Old Nov 20, 2012, 06:29 AM
Spudz27 is offline
Find More Posts by Spudz27
Australia, WA, Perth
Joined Mar 2012
Got my 777 today. Put it all together and it looks as though one wing is higher than the other. So I checked over it and the top of the wing join is flush, but the bottom is not right. Did anybody else have this issue and if so what was the cause? I can't figure it out. All leads were out of the way, spars in and the wings pushed together as hard as I could, which as I said gave a flush join on top, but not on the bottom. Of course I stupidly epoxied it before realising.
O.k so the nacelle's are the same height but the wing tips look like they are out out by 1cm, the underneath of the wings is flat. The nacelles both read 110mm from the top centre to the floor, but the wing tips read 175mm on the right and 185mm on the left. So given the nacelles are at the same height, one could assume the wing itself has a warp? I might just have to see how she flies. Here is a pic of what I mean
Spudz27 is offline Find More Posts by Spudz27
Old Nov 21, 2012, 12:30 AM
Spudz27 is offline
Joined Mar 2012
Well she is all ready to fly, still can't work out the wing. Just need to buy some batteries. I would have to cut way too much foam away for my liking to fit the 4000 in, unless I sit it in on it's side, in which case I only need to cut from the top of the fuzz. Might just be easier to go with 3300's.
Old Nov 21, 2012, 01:39 AM
Ming is offline
Find More Posts by Ming
Ming's Avatar
Hong Kong
Joined Jun 2002
max is 3300, 4000 is too big I can say.
Ming Lou
Ming is offline Find More Posts by Ming
Site Sponsor
Old Nov 21, 2012, 03:20 AM
Spudz27 is offline
Joined Mar 2012
Believe it or not, I did some minor cutting, the 4000 is in and it is balanced fine at 200mm. I just don't have the funds for more batteries and these 4000 are brand new. So I can say it does fit and to be honest I removed barely any foam. Just a bit crowded now lol.
Old Nov 21, 2012, 06:30 AM
Spudz27 is offline
Joined Mar 2012
All ready for maiden tomorrow if everything goes well weather wise
Old Nov 21, 2012, 03:10 PM
rob737 is online now
Find More Posts by rob737
United States, CT, Guilford
Joined Nov 2008
looks great, spudz! did you ever figure out why one wing is higher than the other? hope the maiden goes well in any event.
rob737 is online now Find More Posts by rob737
Old Nov 21, 2012, 05:32 PM
limodune is online now
Find More Posts by limodune
limodune's Avatar
Australia, QLD, Toowoomba
Joined Oct 2011
Spuds good to know the 4000 battery can be fitted if needed, longer flight times for sure, have a good maiden
limodune is online now Find More Posts by limodune
Old Nov 21, 2012, 06:05 PM
limodune's Avatar
Joined Oct 2011
Just finished the last of the vinyl work to be done on the belly, the wing's were glued together with GG then all the join's filled with spac filler and sanded, I butt glued together the grill and added a couple of sticks to make it a little stronger, I took advantage of the recess's on the belly and opened them up for more airflow to the speedies, we have just started 30* days here, I used a piece of 10mm sharpen'd rod to open up the holes, I still have to change out the wheels but that is the last of the mod's for the moment, this is the first time I have vinyl'ed a plane --it has been an experience
Old Nov 21, 2012, 06:20 PM
limodune's Avatar
Joined Oct 2011
Double post
Old Nov 21, 2012, 09:56 PM
Spudz27 is offline
Joined Mar 2012
Looks good mate.
Maiden was a success, no trim was required at all, however the plane is prone to moving around a lot. I have some video but it didn't turn out good, so will grab some still shots from the video.
As I was doing low passes, I realised the LG was on back to front as the wheels were hanging forward not back lol.
Old Nov 21, 2012, 11:47 PM
Hawaiian Flyin is offline
Find More Posts by Hawaiian Flyin
Hawaiian Flyin's Avatar
United States, HI
Joined Dec 2007
Congrats on the successful maiden! Planning on flying mine on Friday. Forecast is for no wind and sunny. We all know the weatherman is always right!
Hawaiian Flyin is offline Find More Posts by Hawaiian Flyin
Old Nov 22, 2012, 02:42 AM
Spudz27 is offline
Joined Mar 2012
Looks great, here is hoping you too have a successful maiden.
Old Nov 23, 2012, 07:36 AM
limodune's Avatar
Joined Oct 2011
I now have the radio gear in mine and it's ready for it's maiden, I have carved out the forward part of the lower hatch to get the battery in location for the C of G, is this where you guy's have yours to achieve C of G
Old Nov 23, 2012, 11:57 AM
United States, HI
Joined Dec 2007
That's the same battery I'll be using to fly mine. Plane is loaded in the truck and was hoping to maiden it today but grandson is sick so I got volunteered to watch him. Hope to try tomorrow. Going to use the balance point Ming showed to start. 5mm back from the middle wing line.
Good luck on your inaugural flight!
Old Nov 24, 2012, 04:56 AM
Spudz27 is offline
Joined Mar 2012
Mine flight today ended in disaster. The plane went down in the tree's, and we fly around very thick scrub etc. After a drive through the bush and a bit of searching, we pulled it totally unmarked from the bushes lol. Went for another flight and almost lost it at the exact same place, given the maiden was uneventful, I can only assume the RX is losing communication, or this plane is not meant for anything but a breeze, it seemed to wallow a lot, in a turn, it just kept rolling over and diving for the ground, then was going straight and it just went skyward, very strange indeed, but again me thinks it is aan rx issue. So will try a different rx.
Build Log Boeing 777 200LR foam and tape RC Airliners (Commercial, Cargo, Troop Carrier) 317 Jan 27, 2013 06:01 PM
Wanted Wtb: Windrider boeing 737 hi2nr Aircraft - Electric - Jets (FS/W) 0 Jun 08, 2012 01:36 PM
Discussion Boeing 777-200LR Twin 90mm project NickM91 Scratchbuilt EDFs 20 Jul 10, 2011 09:40 AM
Boeing 777-200/300 Sections Guybo Fuel Jet Talk 3 Jun 15, 2002 08:04 PM
boeing 777 nacelle jermaine Electric Ducted Fan Jet Talk 1 May 20, 2002 02:24 AM
