Jul 10, 2012, 06:47 PM
The Netherlands, UT, Soest
Joined Feb 2012
Originally Posted by MankySteve
Thats not what the Op was asking. That's the servo signal cable.
well, no he's talking about the motor/esc wires... but he's wrong..
Originally Posted by toymasta
If you look down at the ESC, the wires, from left to right, Signal (usually with a yellow shrink tube on it), Postive Power (red shrink tube), and then Negative power (black shrink tube).
short lesson on three phase motors..
three phase motors do not have dedicated negatives.
all three wires are positive to a (set of) wire winding(s).(poles)
each wire of these windings is connected on one side to esc and the other side to either:
all three wires are connected to eachother (star configuration)
or the end of one pole is connected to the esc wire of the other pole (delta configuration)
changing 2 wires makes the polarization work the other way around.
(trying to keep it simple)
