Old Sep 19, 2012, 11:54 AM
kenh3497 is online now
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
Originally Posted by quincross View Post
Today I finished the wing/boom mount and learn an important addition to the axiom “Measure twice, cut once” – it will now be “Measure twice with 2 different tools, cut once”.
You've got it all wrong.... My motto has always been and seems it always will be.... "Measure twice, cut three times"
Good looking build you've got going there!!
Ken
kenh3497 is online now Find More Posts by kenh3497
Old Sep 19, 2012, 01:07 PM
quincross is offline
Find More Posts by quincross
Ride, Surf, Fly, Sleep
Joined Dec 2007
Originally Posted by The_Builder View Post
Very Clean Mate!!
I am building one so I have something to fly in an upcoming event but I cannot find the camera battery charger so I am thrilled you are doing such a great job detailing the build. You are indeed a master builder.
Paul
No worries a pleasure - it's been a great build and I'm really critical about these kind of things. Cheers for the big up mate - but undeserved especially as I still can't believe I set the mounts too far back.....(bangs head on table)
Originally Posted by kenh3497 View Post
You've got it all wrong.... "Measure twice, cut three times"
Luv it - fits with my TLAR principle for fun-flys - "Don't measure, just cut and cut and cut - the airframe work out lighter"
quincross is offline Find More Posts by quincross
Old Sep 19, 2012, 02:12 PM
Nathan Schmoekel is offline
Find More Posts by Nathan Schmoekel
ground penetration specialist
Nathan Schmoekel's Avatar
USA, MI, Grand Rapids
Joined Apr 2007
That half an inch error will not hurt you at all, infact it may save you needing a few grams of nose weight to balance her out.
Nathan Schmoekel is offline Find More Posts by Nathan Schmoekel
Old Sep 19, 2012, 03:36 PM
The_Builder is online now
Find More Posts by The_Builder
God Created me to Create
The_Builder's Avatar
Joined Nov 2009
Since I put the servos in the wings on the one I am doing now I had to add .5oz to the nose which brought the AUW to 7.8oz. I think I could do 7oz and still have a conservative CG with a careful build.
Luap
The_Builder is online now Find More Posts by The_Builder
Old Sep 19, 2012, 03:43 PM
Joined Dec 2007
Let's hope mate - I'm certain you're right....but I could still kick myself!
Still I'll be using stripped down gear and if the CF rods prove too short now it gives me an excuse to use my CF micro tubing on something that isn't a indoor flyer.
I tend to use 0.7mm and 1.5mm OD tubing so have some lying about. I doubt I'll use the 0.7mm tube (inner dia is 0.25mm ), but the 1.5mm I have is perfect with an internal diameter of 0.7mm (bang on the wire Paul supplied). You can then get away with tiny wire ends so using tubes usual cut 60-70% off the push rod weight in total and still work out stiffer as they come in at about 60% unidirectional fibre. A bit of a waste of material on the FF as I doubt 1-2g will count much but....if there's an excuse!
Old Sep 19, 2012, 04:02 PM
Joined Nov 2009
I just did my shorties with .030 wire ends and hypo tubing connecting them.
Paul
Old Sep 19, 2012, 04:23 PM
Joined Dec 2007
Yeah mate - it's a cracking system for smart rods! Presume you're talking about steel hypodermic tubing? I used to use that too, until a mate shoved me in this direction (I think they have outlets for this stuff States side too).
http://www.easycomposites.co.uk/Cate...rbon-Tube.aspx
Everything from a 0.030" OD tube (0.0098" inner) upwards at reasonable prices (~$6) for 1m lengths. Not sure there's much of a significant weight saving over hypo tubing, but hey it looks cool
Both hypo and micro tube beat the pants of "rod and shrink" push rods for looks, stiffness and weight
Old Sep 20, 2012, 12:19 AM
Joined Nov 2009
I will have to look into the carbon stuff. I had the Hypo stuff from when I was doing some RDS stuff.
Old Sep 21, 2012, 03:13 AM
Joined Dec 2007
Last night I set the stab - I'll post the photos tonight - and then I noticed something very odd, the wing appears to be set at a negative AoA to the stab. I've double checked the rear incidence block, everything has the correct dimensions (3.mm), and mounting the posts further back won't have caused this as the boom has constant taper - so it must be an optical illusion or part of the design.
I'll check the AoA on a meter later on to be sure this is not an optical effect, but I think the wing is either set very slightly negative or at 0* - is this something specific to DLGs and camber needs to be added in the set up or have I missed something?
BTW stab is on the bottom of the boom as per design, so that's not caused it.
Old Sep 21, 2012, 05:50 AM
bbbp is offline
Find More Posts by bbbp
a.k.a. Bob Parks
United States, AZ, Glendale
Joined Jun 2008
Remember that the wing's incidence is from the very front of the leading edge through to the trailing edge, not just along the bottom as it would sit on a table.
BP
bbbp is offline Find More Posts by bbbp
Old Sep 21, 2012, 06:23 AM
Joined Dec 2007
BP
Yeah, thanks - that's caught me out before as some airfoils gives an "optical illusion" even when you are sighting down the correct line.....until you get the meter on it and everything measures out OK. I suspect, this is probably the case this time around, but I'm used to that illusion now and my eyes are still telling me this wing is small -ve or 0* - very weird. Must be my eyes' lack of experience with DLG airfoils
I'll get the meter on when I get home and that'll give me a definitive answer.
