Old Jan 19, 2013, 02:34 AM
Soma is offline
Find More Posts by Soma
Australia, QLD, Brisbane
Joined Sep 2012
Well Rob, you certainly helped me out even though you're just starting
I'm a beginner myself and, thanks to the great help of those on this thread, started with BLHeli too. I also don't know SimonK, that's why I was hoping for the Silabs.
Eventually I wanted to learn SimonK. Maybe these ESCs have made that decision for me now
I'll report back when I hear from Hobbywing. Apparently Hobbywing have a special 'anti-counterfeit' label on all their packages. Mine didn't have the label so that may be telling?
Cheers.
Soma is offline Find More Posts by Soma
Old Jan 20, 2013, 06:07 AM
sskaug is offline
Find More Posts by sskaug
Joined Dec 2009
Hi!
Rev9.4 is now posted on github: https://github.com/bitdump/BLHeli
The code timing has been optimized in order to be capable of running at high rpms.
It now runs smoothly up to 200000 electrical rpms.
Steffen
sskaug is offline Find More Posts by sskaug
Old Jan 20, 2013, 06:45 AM
Soma is offline
Joined Sep 2012
Thanks very much Steffen!
Did you get it to run smoothly on the Skywalker 20A?
I will test it on one of my Silabs 20A Skywalker when I get the chance. My Quattro arrived today so I'm keen to see how it goes.
Also I just found a post regarding Atmel Skywalkers from October...
http://www.rcgroups.com/forums/showp...postcount=6012
Still waiting to hear from Hobbywing. Does anyone know any info on the Atmel version? Has anyone received a Silabs Skywalker lately? That may point to the Atmels being fakes???
Cheers.
Old Jan 20, 2013, 06:51 AM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
Woot, now I can start working on the ESCs for my micro octo running 3s on 2900kv :-)
brontide is offline Find More Posts by brontide
Old Jan 20, 2013, 03:09 PM
Crashpilot1000 is offline
Find More Posts by Crashpilot1000
Joined Jul 2012
Doesn't work with skywalker 20A.
I flashed my quad and 3 esc seem to work and one intermittent stops. Quad unflyable now. I reflashed the "faulty" (worked before) a few times with verify - no help. All values are stock, except the throttlerange was set to 1996 on the high side.
Anyone any ideas?
Greetings
Kraut Rob
Crashpilot1000 is offline Find More Posts by Crashpilot1000
Old Jan 20, 2013, 03:48 PM
Soma is offline
Joined Sep 2012
Originally Posted by crashpilot1000 View Post
doesn't work with skywalker 20a.
Anyone any ideas?
Greetings
kraut rob
Bugger!
Old Jan 20, 2013, 05:26 PM
Joined Jul 2012
I wonder why 3 out of 4 esc seem to work. The PCB and parts look identical. I set my apm to 400Hz PWM (instead of 490Hz) - problem persists.
Greetings
Kraut Rob
Old Jan 20, 2013, 10:09 PM
OlliW is online now
Find More Posts by OlliW
OlliW
Joined Sep 2009
maybe, only of course if Steffen likes, you could send your dude to him for investigation...
I wouldn't be surprised to learn that there are significant variances in the properties, in particular with these cheap escs, and Steffen can of course adjust BLHeli only based on his one or few items he has at hand... this could explain why it's one out of four and why it did work with the original firmware (the manufacturer will have coped for the variances, which are known to them).
Considering the unavoidable material variances, I find it actually amazing how often BLHeli just works...
OlliW is online now Find More Posts by OlliW
Old Jan 21, 2013, 04:28 AM
Joined Jul 2012
Hi!
Thank you very much for your concern. I was very upset yesterday.
Today i found out that this issue occured with the other esc as well but to smaller extend. I flashed the trouble - master esc with different versions of the skywalker20a files, knowing that they are not suitable for multirotoruse - so i handtested them all. The SKYWALKER_20A_MAIN_REV9_4.HEX seems to solve the problem (on stock, with govenor etc on). Than I turned motor PWM from low to high and BAM the problem was there! So i will reflash that esc with SKYWALKER_20A_MULTI_REV9_4.HEX, leave everything at default except: Throttle max 1996 and motor PWM to low. My APM is still set to 400Hz PWM output.
