc was very successful on other PNP plane.
Ming Lou
Site Sponsor
Old Dec 10, 2012, 07:40 PM
bamaguy is offline
bamaguy's Avatar
Joined Feb 2009
A pair of these will more than do the job......but you will need a quality LiPo around 4000/40C (at least)
http://www.pw-rc.com/product_info.ph...oducts_id/2017
Old Dec 10, 2012, 10:42 PM
United States, HI
Joined Dec 2007
Anybody try weighing their planes? I weighed mine and it came in at 1675 grams or 3 lbs 11.2 oz. with the battery. Mine is painted and has 2 coats of WBPU on it.
Hawaiian
Build Log Boeing 777 200LR foam and tape RC Airliners (Commercial, Cargo, Troop Carrier) 317 Jan 27, 2013 05:01 PM
Wanted Wtb: Windrider boeing 737 hi2nr Aircraft - Electric - Jets (FS/W) 0 Jun 08, 2012 12:36 PM
Discussion Boeing 777-200LR Twin 90mm project NickM91 Scratchbuilt EDFs 20 Jul 10, 2011 08:40 AM
Boeing 777-200/300 Sections Guybo Fuel Jet Talk 3 Jun 15, 2002 07:04 PM
boeing 777 nacelle jermaine Electric Ducted Fan Jet Talk 1 May 20, 2002 01:24 AM
