This thread is privately moderated by SkyCadet, who may elect to delete unwanted replies.
Old Jul 09, 2012, 10:11 AM
SkyCadet is offline
Find More Posts by SkyCadet
Segelfliegen bedeutet Freiheit
SkyCadet's Avatar
Canada, MB, Winnipeg
Joined May 2010
Windsock installation at Brookside field...
Well, we finally did it! A windsock.
I've been meaning for the past year to put up a decent windsock at the park/field we do most of our casual flying. When HK (Hobby King) finally got in their new inventory of very affordable windsocks, I ordered 3 of them. They had been backordered for months!
They are quite nice: The sock is a decent size, with a 10" opening, on a 12" aluminum 3/8" tube, with about a 30" length. Only $2.99/ea. We used a 1/2" SS pipe (surplus) that was ~32" long, sandwiched between two hardwood blocks with a "U" clamp on a backstop pole to mount the unit ~22 feet up. It was tricky using the 18' ladder to attach the pole, but we did it!
I used a 5/16 washer with a piece of plastic coat hanger inserted into the sock's tube (using graphite epoxy to adhere it) to extend the sock about 9". It slipped into the pipe perfectly!
We had a hoot with several folks flying after we installed the sock. It was great to have some local help, and the kids can use this to determine whether the wind is enough for kite flying! The sock's stripes are about 2 km/h (or 1mph) per stripe, so when fully inflated, the wind is pretty much 10-12 km/h (or higher). Good to know in that field! The nearby church has a large flag that we used to use, but it did not always indicate wind well. This is WAYYY better!
See pics below...
Sky Cadet
SkyCadet is offline Find More Posts by SkyCadet
Old Jul 09, 2012, 11:32 AM
seojeff is offline
Find More Posts by seojeff
seojeff's Avatar
United States, GA, Atlanta
Joined Aug 2011
I just replaced mine at our local field. It lasted about 10 months in the Georgia sun. Not bad for $3.
seojeff is offline Find More Posts by seojeff
Old Jul 10, 2012, 04:10 PM
SkyCadet is offline
SkyCadet's Avatar
Joined May 2010
re: windsock...
That's not bad!
Yeah, it's a nice offering, and highly affordable. How did it hold up against WIND?
Darren/SkyCadet
Latest blog entry: New plane - Evader!!!
Old Jul 10, 2012, 09:40 PM
seojeff is offline
seojeff's Avatar
Joined Aug 2011
Originally Posted by SkyCadet View Post
That's not bad!
Darren/SkyCadet
Wind didn't seem to be a problem. The fabric simply deteriorated from sun exposure.
Old Jul 11, 2012, 12:18 PM
SkyCadet is offline
SkyCadet's Avatar
Joined May 2010
I figured so. Thanks.
Did you guys there ever figure out the striping vs wind speed of the sock? it looks to be around 1mph/stripe or so as far as I can tell...
Have a great day!
Darren/SkyCadet
Old Jul 16, 2012, 11:42 AM
seojeff is offline
seojeff's Avatar
Joined Aug 2011
Have a great day!
Darren/SkyCadet
Wow, I never even considered it like that. The only issue I see there is that the stiffness of the material changes over time. I wouldn't rely on that.
Old Jul 16, 2012, 04:12 PM
SkyCadet is offline
SkyCadet's Avatar
Joined May 2010
I guess youre right, Jeff!
Over time, as the material "softens" and degrades, it might be less accurate. It's good enough as a guestimate - if the things striaght out, it's probably too wind, anyway!
SC
Discussion power source at field? rcrich Batteries and Chargers 24 Jun 24, 2012 12:54 AM
Sold KOOL TIES-Help you cope with the heat at the Flying Field!!! unclegeorge Aircraft - General - Miscellaneous (FS/W) 0 Jun 22, 2012 02:16 PM
Video UMX Carbon Cub SS - low & slow in the yard, with a short-field landing at the end. turboparker Electric Plane Talk 0 Jun 16, 2012 08:22 PM
Sold KOOL TIES-Help you cope with the heat at the Flying Field!!! unclegeorge Aircraft - General - Miscellaneous (FS/W) 0 Jun 16, 2012 08:35 AM
Discussion Batteries for charging at the field or installed in a trailer Diggs Batteries and Chargers 67 Jan 17, 2009 04:09 PM
