This thread is privately moderated by nakelp86, who may elect to delete unwanted replies.
Old Jul 08, 2012, 03:01 PM
nakelp86 is online now
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
EZ*, Bixler, SkySurfer POWER, ELECTRONICS
Decided to start this for all interested, Please feel free to add your set up details and
only dry facts here, PLEASE.
This is to be tailored as this thread: http://www.rcgroups.com/forums/showthread.php?t=1494373
My current EZ* set up:
Total weight 38oz.
Motor Turnigy B2835 -2200Kv
Prop APC 6x5
ESC - CC 35 Amp
Servos - Tower Hobbies (blue) 9g
Flight Battery : 3S 2200 Mah
RC RX - Micro JR R610M 72MHz
FPV set up:
VTX - 2.4Ghz (Black Widow) 5V
Cam: Fatshark RC922CAM 5V
Antenna: Inverted V
OSD - Remzibi with heat sink mod.
UBEC - DPCAV 5V regulator
Vid Bat. 2S 800Mah
nakelp86 is online now Find More Posts by nakelp86
Old Jul 12, 2012, 08:38 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
nakelp86, you know you list a 2200kv motor but show the 2700kv version, right?
In my EZ*.
Motor: E-Flite Six Series 2000kv inrunner.http://www.horizonhobby.com/products...28mm--EFLM2000
Prop: APC 6x4e
AMPS: draws 19amps WOT static
ESC: 30amp generic. (Mystery).
Servos: Hitech &*&%$ forgot the number....
RX: Corona RP6D1 Synthesized Full Range DSP Receiver, 72mhz http://www.bphobbies.com/view.asp?id...5&pid=E0835795
Gyro: E-sky 704 for elevator only.
Battery: Hobbyking 2200mAh 3 cell.
Mounted the motor with Goop, plumbers type..http://www.eclecticproducts.com/plumbing.htm
Servos held in with hot glue.
RX and battery held with velco glued down with hot glue.
ESC mounted outside . Foam recessed with dremel and held with hot glue. ESC to battery leads extended with 14 gauge silicone wire.
Nose and underside of fuse done with red gorilla tape for those less then perfect landings.
Other red accents done with Econocote cut out.
Fuse glued with Plumbers Goop, tail with medium CA.( Mercury brand)
Rudder enlarged to size of elevator with balsa and use CA hinges.
Flys like a dream and can carry quite a bit of weight as in a camera or a full FPV set up.
Gene
2500GENE is offline Find More Posts by 2500GENE
Old Jul 13, 2012, 08:40 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
My Skysurfer Version 2 setup:
Motor: Stock SS brushless 2620-1950kv 17A burst outrunner
ESC: Stock SS WK-WST-20A, 40A burst
Prop: APC 6x4E
Servos: Stock SS J-Power JE0203
Battery: Turnigy nano-tech 3S 2200 mAh 25-50C
Rx: Orange R610 DSM2 6ch 2.4Ghz
ESC- Battery connection: Deans Style T connecter
Modifications:
Deans T to XT60 adapter for 2200 nano tech battery.
Motor mount: PVC pipe fitting for easy motor swap.
Air cooled with scoop in front and opening behind prop
Magnets to hold wings together
4mm carbon spar glued inside 6mm carbon spar
CG is now at 70mm
# 16 808 cam holder on nose with safety strap
Rudder is mounted on with screw and nut
Canopy is attached to fuse with fish line
Extra glue and tape on nose to repair hard landings impacts.
Spare parts:
RC Timer BC-2826/6 2200kv outrunner
EMP B2835 kv2200 brushless inrunner
Firepower 370 Zoom 2826-19 outrunner
Hobbywing Pentium 30A ESC
4 SG90 Micro 9g Servos (Hitec HS-55)
a couple of 6x4E and 5x3 props and mounting hardware
Full set of SS body parts and control rods
I'm sure I have missed something but I can add if someone jogs my memory.
Vince
Here are a few pix. I have to get one of the full plane after my mods but I have one before.
Eagle202 is offline Find More Posts by Eagle202
Old Jul 14, 2012, 06:33 AM
Martin7182 is offline
Find More Posts by Martin7182
Wallop!
Martin7182's Avatar
Bussum, Netherlands
Joined Oct 2009
EZ* setup
Motors: RCTimer BC2826-6 2200kv outrunner (50g), RCTimer 1600kv outrunner (37g), Hyperion 3900kv inrunner (HP-X22L-3900, 77g)
ESC: Turnigy Plush 30A continuous, 40A burst
Props: 6x4E, 5x5E, stock 5x4
Servos: Stock Multiplex 9g servos
Batteries: Stock 6-cell 1400mAh Nimh, 2S 2200mAh lipo, 2S 2600mAh lipo, 3S 1800mAh lipo
Rx: basic 35Mhz long range receiver
Mods: EPS canopy with camera and two LED head lights, ditto without the lights.
Motor mounts are not glued, they just slide in. So motors are "hot swappable" .
