Nov 29, 2012, 04:16 PM
Australia, QLD, Toowoomba
Joined Oct 2011
I got it from e-bay, search SIGN VINYL it comes in 14 or 24'' rolls, you buy 4 or 5 at a time.
Check the 737 thread, lots of info there in detail, you will need a heat gun to allow it to stretch, use the low heat setting and give 4-5 quick passes about a foot away, to much heat and it will make the foam rise, do a test piece first to get the hang of it, also start from the back so the seams are pointing backwards, I gave a 3mm over lap of the seams, I put mine on in 4 sections though I added extra panels around the nose area to make it cover well
