Old Feb 13, 2013, 02:22 PM
Stigern is offline
Find More Posts by Stigern
Registered Addict
Stigern's Avatar
Bodø, Norway
Joined Mar 2007
Originally Posted by sskaug View Post
Just to be sure, are you using the code from post 449: http://www.rcgroups.com/forums/showp...postcount=449?
Oh! Sorry, that slipped my sight, will try this tomorrow. Thanks
Stigern is offline Find More Posts by Stigern
Old Feb 13, 2013, 02:26 PM
vartaz is offline
Find More Posts by vartaz
Denmark, Central Denmark Region, Karup
Joined Aug 2012
What of these esc would you choose for my build mt4006-13 motors 10x4.5
dji naza running 4s
1: RCX (myrcmart.com) 20a simonk 2-4s 2 months old
2: Turnigy plush 30a stock 2-4s (have program card)
3: RCtimer 30a simonk 2-4s 1 months old
i have these escs in my parts box i just cant choose which to use.
Im getting some f-30as simonk flashed which im gonna try out, but for now im hoping to be able to use one of the three above.
Which of the ones above would you choose and why? i can find out if any of them has extern. oscilliator
vartaz is offline Find More Posts by vartaz
Old Feb 13, 2013, 02:28 PM
Stigern is offline
Registered Addict
Stigern's Avatar
Bodø, Norway
Joined Mar 2007
dji naza running 4s
They are most likely F30As
Old Feb 13, 2013, 02:57 PM
sskaug is online now
Find More Posts by sskaug
Joined Dec 2009
Great! You should also set timing and pwm frequency to defaults .
sskaug is online now Find More Posts by sskaug
Old Feb 19, 2013, 11:43 AM
Stigern is offline
Registered Addict
Stigern's Avatar
Bodø, Norway
Joined Mar 2007
Woho! works fine!
Thanks.
Skywalker 20A ESC flashed with BLHeli Multi 9_4 temp-fix Working! (0 min 29 sec)
Old Feb 19, 2013, 02:22 PM
Joined Dec 2009
BLHeli rev10.0 is out, details can be found here: http://www.helifreak.com/showpost.ph...postcount=2389
Also, check out this thread on motor response: http://www.rcgroups.com/forums/showthread.php?t=1835486
Old Feb 19, 2013, 02:24 PM
Joined Dec 2009
Woho! works fine!
Thanks.
Great to hear . And as you see above, rev10 is out, so if you want overtemp protection as well, then grab it.
Sorry for the trouble caused by this, but it was a rather unexpected behavior of the SkyWalkers.
Old Feb 19, 2013, 02:30 PM
mystman is offline
Find More Posts by mystman
Joined Jan 2012
Does this new version will "wakeup" my lethargic Plush 6A ?
They lost punch after flashing.
mystman is offline Find More Posts by mystman
Old Feb 19, 2013, 02:33 PM
Joined Dec 2009
There is no difference to the Plush 6A behavior. I fly them with BLHeli myself on a HK quad, and find them equally powerful as the originals, but without the annoying "whining". Sure you have no issue with throttle calibration/range etc?
Old Feb 19, 2013, 02:43 PM
4712 is online now
Find More Posts by 4712
Germany
Joined May 2011
The corresponding BLHeli-Setup 10.0 is also out ...
Many thanks for the nice and great cooperation, Steffen!
Changes in 10.0.0.0:
BLHeli 10.0 Hex files added.
Adapted the additional parameters from BLHeli.
Added ESC's
• Turnigy KForce 40A
• Turnigy KForce 120A HV
Motor Calculator:
GOV target now shows also the target rpm in relation to the motor capabilities as percentage value.
Added new Combo-box for individual compensation factor (% Value) for Lipo voltage drop and Motor KV drop
under load. Default is 81% (former procedure assumed 3.8V/s @90% KV drop ->81.43%).
Hassle free update of old Motor data included.
Flash Dialog reworked in parts. Now selection of fitting flash-file is even more comfortable.
Serial Interfaces handling:
Added the capability to flash BESC's in arrangements from 1 up to 8 BESC.
Integrated Multiple-BESC capabilities in the Arduino Interfaces and Boxes.
Updated serial protocol revision to V2 for Multiple-BESC Interfaces.
Raised all Interface Revision numbers to V10.
Added a Arduino Uno based box with a LCD4884 Shield.
Added an Atmega168 upgrade option to the small boxes (Robbe, TDLX, TAQX) to give room for Multiple- BESC capabilities. The small Box will handle up to 5 or 6 BESC's at once (Still Tests are needed).
Several changes in the serial Interface firmware to reduce size and efficiency.
BLHeli Manuals ("BLHeli programming by TX "/" Governor SiLabs High and Low.xls") are now included and accessed local for easier and faster handling. Because information about supported BESC may change more frequent, "BLHeli supported SiLabs ESCs" is not included, but will be downloaded on access through "BLHeli-
Info" menu. (btw: if you store the file as "BLHeli supported SiLabs ESCs.pdf" in the Application path, it will be loaded from there).
All in all:
Some minor general improvements of the UI.
Some bug-fixes too, of course...
__________________________________________________ ___________________
Any bug report, comments, feature request are always welcome. :cheers
4712 is online now Find More Posts by 4712
Old Feb 19, 2013, 02:48 PM
Stigern is offline
Registered Addict
Stigern's Avatar
Bodø, Norway
Joined Mar 2007
I'll flash em with rev 10.
