Joined Oct 2012
How about these
I think these look like a winner. They are the right size for the servo tray, and it say " super strong!".
http://www.hobbyking.com/hobbyking/s...3sec_7_1g.html |
I found these very small, MG servos with about the same power as the 9G servos. I ordered a few to try but have not put them in a plane yet. Check the sizes, they are very small.
http://www.valuehobby.com/power-hd-d...cro-servo.html |
Joined Apr 2012
Hi, Ed. I'm with Spiker.
A heli motor would likely have too high a KV. The KDA 22-20L I'm using has a KV of 1000 and uses around 21Amps and 235watts with a 10X6 prop. This will provide a vertical climb to height in around 10 seconds and I can shave off a couple seconds with an 11X6 prop. My motor, at 85grams, is pretty much the upper limit without having to move everything, including the battery, back towards the tail. |
Joined Apr 2012
I had a really interesting flight yesterday afternoon. It was dark and overcast but I decided to fly the Specter so I could give an inexperienced friend some stick time. I discovered that there was slope lift coming out of a gully and deflected by a line of trees so, essentially, I did my first dynamic soaring. Once I found the sweet spot I was able to stay up indefinitely by just flying an egg-shaped pattern with the narrow end in the lift. Very, very, fun!
Joined Oct 2012
Motor
Cool peter, that's what I'm looking forward to.- I got the stock motor that was recommended with the kit. The Turnigy 480s inrunner. It has a 4mm shaft. I have seen some 32mm spinners with 4mm shaft on a UK hobby sites that I may order. In other bad news, the OrangeRx reciever that I ordered will not bind with my Walkera radio, but I can use the RX out of my heli. I'm going to end up with alot of miss matched parts laying around.
http://www.hobbyking.com/hobbyking/s...idProduct=9377 |
Joined Apr 2012
Ideas for balancing.
Hi, Ed.
With that motor, which I'm surprised fits, you will have to mount everything else as far back as possible for balancing. Regardless of which servos you end up using I think you will have to scrap the servo tray and mount said servos, whether upright or on their sides, towards the back of the area under the wing. Same with the Rx and ESC. You still might have to add a few grams in the tail. Here's the good news. The Specter can handle a little extra weight and it's not terribly sensitive to CG so it won't be an insurmountable problem. |
Hi guys, another new Specter pilot joining in. I ordered mine from HK USA last Monday, so hopefully won't have to wait too much longer.
I fly a bit of everything....sport, EDF, Siren Hotliner, and even my old GP Spirit glider (sinks like feather with a brick tied under it). I read this thread here and you guys really got my itch going for getting back into some gliding activities. I'm a bit burned out with the other stuff right now...except for the Siren. I still need to choose the motor I am going to run and which servos to use. I have a pretty good stockpile of motors, esc's, and servos here, so hopefully something will work. Just to be sure...I think I remember somebody saying this was a copy of a Passer X? Is it? Is it a copy, or just rebranded for HK? I just haven't seen much info on this plane and would like to figure everything out about it. I am sure excited about joining in here. I started with gliders way back in the mid 70's with Gentle Ladies, Wanderer's, Square Soars, HOB 2x6/2x4's, etc. Been dormant for 15-20yrs or so except for the Siren. The Spirit just sucked so never really took it out. I'll be standing by the door waiting for now................... Ken |
Joined Apr 2012
Welcome to the club, CSI.
I'm pretty sure that the Specter is a copy because the tail surfaces, wing hold down, and servo tray are a bit different than the Passer-X. I always return to sailplanes myself. I can only fly powered airplanes for so long before I hit a wall and get bored. Chasing lift, on the other hand, always seems to be fully absorbing. I had dropped all flying for several years due to moving away from my old flying spot and some health issues but with modern electric power systems I can fly at a nearby park so I really don't foresee giving the hobby up again. Plus, with all the inexpensive stuff available, I should be able to maintain a fleet that will always keep things interesting. An exact fit for the spinner is 32mm. |
| Thread Tools | |
| For Sale Specter ARF airplane with complete video system installed - $500 | IBCrazy | FPV/RPV - Equipment and Vehicles (FS/W) | 11 | Nov 03, 2012 09:08 PM |
| Sold 2 skylipo 3s 1800, 1 twenty 3s 1800 | crashnburn69 | Aircraft - Electric - Batteries & Chargers (FS/W) | 3 | May 26, 2012 06:43 PM |
| Yippee! First flight w/ hk 1800 icon a5 and go pro | HARD LANDINGS | Waterplanes | 3 | Sep 29, 2011 06:34 PM |
| Wanted HK Turnigy Nanotech 3S 1800-2200 Lipos | lafuerza | Aircraft - Electric - Batteries & Chargers (FS/W) | 0 | Nov 13, 2010 09:54 AM |
| Discussion Specter became a Specter | LcJ | Life, The Universe, and Politics | 7 | May 19, 2010 02:34 PM |
