Old Jul 08, 2012, 11:01 AM
Lorphos is offline
Find More Posts by Lorphos
aerial photographer
Lorphos's Avatar
Germany, NRW, Dortmund
Joined Dec 2004
Question
Missing documentation for programming a Keda 18A ESC
Hello,
I bought four Keda 18A ESCs (KDA) to use on a quadcopter. They look like this:
There is documentation for this ESC at http://www.kd-motor.com/downloads.htm but it is incomplete.
I need to know how to set the battery type to NiMH so the quadcopter doesn't fall from the sky when the LiPo is almost empty.
When I connect the ESC with full throttle on the tx and wait 5 seconds, I get 4 or 5 beeps as described in the manual.
When I wait another 5 seconds, it gives 1 beep 5 times.
Then it gives 2 beeps 5 times ... etc until it gives 5 beeps 5 times. Then it starts over with 1 beep five times. What does this mean?
There is a programming card for sale for these ESCs (which I don't have) that looks like this:
Note that it reads "Advance plus prog card", so perhaps they are compatible with Pulso ESCs.
It lets you program:
  • battery type (NiMH or LiPo)
  • brake (on or off)
  • cutoff voltage (low or high)
  • timing (low or high)
  • cutoff type (hard or slow)
  • throttle curve (linear or logarithmic)
Does anyone know how to program these attributes of the ESCs using the throttle stick?
Thanks!
Lorphos is offline Find More Posts by Lorphos
Old Jul 11, 2012, 09:24 AM
Lorphos is offline
aerial photographer
Lorphos's Avatar
Joined Dec 2004
I found this document
http://88.101.156.191/VPR/manualy/re...Pulso4heli.pdf
about Pulso ESCs that mentions 5x three and four beeps. It doesn't discuss the 5x five beeps, however.
Guess it's not the right one.
Old Jul 11, 2012, 01:56 PM
Lorphos is offline
aerial photographer
Lorphos's Avatar
Joined Dec 2004
Saker it is
I contacted KEDA and they advised me to use a programming card.
When I insisted about the 3, 4 and 5 beep sequences, they pointed me to the manual for their Saker brand ESCs at http://kedamodel.com/product/doc/ESC...%20advance.pdf
The sequence in that manual matches my KEDA 18A ESC!
Here is the relevant section from the Saker ESC documentation:
Option parameter assistant by transmitter
The transmitter can set only one parameter of ESC at a time. If you want to set several parameters, please repeat the
following procedures:
  • Plug the JR connector into throttle control channel of receiver.
  • Switch “on” the transmitter and move the stick of throttle to the highest position.
  • Connect the main power pack to ESC (pay attention to the polarity).
  • Wait for 5 seconds, you will hear 4 beeps, that means it entered the programming mode.
  • And then you will hear 5 “single beep”, then 5 “double beep”, then 5 “triple beep”, then 5 “quartet beeps” and then 5 “quintuple beeps”. And these sounds will circulate continuously.
  • Each group of 5 sounds stands for a different parameter of ESC respectively.
  • You can put the stick of throttle to the lowest position during one group of 5 sounds, then the corresponding mode is saved.
  • Hear 1 “♪”(Brake-Medium) or "♪♪" (Brake-Off) , then you can exit the setting mode after saving the mode.
  • When the mode is saved, you can disconnect the ESC to the battery pack.
Brake: Hear the first “♪♪♪♪” in the above circulation, put the throttle stick to the lowest position, the braking mode is
changed from Brake-off into Brake-Medium. If you want to change back, please repeat the above procedures, and
vice versa.
Battery type: When you hear 5 groups “♪” or “♪♪” or “♪♪♪”, move the stick of throttle to the lowest position.
1 “beep”: Li-XX battery
2 “beep”: NiCd, NiMH battery
3 “beep”: LiFe battery
Timing: Hear 5 groups “♪♪♪♪”or “♪♪♪♪♪” , move the stick of throttle to the lowest position.
4 “beep”: Automatically change the timing of motor(recommended for all types of motors)
5 “beep”: Timing-High(recommended for 10 (or more) poles motors and outrunner motors)
Note: When the timing mode of motor is saved, please adjust the motor on the ground before the flight.
So, set the cutoff to NiMH I wait for 2 beeps five times, then move the throtle to minimum.
Help! 15-18A Esc programing HELP! Raj Quest Multirotor Talk 12 May 05, 2012 11:25 AM
Help! Documentation Help for Pixie 7 Brushed ESC 356Jim Scratchbuilt Indoor and Micro Models 5 Mar 25, 2012 01:43 PM
Help! Can't program Suppro 18A ESC , stuck ! fltekdiver Power Systems 1 Feb 24, 2012 07:03 PM
Discussion Keda B20-30-12S Kv7800 18A brushless Inrunner stormlauncher Racing Boats - Electric 0 Sep 13, 2007 11:05 AM
Question Programing The ELE-20P ESC from ELE RC WORLD New Documentation PaulVi Power Systems 18 Dec 23, 2006 01:46 AM
