Old Jul 07, 2012, 03:57 PM
cj309 is offline
Find More Posts by cj309
Joined Jul 2007
FMS 1700 mm p51
ok guys i need help. I have an external bec that comes off my speed controller. I know that the speed controller plugs into channel 3 on my receiver. There is an additional black/red wire coming off of this bec. Where does it plug in? I need help Thanks. Any one with an FMS 1700mm war bird help me out Thanks
cj309 is offline Find More Posts by cj309
Old Jul 07, 2012, 07:03 PM
slopoke13 is offline
Find More Posts by slopoke13
United States, TN, Oneida
Joined Oct 2011
Plug it into an empty port and you're good to go.
slopoke13 is offline Find More Posts by slopoke13
Old Jul 07, 2012, 11:23 PM
cj309 is offline
Joined Jul 2007
Do i need to disconnect the red wire coming from the esc into the receiver since both the esc and ubec plug into the receiver or do i need to connect the ubec at all and just connect the esc into the trottle channel. Thanks
Old Jul 08, 2012, 01:25 AM
Mikey 68 is online now
Find More Posts by Mikey 68
Joined Sep 2004
Yes you have to take the red wire out from the esc
Mikey 68 is online now Find More Posts by Mikey 68
Old Dec 25, 2012, 10:37 PM
Kev71H is offline
Find More Posts by Kev71H
Kev71H's Avatar
San Jose, California, United States
Joined Apr 2002
I'm still confused. I have the same esc and bec question. Exactly cutting which RED wire ???
Kev71H is offline Find More Posts by Kev71H
Old Dec 26, 2012, 12:54 PM
Joined Sep 2004
The ESC has 3 wires that go to the ch 3 on receiver and the UBEC has 2 wires that you plug into a empty slot on your receiver or use a Y connector to any Channel. The red wire thats coming out of the ESC had to be disconnected. You can take a X-acto blade and lift the tab on the connector and slide the red wire out or you can just cut it. Know the esc and Ubec will have 2 wire each going to the receiver
Old Dec 26, 2012, 12:55 PM
Joined Sep 2004
Disable red wire on ESC for external BEC install (1 min 58 sec)
Old Dec 26, 2012, 01:03 PM
Kev71H is offline
Kev71H's Avatar
Joined Apr 2002
ahhhhhhh... crystal clear now. Thanks!! Thanks for everyone's patience also on this question.
