Old Jul 08, 2012, 09:57 PM
Joined Jun 2012
Good scratch build trainer plane
Hey, guys I am trying to figure out what plane to build for my dad who wants to get into flying I would like to build him a plane before we spend money on getting a nicer plane. I would like a plane that will fly slow and is very predictable. If you can can you put a link or the name of the planes plans to build it. Thanks rcplaner214
rcplaner214 is offline Find More Posts by rcplaner214
Old Jul 08, 2012, 10:00 PM
It's Just Foam!!!
EZglider's Avatar
Canton,Ga
Joined Apr 2010
Hard to do better than Waterdog's STC http://www.rcgroups.com/forums/showt...&highlight=stc
Lots of folks started out with this trainer. Nice,simple build, very predictable, and flys really well.
Or, if you prefer a full-fuselage plane, the Blu-Baby from Tony65x55 is probably one of the most built designs ever.http://www.rcgroups.com/forums/showt...light=blu+babi . A true classic. If you look at the size and age of both these threads, it's obvious that they're both excellent planes. You won't go wrong with either one.
EZglider is offline Find More Posts by EZglider
Old Jul 09, 2012, 05:41 PM
Up-Out-&-Gone
demondriver's Avatar
Charelston SC U.S.A.
Joined Mar 2007
Those are great planes EZ!
RCPlanner you may also look at the Polaris!
http://www.rcgroups.com/forums/showthread.php?t=922465
demondriver is offline Find More Posts by demondriver
Latest blog entry: Joe Nall 2013!
Old Jul 09, 2012, 10:52 PM
or maybe foam
balsa or carbon's Avatar
United States, WA, Vancouver
Joined Aug 2010
This one is SUPER EASY and inexpensive to make , very stable and will fly slowly if you make it light http://www.rcgroups.com/forums/showthread.php?t=1685988
balsa or carbon is offline Find More Posts by balsa or carbon
Old Jul 10, 2012, 04:40 AM
It's Just Foam!!!
EZglider's Avatar
Canton,Ga
Joined Apr 2010
Those are both great! The OP was asking for a trainer, and when I think trainer, I think "high wing w/ some dihedral, 3 ch (RET)". That's why I went with those 2 for my suggestions.
Old Jul 10, 2012, 06:40 AM
Old age is not for sissies
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
Neither the Polaris or Easy Fly are trainers. EZglider's choices would be much better. Also check out the EZFly, a great trainer I use as my night flyer. http://www.rcgroups.com/forums/showt...ghlight=ez+fly
Azarr
Azarr is offline Find More Posts by Azarr
Old Jul 10, 2012, 09:37 AM
or maybe foam
Joined Aug 2010
The one I suggested IS high wing , dihedral , 3 ch RET .
Old Jul 10, 2012, 09:48 AM
Azarr's Avatar
Joined Jan 2000
It flys well, but in my experience a delta type planform is difficult for a true beginner to keep orientation. I would think point your design towards you and orientation for a beginner would become difficult.
I may have to build one though
Azarr
Old Jul 10, 2012, 12:32 PM
or maybe foam
Joined Aug 2010
Azarr
You should definitely build one ! It's absolutely the quickest , easiest build I've had so far - and also the easiest to fly ( just think of how nicely the paper airplane the design is based on glides ). Orientation isn't really a problem ( when properly balanced and trimmed - like any plane ) because it's self-righting - just let go of the right stick and ease back on the throttle a little . And even if a total beginner were to crash it , chances are just the nose would be mushed - easy to fix , or cut off and replace .
Discussion Micro Plane Foamies Scratch builds? AssassinXCV Foamies (Scratchbuilt) 21 Jun 30, 2012 11:17 AM
Discussion Good Kit Build for 2nd/3rd Plane HillRf Fuel Plane Talk 13 Jun 28, 2012 03:48 PM
Help! are twisted hobbies planes good 3d trainers? RCAddict16 3D Foamies 9 May 29, 2012 08:17 PM
Question whats a good first scratch built faom plane build airpower Micro RTF 2 Jan 13, 2008 09:15 PM
