Old Jul 09, 2012, 03:03 AM
acetech09 is offline
Find More Posts by acetech09
I think I'm inverted. Maybe.
acetech09's Avatar
United States, CA, Pacifica
Joined Apr 2012
(Nearly) Indestructible EPP Trainer
This is a side project, really - that might come to fruition in the far future - later on in the idea queue. Might resurrect this post when I get around to it.
Concept: Build something that flies like a slow stick, but as frustrating for the ground to break as a human trying to open clamshell packaging without any scissors.
How: Thick flat-bottom EPP airfoils. Coated with 10 mil laminating film. Reinforced with custom reinforcing rods to be stiff but extremely flexible. Idea is to have nothing that can shatter in the plane, even under extreme deflection. No shattering = not much breaking. Thick lamination will resist tearing.
Details: The most pressing issue is reinforcement. I don't think that 10mil laminated EPP would be flimsy by itself, but it wouldn't hold up to a crash as well. My initial thought is using some sort of spring steel wire as a reinforcement. If the wing reinforcement is very stiff, then the wing would deform, but not the rod, causing shearing and tearing on the covering, which shouldn't happen.
Weight shouldn't be a big concern - going for a very slow flyer with a high-lift airfoil. I'm shooting for the AUW to be somewhere around 1100g.
I'm debating about how to do the prop. Pusher prop is sorta out of the question, they can stall a lot easier, like an EDF. A standard configuration would be subject to abuse, even with a prop saver. Folding prop would help. Motor pod above the wings is also an option, but subject to same abuse as any others if inverted, which might happen.
Electronics will be safe and snug inside generous layers of EPP and fiberglass.
Idea seem practical? This is just the musings of a man stuck without any planes during a 2 week vacation. I was sorta inspired by this thread about a 12-year-old who kept crashing a plane every week, and feeling bad about it. Although I do believe he shouldn't take crashing as hard, if he's not to the skill level of staying aloft without damage, then he should be able to fly on a plane that if he crashes, he won't be grounded for a week while his dad fixes it.
acetech09 is offline Find More Posts by acetech09
Old Jul 09, 2012, 07:16 AM
gwillh is offline
Find More Posts by gwillh
Has gun..glues stuff
United States, Mt, Kalispell
Joined Jul 2012
Interesting design idea #1?
http://www.collectair.com/Model_Airplanes.html
The link seemed appropriate since it was what we deal with, but more importantly there is a picture of the Focke-Wulf 198 (search the page, couldn't get a decent anchor link). The fact that it was never made isn't important, the shape of it is.
Given a set of heavy duty wings run through a round body like that, with heavy control surface exceeding the outer tips of the propeller (tail fins etc, top and bottom), that might be an idea to shield it from harm, as well as the control surfaces you'd want beefed up to do it with.
Sort of like a roll cage around a prop...which on second thought, might be easier to do on any plane in a simpler, but less elegant design.
Now i'm off in my head wondering what a plane in a circular roll cage would fly like.
Will
gwillh is offline Find More Posts by gwillh
New Product Techone Nearly Indestructibly 33" EPP Me-109 Foam RC Airplane 2dogrc 2DogRC 6 Sep 08, 2014 08:33 AM
Discussion Hacker Decathlon EPP Trainer learn2turn Beginner Training Area (Aircraft-Electric) 4 Aug 02, 2012 04:42 PM
Discussion Foamy pattern trainer, EPP LRFitch 3D Foamies 1 Jun 15, 2012 12:04 PM
Sold Techone Nearly Indestructibly 33" EPP P-51 Foam RC Airplane freeplansguy Aircraft - Electric - Airplanes (FS/W) 2 Jun 13, 2011 11:35 PM
"Indestructible" (EPP?) electric trainer photographer2b Beginner Training Area (Aircraft-Electric) 22 Jan 10, 2002 01:09 PM
