This thread is privately moderated by jlk69, who may elect to delete unwanted replies.
Old Jul 09, 2012, 11:18 PM
jlk69 is offline
Find More Posts by jlk69
RC Aircraft Junkie
jlk69's Avatar
USA, CA, Chula Vista
Joined Sep 2004
mCP X
Here are a couple of pictures of my mCP X Rx. While soldering the signal wire for the ESC to the motor fet I think I got the fet just to right too hot and now I can't bind Rx with Tx. After plugging in battery I do not get the slow blink of the blue light but only a fast blink. Hold the boat, got it to bind with another battery but looks like the motor was bad all along. However I will do more tests and report back my findings.
jlk69 is offline Find More Posts by jlk69
Old Jul 10, 2012, 02:58 PM
Daryoon is offline
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
I think you got the proper solder point on the resistor for your V1 board. Make sure it's not touching the leg of the FET. And that little capacitor to the right makes me a bit nervous.
Happy that your RX is still good though.
Daryoon is offline Find More Posts by Daryoon
Old Jul 13, 2012, 06:05 PM
jlk69 is offline
RC Aircraft Junkie
jlk69's Avatar
Joined Sep 2004
mcpx
I messed up my v1 3in1 trying to solder on signal wire to motor fet for BL conversion.
Old Jul 13, 2012, 06:43 PM
Daryoon is offline
Team WarpSquad
Daryoon's Avatar
Joined Dec 2010
Care to elaborate? What's wrong?
Old Jul 15, 2012, 12:52 PM
jlk69 is offline
RC Aircraft Junkie
jlk69's Avatar
Joined Sep 2004
The signal wire came off a few times (should have sealed it with silicon) and when trying to solder it back on the fet must have got too hot and came off. Now when throttle is applied nothing happens. When I first got the signal wire soldered on I checked and got the motor to spool up. (BTW I attached tail motor to main motor connector to double check but no luck) Is there another way to get a signal for a ESC? Is this the same fet that blows when you have a motor problem? I have heard of people saying that they want a 3in1 with a blown motor fet to use for a BL conversion.
Old Jul 15, 2012, 04:52 PM
Daryoon is offline
Team WarpSquad
Daryoon's Avatar
Joined Dec 2010
With brushless, you don't need the FET. Cuz you just need the signal. The Brushless ESC has the FETs that is responsible for controlling power to the motor.
However, of that FET you burned up is for the tail, and you are running regular brushed tail. Then you need to fix the problem.
New FETs are easy to get and replace. You can even use the main motor FET for the tail motor. The thing that worries me is that you say the tail motor connected to the main still didn't work.
Perhaps you want to let me have a looksee at your mCPX.
Old Jul 15, 2012, 08:06 PM
jlk69 is offline
RC Aircraft Junkie
jlk69's Avatar
Joined Sep 2004
I can sure do that as I just bought another v1 3in1 on eBay for $48. The tail motor runs fine when plugged into the tail plug. I tried plugging it into the main motor plug for trouble shooting purposes. (Previously had tail plugged into main motor plug when I was trouble shooting the ESC/main motor and tail ran just fine.) I am going to use the plug'n'play Oversky 10A ESC and CO5 motor with the 3in1 I bought on eBay. Hopefully you might be able to breath some life into the 3in1 that I messed up. If so I might buy Evan's HP05S and build another more powerful duel BL mcpX. (P.S. Where do you solder the signal wire to if the fet is gone?)
Old Jul 15, 2012, 08:28 PM
Daryoon is offline
Team WarpSquad
Daryoon's Avatar
Joined Dec 2010
I don't think you need the FET to be working to get the signal you need. The signal is intercepted before it goes into the FET. It's probably the resistor that you soldered to that is bad, and thus no signal.
Old Jul 15, 2012, 08:48 PM
jlk69 is offline
RC Aircraft Junkie
jlk69's Avatar
Joined Sep 2004
Ok, I thought that was the fet. How hard is it to replace that resistor?
For Sale Double brushless mCP-X and mSR-X Part out. NIB 3-in-1. Tons of stuff... c3hutson Aircraft - Electric - Helis (FS/W) 6 Jul 10, 2012 11:24 AM
Mini-Review MicroHeli Advanced X Frame mCP X SYMAWD Micro Helis 3 May 17, 2012 11:05 PM
Sold MicroHeli Advanced X Frame and X Swashplate mCP X SYMAWD Aircraft - Electric - Helis (FS/W) 3 May 14, 2012 07:39 PM
Discussion MCP-X thread for people that dont have a MCP-x axelen Micro Helis 186 Apr 01, 2011 01:17 AM
