Old Jul 06, 2012, 11:44 PM
AleG is offline
Find More Posts by AleG
AleG's Avatar
Bangkok
Joined Oct 2007
Help!
Rewinding C20 1550Kv motor, some help needed.
Some time ago I bought four C20 1550kv motor to make a small quadcopter, alas, one didn't work (broken or shortened wire perhaps) so I took it apart and now I'm seeing about rewinding the whole lot.
I have 0.45mm copper wire and on testing I can put 12 turns on a stator (it has nine). Very tidy I should say, much better than the spaghetti-on-a-fork original winding fork.
So, the question would be, is that wire thickness and turn, on a Delta configuration OK? I have no idea what Kv it would yield, around 1000kv I guess?
Since I have pretty much no experience in rewinding and only a flimsy grasp of the relationship between teeth number, wire, turns, kv, RPM and whatnot I'd be grateful if someone would chip in with some advice.
I'm also thinking of making a PCB to solder the solid wires and the stranded leads, I'm just bored of wires breaking at the base of the motors.
AleG is offline Find More Posts by AleG
Old Jul 07, 2012, 01:08 AM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
If the motor started out as a 1550Kv motor and you rewind with twelve turns, the new Kv will be (Told/12)*1550 = Kvnew assuming you use the same termination as the original winding scheme. How many turns did the motor have originally? It appears that in your post you mean to say it has nine stator arms, but I'm also able to read it as nine turns.
Rewinding the motors will bring the actual Kv values very close together. In stock form these cheaper motors can vary widely due to uneven turn counts and such, but when they're rewound all nice and tidy they end up almost exactly the same. That's good news for a multicopter.
The PCB thing is a good idea. I've also had good luck with just tinning the solid winding wires and then soldering stranded wire to them, but that's scary cause you have to chop the winding wires down to little nubs. Good winding wire won't break easily, and if you use heatshrink to bind the leads together where they exit the motor then you probably have nothing to worry about.
Piece is offline Find More Posts by Piece
Old Jul 07, 2012, 03:33 AM
AleG is offline
AleG's Avatar
Bangkok
Joined Oct 2007
The stator has nine teeth, sorry for the confusion.
I'm afraid I didn't count the original turns as I was gutting the motor, I should do it with the next one.
Old Jul 07, 2012, 07:54 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
Your options for winding schemes on a nine arm stator can be seen here:
http://www.powerditto.de/Kombinationstabelle.html
If it is a 9 arm 10 magnet (9N10P) motor it was most likely would with an AaABbBCcC (not ABCABCABC as I said originally) wind originally. And if you did not find a Wye bundle (three of the six winding ends soldered together and insulated) then it was a Delta termination.
So your wind choices really come down to ABCABCABC or AaABbBCcC with the magnets really deciding which one to use.
You can copy those winding schemes from the table and paste them into the winding scheme calculator here:
http://www.powerditto.de/bewicklungsrechner.html
Then choose the slot (arm or Nuten) magnet (pole) count and termination and it will show you the wind and give you the winding factor for it. The closer the winding factor is to a value of 1 the better the torque and power of the motor will be.
9N10P AaABbBCcC winding factor = 0.94521
9N12P ABCABCABC winding factor = 0.86603
If you measure the strands in the original wind they were probably 0.25mm or so and to get the same current capacity you wold want the new single strand wind to be that much or more. You can look up the surface area here:
http://en.wikipedia.org/wiki/American_wire_gauge
I looks like the surface area on your 0.45mm wire (0.162 mm2) would be equivalent in area to four strands of 0.25mm wire (0.0404 mm2). Once you figure out the turn count that will give you the termination you want you may be able to use an even larger wire, the largest size that will let you get the needed turns on, to get the best surface area.
There are some turn calculator spreadsheets here that will show your the results on the various wind, turn counts and terminations. Turn Calculator 6 need the input (turn count and Kv) from a dLRK wind so that won't work for you on this motor but the Simple Turn Calculator will help you if you have a known turn count and Kv:
http://www.rcgroups.com/forums/showp...&postcount=266
Added note: And on further consideration, I think the Simple Turn Calculator only works for dLRK winds. So neither of those turn calculators will help you...
Jack
jackerbes is offline Find More Posts by jackerbes
Old Jul 07, 2012, 08:56 AM
MagnusEl is offline
Find More Posts by MagnusEl
MagnusEl's Avatar
Sweden, Gävleborg County
Joined Jan 2004
...thanks Jack, for editing...
Magnus
MagnusEl is offline Find More Posts by MagnusEl
Old Jul 07, 2012, 10:02 AM
Jack
USA, ME, Ellsworth
Joined May 2008
Magnus,
Thanks for pointing that out, I hate it when that happens. It wouldn't even work that way!
