Old Jul 07, 2012, 02:11 AM
altereddezignz is offline
Find More Posts by altereddezignz
Joined Jul 2012
Build Log
Almost ready to order parts for HEXAcopter build
Ok here are a couple setups. I am trying to decied on what to run. Any ideas?
This all these kits i will have an extra load of 320G max. These numbers do not include any landing gear or camera gimbal or mount.
My end goal will be to fly either a go pro hero 2 or a Sony Nex5x. The only fpv stuff i need is something to use so that i can see what the camera is looking at. I would use the Live video feed out on the Go pro but the Sony does not ahve that option. I have no need to fly really high or fly out of LOS. I would really like to stay around 15 min fly time if at all possible.
#1
Frame: will be 300-500 grams.
Motor: rc timer 2836-9 880kv weigh is 70g each so 420g total
http://www.rctimer.com/index.php?gOo...2&productname=
Model: BC2836-9
Motor size: Ф28*36mm
Shaft size: Ф4.0*49mm
Weight: 70g
KV(rpm/v): 880
Max Power: 243W
Battery: 2-4Li-Po
Test Prop: 12x6/9x6
Ri(M Ω): 0.107
ESC(A): 40A
ESC: Turnigy AE-30A Brushless ESC weight is ?g each so ?g total
http://www.rctimer.com/index.php?gOo...0&productname=
Props: with this kit recomended by motor is 12x6 or 9x6 not sure what the slow fly would be
FC: NAZA with GPS 55G or APM1 max 45G
Batteries: depending on prop that has to be used either 4sp2 10000MAH 1112g or 3sp2 10000MAH 828g
This setup at a fly weight of 6LB flew 19 min using 300g frame using 10x3.8 SF APC props.
The frame that i found for this kit is 300G but limits me to a 11" prop. ONe i know what material the arms are made out of ( U channel i do believe) I can extend them as needed.
#2
Motor: 4215(3507) 650KV Multicopter Brushless Motor 73g each so 438g total.
http://www.rctimer.com/index.php?gOo...9&productname=
Model:
M4215
KV
650KV
Configu-ration
12N14P
Stator Diameter
35mm
Stator Length
7mm
Motor Shaft
4.0*27mm
Motor Dimension (Dia.*Len)
42mm
Weight(g)
73g
Idie Current
≤1.2A
No.of Cells(Lipo)
2-4S
Max Continuous Current(A)
15.7A
Max Contrinuous Power(W)
232.36
Max.efficiency current
>83%
Internal resistance
0.114
ESC: ESC 40A Brushless Motor Speed Controller weight is 25g each so 150g total http://www.hobbyking.com/hobbyking/s...617&aff=615243
Props: with this kit recomended by motor is 12x3.8SF, 10x4.7SF, 12x6E, 13x8E and 14x7E
#3
DJI full f550 KIT
Motor: DJI 2212 920kv
ESC: 30A OPTO
Props: 10x4.5 and 8x4.5
This kit is not bad but i am limited to a 10" prop. Now will i ever need to go over that i ahve no clue. I know there is an extension floating around out there that i can buy to extend and make it a approx 650mm kit and allow me to run a max of a 12" prop.
Well these are the three that i am looking at with the input and help from others.
Price wise kits will run from approx 550 to 1000.
I am being told that i am running cheaper and probable more vibration motors by using RC timers but i would rather spend a little let now. Crash and learn to fly then upgrade to a really good motor in future. Unless that is that these motors work out fine for me?
altereddezignz is offline Find More Posts by altereddezignz
Discussion New AP ship build ready for the 4th of July spacecase Aerial Photography 0 Jul 04, 2012 11:08 AM
Sold Magic fun fly airplane *almost ready to fly* rgandee Aircraft - Fuel - Airplanes (FS/W) 0 Jun 29, 2012 08:54 PM
Sold Almost New MSR Ready to Fly in box with 2 batteries manual extra parts 4 port 1s char blueindian Aircraft - Electric - Helis (FS/W) 3 Aug 16, 2010 01:29 AM
Discussion Getting ready to order parts for Bubble Dancer...have some questions. Ich Bin Sailplane Talk 16 Aug 25, 2009 01:04 AM
Sold 2 planes for sale 1 ready to fly.1 almost ready to fly. chrisdodge65 Aircraft - Fuel - Airplanes (FS/W) 0 Jul 17, 2009 08:30 PM