Flyable configurations:
- RCTimer 2200kv outrunner / 6x4E / 6c 1400mAh, 2S 2200mAh, 2S 2600mAh, 3S 1800mAh
- RCTimer 1600kv outrunner / 5x5E / 6c 1400mAh, 2S 2200mAh, 2S 2600mAh, 3S 1800mAh
- Hyperion 3900kv inrunner / stock 5x4 / 2S 2200mAh, 2S 2600mAh
Martin7182 is offline Find More Posts by Martin7182
Old Jul 15, 2012, 06:30 AM
Verid is offline
Find More Posts by Verid
Joined Jan 2009
Motor RAY B2835/16 -2200Kv
Prop Aeronaut Black 6,5x4
ESC - Emax 30 Amp
Servos -Emax ES08A or TowerPro SG91R for ailerons and Hitec HS-81 for stabs
Flight Battery : 3S 3000 mAh
RC RX - Cyberdrones eLeReS 433MHz
FPV set up:
VTX - 1,2Ghz (Lawmate 500mW)
Cam: 600TVL Sony w/OSD + JVC GC-FM1 Picsio
Antenna: Stock
OSD - Remzibi
Vid Bat. - single battery system
Verid is offline Find More Posts by Verid
Old Aug 05, 2012, 08:23 PM
Karl Bē is offline
Find More Posts by Karl Bē
29 rods from you in western WI
Karl Bē's Avatar
Joined Jan 2003
Easystar/GoPro setup:
Graupner CAM slim prop 6x3 (noisy APC 5.5x4.5 prop pictured)
CC Phoenix 25a ESC
3s 2500mAh lipo at CG, two large framing nails in tail to balance camera
ESC notched into upper fuse:
Brushless outrunner inside original pod:
1/16" fiberglass motor mount is embedded between fuse halves:
GoPro on custom mount attached to ply "instrument panel"; nose is not in view in R3 or R5:
Karl Bē is offline Find More Posts by Karl Bē
Old Aug 13, 2012, 10:58 AM
rockom is offline
Find More Posts by rockom
rockom's Avatar
United States, IL, Genoa
Joined Jan 2004
Easy Star II Setup
Motor: Value Hobby E400 1200kv (perfect fit)
http://www.valuehobby.com/gforce-e400-2830-1200kv.html
Battery: GForce 3s 2200mAh
ESC: Castle Phoenix 25
BEC: Castle 10A
Servos: (4) Hitec HS-55's
Rx: Spektrum AR600
Prop: Stock
150W
12.5A @ full throttle.
-Rocko
rockom is offline Find More Posts by rockom
Old Aug 13, 2012, 10:16 PM
Mehari is offline
Find More Posts by Mehari
Joined Aug 2008
Another EasyStar II
Motor: NTM PropDrive 28-26 1200kv mounted inboard
ESC: Turnigy Plush 30A mounted in tower
Battery: Turnigy 3S/2200mAh 20-30C
Servos: 4xMultiplex Nano-S (aileron leads don't need extending)
Prop: Stock 7x5 folding
Max power 140W @ 11.4A (enough to climb at about 30 degrees)
Mods: 3M Scotch Extreme tape along fuselage belly
4mm carbon fibre tube reinforcing to horizontal stabiliser
Mehari is offline Find More Posts by Mehari
Old Sep 21, 2012, 02:15 PM
Nakelp
nakelp86's Avatar
Joined Sep 2004
EXTREME disappointment with this motor : Firepower 400 Sport (2830-11) from HeadsupRC and APC 8x4 prop the motor is way, way to weak for my 48oz Sky Surfer and totally unbalanced :-(, I say impossible to balance.
With this APC 8x4 recommended prop it wont even move the plane an inch on the grass. Totally overrated power on this one.
One thing I have to say the service of the store is top notch.
Old Sep 24, 2012, 09:50 PM
Nakelp
nakelp86's Avatar
Joined Sep 2004
My new SS II:
weight RTF 48oz.
Motor RC Timer BC-2826/10 1400KV max power est. 200W +
Will be probably replaced with this one :
MicroDAN 2505 "Custom" 2535Kv
Prop RC Timer 7x4 E ( need to be well balanced) will probably replace with APC 7x4 for MicroDan.
ESC Turnigy 40Amp
CC BEC 10Amp
Battery: 3s 2200 Turnigy or Zippy
Rudder and elev servo - Hitec ( dont remember which one LOL)
ailerons servo Blue 9 gram
FPV set up:
UHF DL RC Tx
DOSD ( GPS imbedded in the tail) with 5 turn wires on ferrite.
RMRC 300mW 1.3 Ghz VTx
RMRC 1.3Ghz VRx
FPV camera : Range Video KX 171 G2
Video Battery: Turnigy 2S 1000Mah
Inverted V antenna.
Main mods:
custom FPV and GoPro camera base.
Servos moved under the motor
CF rods imbedded in original servo wire groves extended to the front
Foam skid covered with plastic from milk jug :-)
Fuse is spot glued (just in case I need to open it)
Wings detachable with custom joint (pretty much my standard for 2pc wind)
described in the blog.
Discussion My ideas for Skysurfer/Bixler FPV setup Rogue.insight FPV Talk 5 Jul 04, 2012 01:00 PM
For Sale SkySurfer or Bixler stock engine Maddmax FPV Equipment (FS/W) 0 Apr 12, 2012 10:25 AM
Discussion HK Bixler RTF vs ReadyMadeRC SkySurfer RTF fpvwannabe Foamies (Kits) 8 Jan 28, 2012 06:45 PM
Poll SKYSURFER/BIXLER mods only thread! Lafayette Foamies (Kits) 0 Jan 27, 2012 03:25 AM
Discussion Bixler a.k.a SkySurfer tendency to flare MarLi Beginner Training Area (Aircraft-Electric) 5 Nov 07, 2011 01:23 AM