Jack
Old Jul 07, 2012, 11:18 AM
zeroback is offline
Find More Posts by zeroback
United States, FL, Pompano Beach
Joined Oct 2011
Am I understanding correctly that an ABC wind can have 3 arms wound opposite from the other six? sort of LRK
zeroback is offline Find More Posts by zeroback
Reply With Quote  (Disabled)
Old Jul 07, 2012, 11:49 AM
AleG is offline
AleG's Avatar
Bangkok
Joined Oct 2007
Ah... erm... I'll read that a couple more times.
I checked the motor and it has 12 magnets. I haven't disassembled another one to count the original windings.
In the meantime I spent some time rewinding a AXN2213 I had laying around, after finishing the second winding I realized it was all wrong. No big deal it was a practice run to gain some experience anyway.
Old Jul 07, 2012, 01:34 PM
Jack
USA, ME, Ellsworth
Joined May 2008
That is the way that generally reliable and accurate table at powercroco has it shown. It has one variation for 4 magnets (ABaCAcBCb), a second variation (AaABbBCcC) for 8 and 10 magnets, and tbe ABCABCABC for 6 and 12 magnets.
We need to get three identical motors and try it all three ways, right?
The winding scheme table on the Motor Building Info page presents the same info but in a little different manner. They use a black/blue/white/red scale (credited to Dr. Ralph Okon) for grading the winds as meaning:
black- does not work,
blue - good combination,
white - it works,
red - it works, but not very well
The powercroco page grades the blue fields as "works well", the red fields as "not tested" and empty gray fields to mean there is no functional wind.
I think the powercroco table is the newer of the two so I have been using that one for the most part.
Jack
Old Jul 07, 2012, 04:50 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Having rewound a couple or 4 C20's in the past, 8 turns is (?) ~2000kv on those, it's 4 strands of V thin wire oem. Quite easy to replicate using ( IIRC?) 24 ga which gave more density than the oem but it does look a bit skimpy actually.
No matter, perf is improved as result.
Simple ABC wind is fine. There are no observable disadvantages to the simpler wind scheme.. true enough.
Bare is offline Find More Posts by Bare
Old Jul 09, 2012, 08:30 AM
zeroback is offline
Joined Oct 2011
How interesting, new (to me) winding technique. Is there any motor kits available with 9 arms and loose magnets to experiment with. The RCer kit I bought has a 9 tooth stator but the magnets come glued in the bell.
Old Jul 09, 2012, 03:17 PM
Jack
USA, ME, Ellsworth
Joined May 2008
Strong Motors has some:
http://www.strongrcmotors.com/Motors.htm
And Komodo Hobby, at least in theory, sells some kit motors and the KH-278 has a 9 arm stator and comes with loose magnets.
http://www.komodohobby.com/
But I can't ever get their web pages to work in Firefox so I'm not allowed to shop there or even see what the prices are like...
I don't have another browser to try, IE might get it up for you.
If you google the KH-278 motor it brings up some info on it:
http://www.komodohobby.com/cgi-bin/s...categoryID=181
But I can't get anywhere from there.
Jack
Old Jul 09, 2012, 08:17 PM
Bare is offline
Canada
Joined Nov 2000
Unfortunately DIY Motor kits are yesterday's news. Looong gone.
Either old stock or foolishly expensive for what you get
Simplest more cost effective approach is to rewind an existing motor.. albeit , often these are glue slathered . Just to add insult to injury.
IMO (gasp! a Heretic) it's a slowly dying Fad.
Old Jul 10, 2012, 06:33 AM
Jack
USA, ME, Ellsworth
Joined May 2008
The kit motor days peaked before I got into this so I skipped that phase. I came in during the Tower Pro CD-ROM style motor glory days I think. And those are still viable candidates for rebuilds and rewinds. But getting hardwer to find and some of the parts for them, like the end bell fittings and stuff are probably getting hard to find.
Jack
Old Jul 10, 2012, 09:08 AM
zeroback is offline
Joined Oct 2011
There is a life time supply of burnt up motors/parts that folks will sell for cheap or give away just pay for shipping. I posted 1 request and I have acquired a pile of motors. The selection includes cheap to top tier.
I'll check out the links and see if I have any luck.
Discussion Need some motor guru help powering my Y6 Bolt Multirotor daign Power Systems 13 Aug 06, 2012 07:12 PM
Found Need some gear (help me out :) ) ESCs and Motors Adidas4275 Aircraft - Electric - Multirotor (FS/W) 4 Jul 03, 2012 09:41 PM
Question rewinding some A20-22L motors sirbow2 Power Systems 5 Apr 29, 2012 02:24 PM
Wanted C20 brushless Outrunner 1550kv, shipping to PA AndrewID Aircraft - Electric - Power Systems (FS/W) 0 Mar 12, 2012 07:24 AM
Help! HELP-Who is the best at rewinding outrunner motors? I have two that needs rewinding mechengineer03 Electric Motor Design and Construction 13 Jul 06, 2011 09:40 PM