Nothing to be sorry about! Your doing all this on your spare time, I should be glad someone takes the effort to do such. Kudos!
Old Feb 19, 2013, 03:15 PM
mystman is offline
Joined Jan 2012
Any special throttle calibration/range tips for using with multiwii ?
I'm really missing the throttle punch I had before flashing.
If I give short throttle punches with a 2S 35C 500mah lipo and 1811-2000kv motors (Totalweight including lipo : 175g) I don't have the "rocket" effect. The ESC don't seem to react instantly.
I'm missing the nice accleration I had before.
I set the throttle range automatically by the multiwii software (ESC_CALIBRATION)
The ESC are only setup with with high timing and full startup power. Other values are left by defaults.
Old Feb 20, 2013, 01:32 PM
OlliW is online now
Find More Posts by OlliW
OlliW
Joined Sep 2009
over and over again
now this really becomes rediculous:
and allover again, the next invention of mine just copied into BLHeli-Setup...
the list of historical facts about BLHeli-Setup vs owSilProg/BLHeliTool/BLHeliBox looks now like this:
* sskaug/Steffen intoduced the BLHeli firmware, running on Silabs-based ESCs
* 4712/Achim introduces the BLHeli-Setup program, rev 1 to rev 6, which allows to flash and program BLHeli-ESCs using Silabs toolsticks and clones
* OlliW introduces the concept of using ATmels and Arduinos specifically to flash silabs chips and program BLHeli-ESCs using a simple serial interface, and working firmwares/softwares
* OlliW with sirbow2, copperclad, and sadsack work out the technical tricks to handle the Arduinos best
* OlliW with v20120815 introduces the multi-functional BLHeliBox with 1602 LCD text displays, which works both as stand-alone programming box and programmer
* 4712/Achim with BLHeli-Setup 7/8 (15.Oct.2012) introduces the 1to1 pin compatible possibility to use ATmels and Arduinos specifically to flash silabs chips and program BLHeli-ESCs using a simple serial interface, and introduces various multi-functional boxes with 1602 LCD text displays, which work both as stand-alone programming box and programmer
* OlliW with v20120815 introduces a filter for easier selection of hex files
* OlliW with v20120921 introduces the graphical BLHeliBox with graphical displays, the Arduino Uno+lcd4884 shield specifically
* OlliW with v20130103 introduces the multiple-esc function, which allows to handle up to eight silabs esc with several convenience functions
* 4712/Achim with BLHeli-Setup 10 (19.Feb.2013) introduces a filter for easier selection of hex files, introduces support for a box with graphical displays using the Arduino Uno+lcd4884 shield, and introduces the multiple-esc function, which allows to handle up to eight silabs esc with several cponvenience functions
* OlliW with v20130103 introduces the BLHeliBox No.5, and shortly later the Ardubox
* OlliW with v20130204 introduces bluetooth support, along with a smart auto-configuration procedure
* 4712/Achim introduces... well, these have not yet been copied over to BLHeli-Setup (I'll take bets on how long wil it take before e.g. the bluetooth function is also take over LOL)
now, you tell me
* is it incorrect to say that any aspect of the owSilProg/BLHeliBox/BLHeliTool have been duplicated/copied by BLHeli-Setup
* have you ever seen anything like this happening before, is this normal
* what sort of person is this guy
* what would you do/think if any step of innovation you do in such an extended project (which owSilProg/BLHelitool certainly is) is integrated shortly later by someone else in his own project
I mention, that, out of respect of 4712/Achims project, I stayed on "my side" of the bridge and have never made ANY effort to include also support of silabs toolsticks and clones, which was that BLHeli-Setup was (used to be) about.
olli
OlliW is online now Find More Posts by OlliW
Old Feb 20, 2013, 03:50 PM
Joined Dec 2009
Why not just share and help each other? If others are inspired to do the same or similar stuff, that is just a bonus to the community. For my part I'd just be happy to see someone do a "BLMulti" or whatever. The source code is out there, feel free to use it and abuse it!
Old Feb 20, 2013, 05:09 PM
OlliW is online now
OlliW
Joined Sep 2009
http://www.helifreak.com/showpost.ph...postcount=2400
http://www.helifreak.com/showpost.ph...postcount=2402
Found forget the plush, i need 5x 30 amp esc that i can flash, no plush !!! crash8384 Aircraft - Electric - Multirotor (FS/W) 14 Jun 25, 2012 03:10 AM
Discussion is it possible to flash the Flycam Blackboard w/ 4.7kk X betito Multirotor Talk 2 May 03, 2012 02:12 PM
Discussion Silabs 8051 ESC (Turnigy Subperbrain) Firmware nickax Multirotor Talk 2 Jan 29, 2012 11:11 PM
Sold 2 Turnigy Plush 10 amp ESCs + 1 Turnigy 5A UBEC + 1 Turnigy Programming Card - $21 shawn595 Aircraft - Electric - Power Systems (FS/W) 2 Apr 02, 2011 12:30 PM
Discussion Is it possible to convert TURNIGY Plush 30A ESC's from PWM to TWI/I2C control benbois DIY Electronics 0 Dec 17, 2008 11:56 AM
