Old Jul 10, 2012, 04:49 PM
WhiteNite1971 is offline
Find More Posts by WhiteNite1971
Joined Sep 2011
BEVRC Easy Diversity Controller
Hi Gang
I have just purchased the BEVRC Easy Diversity Controller and I have a few questions;
1. Does the system run off 12V?
2. How do you adjust the unit to balance the RSSI voltages from the video receivers?
Kind Regards
Jason
WhiteNite1971 is offline Find More Posts by WhiteNite1971
Old Jul 11, 2012, 02:55 AM
joel0407 is offline
Find More Posts by joel0407
joel0407's Avatar
Australia, NT, Lyons
Joined Oct 2010
Originally Posted by WhiteNite1971 View Post
Hi Gang
1. Does the system run off 12V?YES
2. How do you adjust the unit to balance the RSSI voltages from the video receivers?I don't know you can. I just use 2 identical receivers. If I want to secify to use one only, I change the channel of the opposite receiver.
Kind Regards
Jason
Happy Days
joel0407 is offline Find More Posts by joel0407
Old Jul 11, 2012, 06:19 AM
Joined Sep 2011
Hi joel0407
Thanks for the reply. So you don't experience any problems with the diversity controller switching from one video receiver to the other?
Kind Regards
Jason
Old Jul 11, 2012, 06:28 AM
joel0407 is offline
joel0407's Avatar
Joined Oct 2010
Yeh, I do mate, when my Tx is very close by and I have the same antenna on both Rx. Like when testing on the kitchen table. As soon as I have a couple of meters distance, it's fine. As I have my 2 x Rxs all connected up in my ground station box, when I'm testing stuff on the bench, I just change the channel of one of the Rx up or down one. Obviuosly when my Tx is on 8 and one Rx is on 8 and the other on 9, the one matching the Tx gets the best signal and stops the switching. When it's switching alot on the bench you get about 1 second lose of video but that doesn't happen when its at distance and makes the change from one to the other. When I'm at distance, I have a patch antenna on on Rx and a Clover Leaf CP on the other.
Happy Days
Old Jul 11, 2012, 09:42 AM
Joined Sep 2011
Hi joel0407
Thanks again for the reply. How have you connected your RX's (photos)?
Kind Regards
Jason
PS I'm using RC305's
Old Jul 12, 2012, 12:44 AM
joel0407 is offline
joel0407's Avatar
Joined Oct 2010
Description:
I'll get a better pic later. Sending this from my IPhone.
Old Jul 12, 2012, 05:16 AM
Joined Sep 2011
Hi joel0407
Two words. NICE WORK!
Cheers
Jase
PS What size is the DC jack on the diversity controller?
Old Jul 12, 2012, 05:22 AM
joel0407 is offline
joel0407's Avatar
Joined Oct 2010
It's the standard. The same as the Rxs. I think it 3.5mm DC. The RSSI leads between the RXs and the Diversity are 2.5mm mono audio type.
Old Jul 12, 2012, 05:28 AM
joel0407 is offline
joel0407's Avatar
Joined Oct 2010
The only downside I can see to this diversity system is it doesn't consider the video quality, only the Rx power. The problem with Rx power is the RF doesn't have to come from you VTx. For example, if you use it on 2.4Ghz, here in Australia WiFi networks are 2.4Ghz, as are cordless phones and other household RF appliances. All these will create higher Rx power but worse Video.
I fly far enough away from populated areas and any other RF sources that the only source is from my own Vtx.
Old Jul 12, 2012, 08:13 PM
LexusFPV is offline
Find More Posts by LexusFPV
TBS Crossfire or DragonLink?
Joined Feb 2011
Just wanted to know bc the FoxTech Website has some sort of RSSI soldering modification to video Rx?
So I have 2 LawMate VidRx, do I just plug them right in with the monopole headphone jacks?
those Monopole headphone jacks have Audio/Video? (White and Yellow)....
and we power our VidRx separately?
confused?
LexusFPV is offline Find More Posts by LexusFPV
Old Jul 13, 2012, 05:05 AM
joel0407 is offline
joel0407's Avatar
Joined Oct 2010
confused?
Nope. Not the Audio/Video leads. Higher end diversity uses that, Oracle diversity, for example.
The BEVRC Diversity requires RSSI output from your Recevier. I think the Sunsky receivers can be modified. That might be the FoxTech thing you are talking about.
Old Jul 13, 2012, 05:26 AM
joel0407 is offline
joel0407's Avatar
Joined Oct 2010
Here you see the BevRC Receviers with the RCA Video (Yellow) and RCA Audio (White) with the RSSI in between.
Old Jul 13, 2012, 05:28 AM
joel0407 is offline
joel0407's Avatar
Joined Oct 2010
Here you see the RSSI and RCA Video (Yellow) from each receiver, going into the Diverstiy.
Old Jul 13, 2012, 05:31 AM
joel0407 is offline
joel0407's Avatar
Joined Oct 2010
Here's the power feed for the Diversity.
Old Jul 13, 2012, 05:37 AM
joel0407 is offline
joel0407's Avatar
Joined Oct 2010
This is how I have them laid out. The 2 x RCA video leads out of the bottom of the Diversity are identical video feeds. One goes to my HDD recorder and the other to my Fat Shark goggles.
I have the audio from each receiver goes to the left and right channels of the recorder but not through the diversity.
Discussion BEVRC.com Easy Diversity just 15$ RcCreator FPV Equipment 20 Aug 06, 2013 09:24 AM
Discussion BEVRC Easy Diversity joel0407 FPV Talk 1 Jun 03, 2012 01:39 AM
Discussion DIY Diverity Controller without RSSI Rangarid FPV Talk 10 Apr 03, 2012 01:03 PM
Sold BEVRC Easy OSD mflander FPV Equipment (FS/W) 4 Sep 19, 2011 12:57 PM
Alert problems with easy OSD and online store bevrc.com guy1a FPV Talk 0 Jun 07, 2011 06:49 AM
