Old Nov 14, 2003, 05:43 AM
Norway
Joined Oct 2003
Is 0.8 kg/cm (12oz/in) enough to drive the rudder on a GWS size warbird?
I'm trying to pick the servos for my new project. A scratch built Hawker Tempest with GWS 350 power.
Is this enough torque for the rudder: 0.8 kg/cm (12oz/in)
How much do I need for the ailerons and elevator? I'm guessing 0,8kg/cm is not enough.
Spiteful
Spiteful is offline Find More Posts by Spiteful
Old Nov 14, 2003, 02:27 PM
College Park, MD
Joined Sep 2002
That's probably plenty for the elevator and rudder. I've used Pico STD servos on my GWS warbirds' elevator and rudder with no problems. They only have 10 oz/in torque. The only thing I'd be careful about is in a tailwheel situation. Could be enough torque there to strip a gear.
For the aileron I'd use a servo with at least 1 kg/cm or 15 oz/in torque. It really depends on the amount of drag/friction in the actuating mechanism. Flex cable is pretty high friction, torque rods are lower.
thunder1 is offline Find More Posts by thunder1
Old Nov 14, 2003, 02:33 PM
Nickel what?
Phreakish's Avatar
Prescott, Arizona, United States
Joined Jan 2003
I run pico std in my mustang, and havnt' had a problem (yet... brushless will tell)... I even ran a tailwheel with the pico, and didn't have a problem (the tiny parkflier tailwheel is hard to lever a lot).
Phreakish is offline Find More Posts by Phreakish
Old Nov 14, 2003, 05:52 PM
Idaho
Joined May 2002
GWS Pico or Hitec 55 should be able to handle any parkflyer needs for any plane flying 25mph or less. The only exception would be a 3D type craft with barn door control surfaces. thunder 1 is right in cautioning aileron control with flex cable will need more torque than torque rods. If possible, use torque rods for the ailerons. The weight savings on the smaller servos will compensate for the extra work of fitting rods.
JT
DEPENDS is offline Find More Posts by DEPENDS
Old Nov 17, 2003, 03:37 AM
Norway
Joined Oct 2003
Thanks folks.
I now know what to look for!
Alert Flying on 8/26/06, Location in Park Change..... Tommy632 North Coast Electric Flyers 55 Aug 28, 2006 10:25 AM
Help! Convert kg/cm to oz/in yukondog Radios 7 Apr 02, 2006 04:24 AM
Out-of-Towner wanting to e-Fly in Alpharetta/Cumming area on 8/14-8/19 SteveE Atlanta Area RC 2 Aug 09, 2004 08:53 PM
Question 0.8 oz receiver in 31" span park flyer greyhound Electric Plane Talk 14 Dec 31, 2003 09:00 AM