Old Sep 21, 2012, 07:57 AM
Ken Lilja is online now
Find More Posts by Ken Lilja
I'm slow but I'm expensive
Ken Lilja's Avatar
United States, GA, Snellville
Joined Nov 2003
Most airfoils don't go to zero lift until they reach an AOA of -1 to maybe -3 degrees to the chord line. And the chord line is not the bottom surface of the wing. So yes visual sighting could look screwy.
Ken
Soon to receive most of a kit.
Ken Lilja is online now Find More Posts by Ken Lilja
Old Sep 21, 2012, 08:38 AM
Joined Dec 2007
Ken
Strange you should say that - I've been fitting the Vert, and that is cambered and needs to be set at the zero lift line.
Sighting up only approximates zero lift and I know I have issues here already given my take on the wing
So I grabbed a fag break (that's a 'smoke' to you guys across the pond not something on the wild side ) and pondered that what I needed was a portable wind tunnel.....mmmm......
So behold....drum roll....
"the ACME Portable Wind Tunnel"
3 mins later I had a Vert at zero lift AoA. Sighting up as a secondary check confirmed that it wasn't just some fluke. So it seems to work great and only took 1 min to make - if you have a try you want to do it in the centre of the room though to minimise wall cyclic effects. The straws should ensure that airflow is linear out of the cup, it's the same principle that I use on my big DIY tunnel in 'Shed No. 2'
Beep! Beep!
Old Sep 21, 2012, 12:07 PM
Joined Dec 2007
Woohoo - finally it looks like a plane! And it looks great - the stab and vert are on but I've yet to patch the vert across the boom - I'll think on that tonight as I've half a mind to tie it to the vert's main spar as the boom ends 1/4" in front of it...but don't want to add unnecessary weight....dunno really
The wing's AoA is probably OK at very slightly above 0* - hard to know for sure as my DIY meter doesn't fit exactly because of the longer boom to root chord ratio than a standard thermaller.
Old Sep 21, 2012, 04:12 PM
Joined Nov 2009
OKay a Conformation and an admission of how wild this week has been. I finished up a plane for the Wilson event. Somehow I had it in my head the rear wing spacer needed to be 6mm/.25" and that is what I put on there. The plane flew fine, it took more tuning than I am accustomed to and it dragged it's butt a little.
I read James' posts earlier today while chatting with Nathan and I went hey that spacer should be 6mm not 3. Nate says no, you had settled on 3mm....HHMMMM
I pop the 6mm spacer off and replace it with a 3mm. I can now have my stab almost perfectly flat across the top and I gained 15-20' in launch. The plane is much faster on launch, will seriously move across the sky and will slow way down without stalling. On top of all that I am not dragon azz anynore.
James I will take a look at her later and post some camber settings and where my CG is so you can at least have a base line.
This plane is what I have dreamed of building for years. I may just take this one to a whole new level.
Seperate subject but realated to the FireFly;
There have been some occasions when I ended up with flat spots on the leading edges of my wings and tails. All this time I presumed it was my lack of skill. Here lately it has been happening a great deal. I have thrown out three wings this week.
The flat spots may or may not show up, when and where they show up is completely random.
The last one that went bad I had really taken my time on. I even used a magifier light to work on the leading edge. I had much more glass on the leading edge than needed and I still got a nasty flat spot.
Yesterday I decided to do some experiments. I cut a wing core with the intention of sealing the leading edge with foam safe CA or epoxy. It soaked up the foam safe like a sponge and formed a really nice leading edge.....except for a 6" section that swelled a lot. I tried sanding it back down but that was a no go.
Nathan and I were on the phone very late kicking around ideas on how to resolve this. It would be easy to just go back to standard blue or pink foam but that would be admitting defeat. I really like all the atributes of the white foam. It bonds to the skins really well and is super hard in thickness direction.
lying in bed I had an idea.....make the leading edge out of 60psi foam. This morning I ran to the shop and I found an old piece of HiLoad 60. I had just enough to try something. I blocked out a wing but left it so I could add 1" of HL-60 to the lading edge. What a pain in so many ways but what a beautiful wing. The HL-60 sand differently so I could get one of the nicest leading edges I have seen.
It is cooking right now and I cannot wait to open the mylars in the morning. If this works like I believe it will this will be the finest bagged wing I have ever done and the way the FireFly wings are done in the future.
Luap.....What a week !!!
Mini-Review HD Wing Cam - A 120° light weight 1280x720p cam Dreamcatcher Aerial Photography 11 Oct 17, 2012 05:00 AM
Discussion Lights go dim on yet another Obama energy project P-51C Life, The Universe, and Politics 31 Jul 06, 2012 01:52 PM
Sold Light weight alloy spinners ArtJ Aircraft - General - Miscellaneous (FS/W) 2 Apr 13, 2012 07:01 AM
Sold Spinners...light weight alloy ArtJ Aircraft - General - Miscellaneous (FS/W) 0 Mar 25, 2012 05:31 PM
Found 30 inch light weight V hull for project LarryFlew Boats (FS/W) 3 Jul 22, 2008 11:25 AM
