Old Jul 09, 2012, 02:15 PM
Alex Schauer is offline
Find More Posts by Alex Schauer
Alex Schauer's Avatar
United States, MN, North Mankato
Joined Feb 2011
Help!
Mystery ESC Not working correctly!
I have a Mystery ESC, and I used it in my Piper Cub....and that crashed due to overcurrent. It was a cheapo motor from Leader's hobby and they said to use a 40A ESC...I should have known better
But then I tried it (on land) and it still worked fine.
The next time I tried it, it didn't.
The motor sounded different, and it cogged upon startup. But after the cogging it ran. (About a second of cogging)
BBBUUUUT....I wouldn't care about all this if It weren't for that I have about half power. I put it back in my EPP slick and I couldn't even hover!
I thought, hmm well maybe I forgot to charge this battery....
I tried all of my batteries and they proved innocent. Even took a voltmeter to them.
I think this ESC might be toast...but I'm low on funds, so can you guys please try to help?
Thanks!
Alex Schauer is offline Find More Posts by Alex Schauer
Old Jul 09, 2012, 02:36 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
What's the ESC's current rating, and how much current was the Cub's motor actually drawing? LH might have suggested a 40A ESC for the motor, but that doesn't tell us anything about how much it was actually drawing.
And we REALLY don't know anything without knowing the ESC's rating.
It sounds like the ESC is on its way out, though. ESC failure symptoms can have a whole lot of variations, but generally if the ESC isn't working properly then it's probably dying or dead.
Piece is offline Find More Posts by Piece
Old Jul 09, 2012, 03:48 PM
Joined Feb 2011
It was a 40A esc, and I don't know what the motor pulled.
Should I just toss it?
Old Jul 09, 2012, 05:14 PM
Martyn McKinney is offline
Find More Posts by Martyn McKinney
Toronto Canada
Joined Dec 2002
Have you calibrated the endpoint on your ESC?
Martyn McKinney is offline Find More Posts by Martyn McKinney
Joined Feb 2011
Yep
Old Jul 09, 2012, 05:31 PM
Piece is offline
Piece's Avatar
Joined Aug 2009
Ok then, do you have a link to the motor? Also, what prop were you running, and what battery? The more specific info you can give, the better.
Do you have a wattmeter?
Old Jul 09, 2012, 08:41 PM
Joined Feb 2011
No wattmeter....Yes I know...I should get one.
I was running an 11x5.5E APC
Zippy 2200 3S 35C
3 Standard servos
https://www.leaderhobby.com/product....=9394001224126
Help! Trying to calibrate ESCs - not working DaMaDo Multirotor Talk 20 Jun 07, 2012 07:03 PM
Discussion ESC does not emit any beeps anymore, but works. tlh101 Power Systems 1 May 02, 2012 10:12 PM
Discussion Help, motor not responding to tx, ESC/receiver may not be connected correctly jmccollough Beginner Training Area (Aircraft-Electric) 15 Mar 28, 2007 01:11 PM
Question 8UAFs - "Link" function not working correctly in PMIX Andy W Electric Plane Talk 14 Aug 05, 2004 07:32 PM
MicRotex and CC10 not working correctly akeyzoo Power Systems 127 Apr 26, 2004 05:25 PM
