Espritmodel.com Heli Air
Old Jul 09, 2012, 02:39 PM
Joined Jun 2012
Using a IMAX B6 lipro balanced charger to charge a nimh pack
Hi I recently purchased a IMAX b6 charger for the lipo pack I've got on order but for now I just need a quicker charge on my nimh 7.2 v 2000mah pack rather than using the crap charger I got with it, so I turn the charger on and select battery type nimh then set the charge current then I hit select for 3 seconds and it goes to the charge screen and then almost instantly beeps and says input vol err and in the little book that means erroneous voltage selection of lithium pack and to check the voltage now for a start it's a nimh battery using the nimh program and it won't even give me the option to select any voltage?! Please somebody help I'm just no good at this stuff.
Tripsta is offline Find More Posts by Tripsta
Old Jul 09, 2012, 04:35 PM
wparsons's Avatar
Canada, ON, Markham
Joined Aug 2008
I've never had that happen with nimh packs on my B6. What charge current are you charging at?
wparsons is offline Find More Posts by wparsons
Old Jul 10, 2012, 12:49 AM
Joined Jun 2012
Well I've not been given a specific current but it's a 2000mah so it says in the book 2A for 84 min but I just get an alarm after a few seconds and it says input vol err.
Old Jul 10, 2012, 04:16 AM
traxx de maxx's Avatar
uk
Joined Nov 2010
what is being used to power the charger. Thats the input to the charger error.
traxx de maxx is offline Find More Posts by traxx de maxx
Old Jul 10, 2012, 05:04 AM
Joined Mar 2012
maybe try charging at a lower current?
jsarwar469 is offline Find More Posts by jsarwar469
Old Jul 10, 2012, 08:16 AM
Joined Jun 2012
I'm using a 12v ac/dc universal power pack and in the book it says the error means erroneous voltage of lithium pack and check pack voltage? It doesn't mention the anything about the dc input Also if I lower the charge current to 0.1 A it will charge to the time limit
Old Jul 10, 2012, 08:28 AM
uk
Joined Nov 2010
How many amps is the power pack. Try another power supply if you can. Or if you can measure the DC output voltage from the supply you have.
Old Jul 10, 2012, 11:13 AM
Joined Jun 2012
I've hooked it up to a car battery and it's fine I don't think the power pack I'm using has enough amps to support the charger
Old Jul 10, 2012, 11:52 AM
uk
Joined Nov 2010
Cool, now just a new power supply to find, If you like to work on things,
A PC Power supply mod is inexpensive alot of how to's on internet. Big and bulky.
A Playstation 3 power supply is a lot less work and also inexpensive from fleEbay. I use this one nice and small'ish
An Xbox 360 supply has been used also.Don't know how to do this one, but have seen it.
Or you could just buy a normal supply but i think they are expensive.
If you go for ps3 there is lots of power outputs. I have a list of them somewhere.
Old Jul 10, 2012, 02:27 PM
LaTuFu's Avatar
United States, VA, Bedford
Joined Oct 2011
This power supply has been out of stock for quite a while at Hobbypartz, but it is a good quality PSU for the money. It has more than enough power to supply your B6.
This one is the HobbyKing equivalent. Roughly the same price and specs.
LaTuFu is offline Find More Posts by LaTuFu
Old Jul 11, 2012, 04:15 AM
Joined Jun 2012
Thanks for the advice guys, What ampage am I looking at here? My friend has lots of power packs lying around and it's a very common fitting so hopefully hes got one with a bit more juice.
Old Jul 11, 2012, 05:28 AM
uk
Joined Nov 2010
you'll want one with at least 75Watts if they are all 12V. Running lower could over heat the supply when charging.
Discussion IMAX B6 charger 1300 Nimh bat rayman39 Batteries and Chargers 10 Jul 09, 2012 02:49 PM
Discussion Is it ok to use the IMAX b6 to charge larger capacity packs? tasso del miele Batteries and Chargers 6 May 24, 2012 12:01 AM
Discussion Balance Board for Imax B6 charger super_dork Batteries and Chargers 8 May 14, 2012 08:13 AM
Sold Charger - Imax B6-Pro balance charger - New in Box Captain3D Aircraft - Electric - Batteries & Chargers (FS/W) 0 Apr 21, 2012 06:15 PM
For Sale only $21.99, IMAX B6 Lipro Balance Charger usasteele Aircraft - Electric - Batteries & Chargers (FS/W) 2 Oct 06, 2010 06:27 AM
