Old Aug 05, 2012, 02:44 PM
sirbow2 is offline
Find More Posts by sirbow2
Emress
Joined Nov 2011
Mwc ftw!
sirbow2 is offline Find More Posts by sirbow2
Old Aug 06, 2012, 02:18 PM
airmamaf is offline
Find More Posts by airmamaf
France, IdF, Neuilly-sur-Seine
Joined Jan 2012
Originally Posted by kaakku View Post
Just want to confirm that was able to flash 4 x Plush 25A successfully. Tested with Arcucopter 2.7 & APM2.0.
Start is a bit tricky. Once 1 motor did not start, otherwise motors need to be tricked to start. Once going it works fine.
Rev 6 flashed.
What change did you made in Arducopter 2.7 code ? Did you change min / max throttle ?
@sskaug, is a small firmware planed for multicopter with no configuration and throttle range, like simonk firmware ?
airmamaf is offline Find More Posts by airmamaf
Old Aug 06, 2012, 02:27 PM
sirbow2 is offline
Emress
Joined Nov 2011
http://www.rcgroups.com/forums/showp...tcount=58right now you dont need to change any esc settings i dont think only endpoint on the FC. the MULTI style firmware is already setup best for multis.
Old Aug 08, 2012, 03:25 AM
airmamaf is offline
Joined Jan 2012
@sirbow2, I saw you advise to use your firmware (TURNIGY_PLUSH_25A_MULTI_REV5_0.HEX) instead of REV6, is it still true ? I tried my HK Plush 25A with REV6, and after 3/4 throttle, there's a kind of step, e.g. before it's linear and after esc roughly change motor's speed. You know what could be the reason ?
Old Aug 08, 2012, 10:32 AM
excalibur46 is offline
Find More Posts by excalibur46
France
Joined Dec 2010
Same thing for me on a Plush 25A with rev6 and rev6_test (multi)
Step at 3/4 throttle and step to start
I found that the ESC is warmer compared with the original firmware
A pb of timing ?
excalibur46 is offline Find More Posts by excalibur46
Old Aug 08, 2012, 11:14 AM
vpb is offline
vpb
Find More Posts by vpb
vpb
Joined Jun 2012
Hi sirbow2, can't wait to try reflashing my plush 30A, i've checked it recently, it's silab. But now I have to order and wait about 2-3 weeks for the toolstick. Is there a way to flash with USBAVR? I have one from the previous kk board here :-(.
P.S: the hex I go with will be TURNIGY_PLUSH_30A_MULTI_REV6_0.HEX?
Tks!
vpb is offline Find More Posts by vpb
Old Aug 08, 2012, 01:22 PM
sskaug is online now
Find More Posts by sskaug
Joined Dec 2009
A pb of timing ?
The plushes have a slow driver that causes the step at full throttle. Read post #50 for more details. Original plush use 8kHz pwm, so the step will be smaller.
Maybe the 20kHz high pwm frequency that is default for BLHeli makes the esc a bit warmer. You could try low pwm frequency. Also the startup of BLHeli uses a stepper mode drive of the motor that consumes a bit of power. I'll look into other start modes that may be better suited for a multirotor application.
sskaug is online now Find More Posts by sskaug
Old Aug 08, 2012, 02:53 PM
sirbow2 is offline
Emress
Joined Nov 2011
nope. use the rev6. i made that one rev 5 because there was no rev5 25a hex.
Old Aug 08, 2012, 03:00 PM
sirbow2 is offline
Emress
Joined Nov 2011
Tks!
im waiting for some(usbavrs) myself and will get back to ya when i do it. but it is possible. youll need two usbavrs though as you have to put the silprog firmware on the usbavr
Old Aug 08, 2012, 05:28 PM
sirbow2 is offline
Emress
Joined Nov 2011
Note for all current and future windows 8 users! you must run silprog in windowns xp sp3 compatibility mode or else silprog will crash during programming!
also, in win 8 i am unable to move the window while it is sending the hex to the arduino. no biggie.
Old Aug 08, 2012, 10:41 PM
vpb is offline
vpb
vpb
Joined Jun 2012
I can buy some more usbavrs here, as hobby resellers stock so many of them here. Can you give me the instruction and I can... try first?
Old Aug 12, 2012, 02:00 PM
Joined Dec 2009
Rev6.1 is now posted: https://github.com/bitdump/BLHeli
The changes are:
- Added input signal qualification criteria for PPM, to avoid triggering on noise spikes (fix for plush hardware)
- Changed main and multi mode stop criteria. Will now be in run mode, even if RC pulse input is zero
- Fixed bug in commutation that caused rough running in damped light mode
- Miscellaneous other changes
Cheers,
Steffen
Old Aug 12, 2012, 02:15 PM
sirbow2 is offline
Emress
Joined Nov 2011
with the current silprog firmware, this is impossible because the usbasps/usbavr use usb to communicate, not serial (flashing is done via serial to the arduino and then to the esc).
Old Aug 13, 2012, 04:25 PM
AcroFPV is online now
Find More Posts by AcroFPV
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
How different is the BLHeli firmware and the SimonK firmware?
AcroFPV is online now Find More Posts by AcroFPV
Old Aug 13, 2012, 09:05 PM
sirbow2 is offline
Emress
Joined Nov 2011
they have pretty much the same goal, but simonk is simpler (fewer settings) and works better than blheli currently. blheli is pretty close, though, jsut needs some timing issues fixed up (on the plush at least, dont know about other ESCs)
Found forget the plush, i need 5x 30 amp esc that i can flash, no plush !!! crash8384 Aircraft - Electric - Multirotor (FS/W) 14 Jun 25, 2012 03:10 AM
Discussion is it possible to flash the Flycam Blackboard w/ 4.7kk X betito Multirotor Talk 2 May 03, 2012 02:12 PM
Discussion Silabs 8051 ESC (Turnigy Subperbrain) Firmware nickax Multirotor Talk 2 Jan 29, 2012 11:11 PM
Sold 2 Turnigy Plush 10 amp ESCs + 1 Turnigy 5A UBEC + 1 Turnigy Programming Card - $21 shawn595 Aircraft - Electric - Power Systems (FS/W) 2 Apr 02, 2011 12:30 PM
Discussion Is it possible to convert TURNIGY Plush 30A ESC's from PWM to TWI/I2C control benbois DIY Electronics 0 Dec 17, 2008 11:56 AM
