Joined Jan 2013
You've done a good job getting things simple, Kjell. I wonder if you could test something on your spinning test equipment? I'm curious to see a graph of the current drawn by the motor throughout the flapping cycle. Knowing that, a cam could be designed to flatten the curve and reduce system stresses.
As for my model, it doesn't work as is. My ball and socket idea allowed the ball to spin in the socket and prevented rotary motion from getting to the swashplate. It seems pretty stupid now. I can post the broken model if you really want to see it. |
Joined Jan 2012
Not all swashplates use thrust bearings like you have depicted there Kjell
![]() Every heli swash plate ive worked on have used radial...the big ones double row deep groove angle contact and +6k ea. the only type swash plate i have see with thrust bearings are hyd pumps, I see another possible solution here.... it only requires 1 swash plate bearing, but it requires 2 shaft bearings, the spindle needs to be rigid... ![]() Hope this isn't seen as riding high and I'm contradicting myself, but I can see 2 swash plates in that picture ![]() 1 has a dog leg and the other a pivoting hub....they both swash. Get a coin and spin it on a table, as it slows it will fall into an accelerating decay swash motion. Discovered / invented by Boris 1910. ![]() Pic attached is an old heli swash plate bearing, its a impossible to get them small as we require, single row radial bearing will easily stand up to the job ! |
Joined Jan 2012
To follow on with a ceramic solution
as an example I've found in 6802 single steel bearing is 7.26g single ceramic bearing is 3.1 g that is quite a significant weight loss I hope im helping here...or has this already been covered ? "The Wiggle movement is the best of the mechanical ways to move the wings for flight. " Kjell is absolutely correct here , Im totally convinced this method is the best way, it cannot get any easier than simply turning a bearing in this swash action. the engineering is more complex but the end result is simplistic in nature if you know what i mean ! |
Joined Jan 2013
Options to make it work: a non-circular axle, powered rotating collar, change ball and socket to gimble |
Joined May 2011
Just suggestion and appreciate the efforts,spent time and money of all the guys in the thread! Success to all inventors! http://www.vxb.com/page/bearings/PRO...FXGRPAodY24ACw |
Joined Jan 2012
Good idea Kjell
![]() obviously it runs ok without cages ? Certainly dismisses the ceramic idea, you are certainly further refined than your letting on is it flyn already ![]() This one is axial not radial.... so does it wiggle or swash ![]() Those POM /Glass bearings look like the way... off the shelf solution and only $8, couldn't find any weight ? they look light ... good lead, thanks ! |
| Thread Tools | |
| Discussion wiggle drive propulsion | SudorracMechEng | Dock Talk | 12 | Aug 17, 2012 05:08 PM |
| Question How does a Direct Drive Variable Pitch Multicopter Achieve Yaw? | Bearsa LLC | Multirotor Talk | 8 | Jun 20, 2012 02:28 PM |
| Discussion wiggle drive propulsion application | SudorracMechEng | Scale Boats | 7 | May 15, 2012 12:18 PM |
| Discussion wiggle drive propulsion | SudorracMechEng | Power Systems | 1 | May 07, 2012 06:58 AM |
| Discussion Kjell-Wiggle-Drive | KJELL | Ornithopters | 11 | Feb 26, 2012 02:45 AM |
