Old Jul 24, 2012, 07:36 AM
sirbow2 is offline
Find More Posts by sirbow2
Emress
Joined Nov 2011
That's what my 25 A are
sirbow2 is offline Find More Posts by sirbow2
Old Jul 24, 2012, 09:39 AM
dyarrow is offline
Find More Posts by dyarrow
United Kingdom, England, Poole
Joined Dec 2008
Would this work for the silabs version of Hobbywing 25A?
I'm wondering if this will fix my unstable hobbywing esc issues.
dyarrow is offline Find More Posts by dyarrow
Old Jul 24, 2012, 10:04 AM
sirbow2 is offline
Emress
Joined Nov 2011
it depends on what the FET layout is. im GUESSING that they are the same(probably a copy?) so its worth a try. sacrificing one ESC to test wouldn't be so bad if you had an extra.
Old Jul 24, 2012, 10:10 AM
dyarrow is offline
Joined Dec 2008
I have 4 of them going spare as I can't use them for multirotor at the moment.
Might give the arduino method a try.
Old Jul 24, 2012, 09:36 PM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
OK, I'll bite.
Turnigy 10A w/Silabs, do I just use tgy 6A file on them? Or is there something else to try?
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Jul 25, 2012, 08:43 AM
sirbow2 is offline
Emress
Joined Nov 2011
Yeah that should work. to get the best results you need to copy the 6A plush code and chanege the NFET/PFET delay time to the fets on the esc so the fet on/off timing is the best. Then compile it into a new hex. I'll write a quick guide soon.
Old Jul 25, 2012, 08:49 AM
timecop is offline
Joined Dec 2010
I've got a toolstick on the way (seems I lost one I bought last year) so I will try it again.
Old Jul 27, 2012, 10:31 PM
shultz is offline
Find More Posts by shultz
United States, NV, North Las Vegas
Joined Sep 2009
I did one HW funfly 10a tonight using the Turnigy 6A multirotor hex. so far it seems OK, The motor (suppo 2214) starts and runs fine but I still don't have a very linear throttle. Once you hit about 3/4 stick using a mutli advance stock setting of 1.0 its like hitting Turbo... the motor is smooth up to 3/4 throttle then JUMPS to full and you have no throttle control past 3/4 stick. If i back off the multi advance to .75 the throttle is more linear BUT once you hit 3/4 stick thats it...motor never reaches full power
I think I'll flash 3 more and try them on a quad...I do think the firmware still needs some more work by someone smarter than me
John
more info here, /i'm grabing the new files and trying them out.
http://forums.openpilot.org/topic/10...ilabs__st__200
shultz is offline Find More Posts by shultz
Old Jul 28, 2012, 11:59 AM
sirbow2 is offline
Emress
Joined Nov 2011
That's because the throttle range is set to 1150(activate
esc), 1200(start motor), and 1800(max throttle). In mwc I set min_command to 1140, min_throttle to 1195, and max_throttle to 1850. works fine. The issue at 3/4 you describe is probably because your throttle range is 1000 to 2000?
Old Jul 29, 2012, 02:34 PM
kaakku is offline
Find More Posts by kaakku
Joined Feb 2012
Just want to confirm that was able to flash 4 x Plush 25A successfully. Tested with Arcucopter 2.7 & APM2.0.
Start is a bit tricky. Once 1 motor did not start, otherwise motors need to be tricked to start. Once going it works fine.
In my opinion battery consumption is higher that with stock Escs.
Rev 6 flashed.
kaakku is offline Find More Posts by kaakku
Old Jul 29, 2012, 03:01 PM
sirbow2 is offline
Emress
Joined Nov 2011
Rev 6 flashed.
ah good rev6 works. Use the 25a hex I posted here and that will fix the startup issues.
Old Jul 30, 2012, 12:36 PM
Kaji is offline
Find More Posts by Kaji
Kaji's Avatar
Finland, Päijänne Tavastia, Lahti
Joined Jul 2010
Is the firmwares found here the latest and optimized for multicopter use if I choose firmware with MULTI in its name?
https://github.com/bitdump/BLHeli/tr...bs/Hex%20files
Kaji is offline Find More Posts by Kaji
Old Jul 30, 2012, 12:55 PM
sirbow2 is offline
Emress
Joined Nov 2011
i see he put the plush 10/12/25/30/18A in the new rev6! yes those will work.
Old Jul 30, 2012, 01:07 PM
Kaji is offline
Kaji's Avatar
Joined Jul 2010
Very good! I will give a try for plush 12A multi version when I finally get toolstick.
Originally Posted by sirbow2 View Post
i see he put the plush 25/30/18A in the new rev6! yes those will work.
Old Jul 30, 2012, 03:23 PM
Menno is offline
Find More Posts by Menno
Joined Nov 2005
I've got 3 Plush 25 amp ESC's with Atmel processors and 1 Plush 25 amp ESC with Silab processor (lucky me ).
Now that the Silabs can also be flashed with Multicopter firmware I might give it a go. However I don't really feel like buying a 25 dollar toolstick to flash a 12 dollar ESC. Do you think it will ever be possible to flash it using the USBASP controller. Almost everybody with a KK board already has this programmer. Or is this strictly for Atmel?
Menno is offline Find More Posts by Menno
Found forget the plush, i need 5x 30 amp esc that i can flash, no plush !!! crash8384 Aircraft - Electric - Multirotor (FS/W) 14 Jun 25, 2012 03:10 AM
Discussion is it possible to flash the Flycam Blackboard w/ 4.7kk X betito Multirotor Talk 2 May 03, 2012 02:12 PM
Discussion Silabs 8051 ESC (Turnigy Subperbrain) Firmware nickax Multirotor Talk 2 Jan 29, 2012 11:11 PM
Sold 2 Turnigy Plush 10 amp ESCs + 1 Turnigy 5A UBEC + 1 Turnigy Programming Card - $21 shawn595 Aircraft - Electric - Power Systems (FS/W) 2 Apr 02, 2011 12:30 PM
Discussion Is it possible to convert TURNIGY Plush 30A ESC's from PWM to TWI/I2C control benbois DIY Electronics 0 Dec 17, 2008 11:56 AM
