Joined Dec 2007
![]() The only issue with stabs in that position is damage - with one hand physics gives, with the other it takes away......you'd think it'd be more generous being a fundamental concept in a position of responsibility....darn universal laws
Joined Dec 2007
In general (if that's actually possible to say ) for my 1.5m to 2m thermal glider designs using variable camber/flaps:T tail - mostly lamina, good predictability for design, easy to trim High mount X tail (>2/3) - similar to T above Boom/Standard tail (~inline with wing) - Unpredictable design and difficult to trim Low mount - worse than X but better than Boom/Standard And then you have the practicalities of design - which are usually best when your efficiency is worst (e.g. T-tails add weight, low mounts get damaged etc.)....you can't win
Joined Dec 2007
Nope, just 3 servos ended up going in. During the preliminary parts shuffle I wanted to account for adding a rudder if needed, BUT SO NOT NEEDED!!
I'll shoot a few pics of my final set-up later..... if I remember The HS-35 servos need to come out. They are analog and the center hold on the ailerons is just not quite good enough. Great little elevator or rudder servos though! I have a pair of JR 290g that are going in there this week. |
Thanks Gerald, good advise.
In my case it's the fact that analog servos "rest" at center when they are not loaded. Due to that, when the ailerons try to flutter the servo is one step behind trying to re-center. Digitals "actively" hold their center position and have a much faster reaction time to outside forces. I tried the HS-35 to see what I could get away with... guess I found the lower limit The HS-5035 digitals would probably suit this plane well, since the ailerons are only 20%ish of the wing cord, but I'm going big because I have them in stock.Analog HS-35s work fine on our spring-string set-up because the servo is constantly holding against the spring, which eliminates the "resting lag". Also we are doing the elevator below the boom so the spring doesn't need to be quite as stiff, between that and and a short servo horn, 12oz-in of torque is plenty to do the job well. |
Joined Dec 2007
Left for work late today so started the next part of the build.
I pretty much followed Paul's FF blog. The only real thing I did differently was inject the hard points for the stab under the skin - I still couldn't find my epoxy syringe, so I whacked together a replacement with disposable 'drinking straw' tips (see pic) - simple and worked better than the purpose made job I've lost. Guess I'll keep a bunch of straws around now! I'm using 60min epoxy which allows me to heat it to get it thin (or rather heat the wing a little before application!). In the 1hr I had I managed to: 1. finish the 2nd fix on the wing join with the GF strip 2. Mark, drill, excavate and inject the hard points for the tail. I did write a bit more detail about today's efforts whilst at work, but for some reason RCG is blocked on my work tablet but my own website apparently isn't and as I'm in the middle of updating it and happen to have a gallery app in progress...... I did a more detailed temporary build log there instead (that'll teach them!):Detailed build log for my FireFly DLG Right I'm off to bed!
Joined Dec 2007
![]() If you do try the trick, don't get the knife too hot, it takes less heat than you think and hold it flat against the straw or you just melt straight through like...well...a knife through a melting straw ![]() Oh and the real genius thing (and where it beats the epoxy syringe hands down)_ is that you can cut the right size of hole in the end for the job, just snip less or more off. |
| Thread Tools | |
| Mini-Review HD Wing Cam - A 120° light weight 1280x720p cam | Dreamcatcher | Aerial Photography | 11 | Oct 17, 2012 05:00 AM |
| Discussion Lights go dim on yet another Obama energy project | P-51C | Life, The Universe, and Politics | 31 | Jul 06, 2012 01:52 PM |
| Sold Light weight alloy spinners | ArtJ | Aircraft - General - Miscellaneous (FS/W) | 2 | Apr 13, 2012 07:01 AM |
| Sold Spinners...light weight alloy | ArtJ | Aircraft - General - Miscellaneous (FS/W) | 0 | Mar 25, 2012 05:31 PM |
| Found 30 inch light weight V hull for project | LarryFlew | Boats (FS/W) | 3 | Jul 22, 2008 11:25 AM |
