Old Jul 09, 2012, 04:37 PM
BVH is offline
BVH
Find More Posts by BVH
BVH
BVH's Avatar
United States, CA, Pismo Beach
Joined Dec 2006
Question
PL8 as a Voltage booster
I run a 28V, 20A military High Intensity Discharge searchlight off of 2 Series'd, 110 AH deep cycle batteries. After a fresh charge and under load, the battery voltage is steady at around 24.4. This light is not regulated in that the higher the input voltage (up to 28.5), the more light is produced - as much as a 70% increase at 27.4V vs 23.5V) Could I use the 24V PB preset at a 30 Amp charge rate to concurrently "charge" the "pack" while running the light to provide a Voltage boost without damaging the charger?
edit: Yes, I can. However, since I'm using the Iota 12V/55A PS, the charger will output only about 15 Amps due to PS low Voltage at 14.5V so charging Voltage reaches only 25.5V.
BVH is offline Find More Posts by BVH
Old Jul 09, 2012, 11:46 PM
Tim Marks is offline
Find More Posts by Tim Marks
President, FMA, Inc.
Tim Marks's Avatar
Joined Mar 2008
Hi:
You'll likely need to actually connect a Pb battery to the charger and connect the light across the Pb. The PL will charge the battery while the light discharges it. You'll want to set the charge rate to essentially "zero" the current I think. You will also likely want to increase the timeout on the preset to the max I think.
Tim Marks
Tim Marks is offline Find More Posts by Tim Marks
Old Jul 10, 2012, 04:24 PM
BVH is offline
BVH
BVH
BVH's Avatar
Joined Dec 2006
I was not clear in my post but I connected just as you say - the PL8 to the PB and the light to the PB so the battery acts like a "translator". I need to pick up a 24V PS for more PL8 output though.
Discussion Low voltage level for PL8 where it won't even see cell anymore? WBFAir FMA Direct 3 Jul 01, 2012 07:24 PM
Question 1cell lipo with voltage booster or..? Wormboy Batteries and Chargers 1 May 22, 2012 02:16 PM
Discussion High voltage servos, such as Hitec's do they work with 4.8V-6V voltage? liukku Radios 9 Mar 26, 2012 12:35 PM
Question What voltage boosters are out there? boredom.is.me Scratchbuilt Indoor and Micro Models 5 Mar 07, 2012 02:51 PM
Discussion PL8, check cell voltage tesa1 FMA Direct 2 Nov 20, 2010 08:12 PM