I will report back
Cheers
Kraut Rob
Old Jan 21, 2013, 04:56 AM
Joined Jul 2012
Works now
Hi!
It works now with pwm low! I am back in the air!
I did screenshots of the current settings.
EDIT: Set APM back to 490Hz PWM - still works
Greetings
Kraut Rob
Old Jan 21, 2013, 06:27 AM
Soma is offline
Joined Sep 2012
Good news Rob!
Fingers crossed this has it sorted.
Keep us posted mate
Old Jan 21, 2013, 07:09 AM
flyboygaac is offline
Find More Posts by flyboygaac
flyboygaac's Avatar
Portugal, Lisbon, Sintra
Joined Jul 2011
Thank you for all effort with BLHELI.
I love it!
This video from warm summer was flown with scratch built Tricopter with plush 30A ESCs with BLHeli and DT750 motors
No more Winter FPV... remembering Summer - Flown with Dragon Link (0 min 38 sec)
flyboygaac is offline Find More Posts by flyboygaac
Old Jan 21, 2013, 08:02 AM
Joined Jul 2012
OMG it happened again, but only slightly this time.
Now i flashed SKYWALKER_20A_MAIN_REV9_4.HEX. Everything stock except: gov. OFF, voltage protection OFF. And maxthr 1996.
I hovered a complete lipo without glitches - i hope i got it now once and for all.
Attached settings as pictures.
@flyboygaac: Very nice video! I hope my quad will do the same in freeflight now
@sskaug @OlliW: Thank you very much for your effort and time you stick into this project. I know my problem is pain in the a... but you can not support all the different escs out there and their small variations.
Cheers
Kraut Rob
EDIT:
I had a chance to give it a one lipo - spin outside. It flies better than before (rate_p increased!) and no glitches at all. First time throttle seems to be problematic for multirotors with this "main" FW. So let the motors run, stop them and then start.
Old Jan 21, 2013, 10:52 AM
sskaug is offline
Joined Dec 2009
Cheers
Kraut Rob
EDIT:
Hi Rob
Glad you are in the air now
But there is something fishy going on that I would like to investigate. If you like, I will be happy to buy one of your quattro's to look at. While there is some variation in ESCs, I think there is even larger variation among motors. What motors do you use? Have you tried swapping motors and ESC channels to see whether the problem follows a specific channel on the quattro, or if it follows a motor?
Steffen
@flyboygaac, glad to see that your tri now flies well. And good to see some summer amidst all the white here these days
Old Jan 21, 2013, 11:31 AM
Joined Jul 2012
@sskaug:
"But there is something fishy going on ..."
I think the same.
My setup: apm2.0, no quattro just 4 single skywalker 20A ESC, Motors: Robbe roxxy 2827-26 with APC SF 10x4.7.
Everything is soldered - so easy swapping the esc between motors is not possible. These motors are not very old and experienced no serious crash - not even a broken prop . They turn easily. Before mounting them i checked them for a short between phase and housing ( i always do that after some bad experience with some emax models)
I am just happy the thing flies again and that i could turn up the rate_P by 40%.
Greets
Kraut Rob
Found forget the plush, i need 5x 30 amp esc that i can flash, no plush !!! crash8384 Aircraft - Electric - Multirotor (FS/W) 14 Jun 25, 2012 03:10 AM
Discussion is it possible to flash the Flycam Blackboard w/ 4.7kk X betito Multirotor Talk 2 May 03, 2012 02:12 PM
Discussion Silabs 8051 ESC (Turnigy Subperbrain) Firmware nickax Multirotor Talk 2 Jan 29, 2012 11:11 PM
Sold 2 Turnigy Plush 10 amp ESCs + 1 Turnigy 5A UBEC + 1 Turnigy Programming Card - $21 shawn595 Aircraft - Electric - Power Systems (FS/W) 2 Apr 02, 2011 12:30 PM
Discussion Is it possible to convert TURNIGY Plush 30A ESC's from PWM to TWI/I2C control benbois DIY Electronics 0 Dec 17, 2008 11:56 AM
