Old Aug 02, 2012, 10:11 AM
RCFlightman is offline
Find More Posts by RCFlightman
Joined May 2012
Ah, thank you. cfircav8r acctually knows what he is talkinga bout!
RCFlightman is offline Find More Posts by RCFlightman
Old Aug 02, 2012, 06:18 PM
seeingeyegod is offline
Find More Posts by seeingeyegod
seeingeyegod's Avatar
United States, OR, Portland
Originally Posted by cfircav8r View Post
Definitely not a stall. I have seen that exact thing while instructing in full scale. you are coming in to land get hit with a small gust or just pitch up too fast and the plane balloons. The common, yet wrong, action is to release back pressure and the plane dives back down too quick to react to. The correct action is to maintain the stick position and even add a little throttle if it seems a little slow. This will slow the descent and allow you to stabilize the approach. The instant you relax that back pressure it will dive, when you maintain the pressure it will still start to drop the nose and start a rapid descent but it will be a more controlled descent and you will still have some airspeed to play with. If you are too near your stall speed you have to either go around or use throttle, not the elevator, to slow your descent.
Unless the reason you ballooned is that you gave it too much gas to cushion your decent, in which case giving it more will just make it climb more, and pushing down will just make you float on.... just freaking go around again.
seeingeyegod is offline Find More Posts by seeingeyegod
Old Sep 15, 2012, 09:00 PM
hobbiconexstar is offline
Find More Posts by hobbiconexstar
SMASH AND DASH :)
hobbiconexstar's Avatar
United States, ME, Bangor
Joined Feb 2011
Did you check to see if the wheel pants caught up the wheel? I know that has happened to some people that I know.
hobbiconexstar is offline Find More Posts by hobbiconexstar
Old Sep 16, 2012, 09:27 AM
Fox-composites is offline
Find More Posts by Fox-composites
Thailand
Joined Aug 2010
You can fix that. I have repaired much worse.
The undercarriages are usually held on badly and pull back during a bad landing. This rips the woodwork out making the damage much worse.
2 months ago my friend broke what looks like exactly the same model.
The fuselage was much worse than that.
I repaired it all and inserted 2 10mm x 12mm fibreglass rails from the nose back and screwed the undercarriage to those. Now the load is taken over a wide area as the rails were 10 inches long.
He has really bounced it and even landed into a ploughed field, the u/c stayed on.
The cg was slightly rearward and moving it forwards by just a small amount made landings much easier.
Jim
Fox-composites is offline Find More Posts by Fox-composites
Discussion A very bad day, check out my face! Video... wac Hoverfly Technologies 12 May 17, 2012 07:46 PM
Discussion Very Bad experience with Xheli (short and long) N8LBV XHeli 26 May 08, 2012 12:22 PM
Careful! Very poor and bad Service from Castle Creation - my case !! marknopfler Castle Creations 5 Mar 17, 2012 01:25 AM
Careful! Very bad crash (because of blade snaping in air) Speed Stick 3D Mini Helis 59 Apr 11, 2007 07:49 PM
Discussion Very Bad Crash.................. Speed Stick 3D Electric Plane Talk 29 Mar 23, 2006 06:30 PM
