Old Jul 10, 2012, 06:34 PM
hamburger is offline
Find More Posts by hamburger
Hamburger
hamburger's Avatar
Joined Jan 2010
Floats for multicopter?
Hi,
I want to use one TRI to fly over water, a lake to be precise; so no high waves.
To be on the safe side at least a little more, I want to replace the landing gear with floats. AUW of the copter is about 800 grams, m2m is 60cm.
About the material:
Currently I am in favor of large foam balls.
The foam either will have to be of closed to water structure, so it does not soak,
or it needs some kind of laminating / epoxying the surface. Not sure what is best.
About the shape
spheres are probably easily available and have good in flight characteristics. But is that shape sutable for vertical takeoff or does it stick to the water surface too much during starts? Maybe a downwards oriented cone at the end of cylinder would be better?
Ideas?
hamburger is offline Find More Posts by hamburger
Old Jul 10, 2012, 06:38 PM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
You'll still need to water proof the electronics. The prop wash will splash up quite a bit of water unless you have tall landing gear which will make you easy to tip over.
MCrites is offline Find More Posts by MCrites
Old Jul 10, 2012, 06:46 PM
Hamburger
hamburger's Avatar
Joined Jan 2010
ok, good point. Will do that. And I want to keep the landing gear low.
Old Jul 10, 2012, 07:32 PM
dutchcommando is offline
Find More Posts by dutchcommando
making crashing a lifestyle!
dutchcommando's Avatar
The Netherlands, UT, Soest
Joined Feb 2012
pool noodles will keep your tri floating without adding a lot weight..
i tried it on my quad to. the quad weighs approx. 1450 grams..
i wasn't successful for me though..
quadcopter swimming (1 min 29 sec)
dutchcommando is offline Find More Posts by dutchcommando
Old Jul 10, 2012, 08:58 PM
MK is offline
MK
Find More Posts by MK
MK
NJ
Joined Feb 2001
You need to tie the floats to the ends of the arms and not the body like a heli.
MK is offline Find More Posts by MK
Old Jul 10, 2012, 10:16 PM
power is offline
Find More Posts by power
Begin with end in mind...
power's Avatar
Eagle Lake, Minnesota
Joined Apr 2003
Pool noodles rock!!
Not that this will save the camera from damage, but it wont sink
power is offline Find More Posts by power
Old Jul 11, 2012, 12:03 AM
rcbif is offline
Find More Posts by rcbif
Do a Barrel Roll!
rcbif's Avatar
United States, OH, Medina
Joined Jun 2005
what about 3 or 4 mini 8oz water bottles? You know the ones the size of a can of soda. They wont absorb water like pool noodles do ever time. Pool noodles can eventually become waterlogged.
rcbif is offline Find More Posts by rcbif
Old Jul 12, 2012, 05:58 PM
Hamburger
hamburger's Avatar
Joined Jan 2010
I will try to aquire some foam spheres and cover with thinned epoxy. Water bottles I do not trust to not get punctured unknowingly.
And yes, I will attach the floats far out.
Noone commented on the neccessary shape for liftoff. While this seems a big issue for floats for waterplanes I take it that is coupled to speed over water which VTOL multicopter has not; so it does not matter too much.
Thanks everybody. I will post results when floats are floating.
Old Jul 12, 2012, 06:37 PM
MCrites is offline
Joined Jan 2012
You will lose efficiency with the weight and if they get caught up in the prop wash. If they are inside/outside of your props the shape shouldn't matter as much.
Old Jul 15, 2012, 09:15 AM
simiban is offline
Find More Posts by simiban
simiban's Avatar
France, Alsace, Erstein
Joined Jul 2012
You can also add severals 'Waterbuoy" on yours multi, each one can lift up to one kilo and will only pop up once in the water.
It's also equiped with a small red LED witch light for more than 2 days
WATER BUOY
Big + it weight almost nthing (19gramms)
simiban is offline Find More Posts by simiban
Old Jul 15, 2012, 11:05 AM
CH33ZEBURG3R is offline
Find More Posts by CH33ZEBURG3R
Australia, VIC, Frankston
Joined Jul 2012
Get a large piece or polystyrene and cut something out of it?
CH33ZEBURG3R is offline Find More Posts by CH33ZEBURG3R
Old Jul 16, 2012, 12:55 AM
Kahnx is offline
Find More Posts by Kahnx
Registered DSer
Kahnx's Avatar
Australia, VIC, Hadfield
Joined Mar 2003
My Tri-float experiment
I tried this a few months ago:
Got a ploystyrene fruit box from the local market.
Chopped the corners off at a 45 degree angle.
Attached them to the existing 'legs' of the tricopter, inboard of the props to ensure that they didn't affect the prop-wash.
Used cable ties, which put holes through the corners - the floats fill up with water, but that drains out soon after lift-off.
I like the pointy tips, which eliminates 'sticktion' to the water on lift-off.
See the video below of the test flights. I intended only to keep the tri-afloat if I ditched it while undertaken FPV ops.
Tricopter on floats test flights (1 min 37 sec)
Roger.
Kahnx is offline Find More Posts by Kahnx
Old Jul 16, 2012, 01:54 AM
iamsuperbleeder is offline
Find More Posts by iamsuperbleeder
Licensed Lunatic
iamsuperbleeder's Avatar
United States, FL, Lake City
Joined Mar 2012
WATER BUOY
I'm pretty sure that's a one time use thing...
I think pool noodles would be an EXCELLENT option; they support a lot of weight. Plus they're cheap!
I made some little foam floats out of some packaging out of something for my MQx. They worked fine, it just made me nervous as all hell to land on the water, and the extra weight was noticeable...
iamsuperbleeder is offline Find More Posts by iamsuperbleeder
Old Jul 16, 2012, 02:25 AM
simiban is offline
simiban's Avatar
Joined Jul 2012
Yes you are right, it's a one time use only
But I need them to prevent from sinking in case of an unwanted water landing
I do not plan to land on water every time, I'm not in waterworld
It's only to have time to look for a small boat in case my Octo have a problem by hovering a lake or something like that
In Decembre I would like to take my time, and most of all, I wouldn't like to have to jump in the water , so with this systeme, i have plenty of time to surch a small boat and to rescue my half way floating crap machine
Old Jul 16, 2012, 03:03 AM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
WATER BUOY
i have and do use these as well... i have not needed them, but i tested them and i needed 3 to lift my AP rig... so i have 3 on my rig when i fly over lakes and rivers.
like here:
Aerial Highlight Reel Wyoming 2012 (ATV, Horseback, Fly Fishing, Real Estate, Salt & Snake Rivers) (4 min 36 sec)
Adidas4275 is offline Find More Posts by Adidas4275
Discussion Looking for a Nice multicopter dc9guy Multirotor Talk 18 Jun 25, 2012 08:56 PM
Discussion Wow, we need this for multicopters milo12 Multirotor Talk 4 Jun 23, 2012 02:12 PM
Question suggestion for a stable multicopter solution thexhulk Multirotor Talk 0 Jun 21, 2012 01:59 PM
Wanted Looking for the Banana Hobby MIG-29 and will trade for my multicopter jasper7821 Aircraft - Electric - Airplanes (FS/W) 0 May 09, 2012 07:48 PM
Discussion Looking For Floats For E-Flight Apprentice... NFA Fabrication Waterplanes 1 Apr 06, 2012 09:43 PM
