Old Jul 09, 2012, 08:46 PM
charbot is offline
Find More Posts by charbot
Joined Oct 2006
aww...you got our hopes up
charbot is offline Find More Posts by charbot
Old Jul 09, 2012, 08:49 PM
sirbow2 is offline
Find More Posts by sirbow2
Emress
Joined Nov 2011
we have waited years(?) for this, a few days wont hurt( the firmware files arent too different between main and multi.)
sirbow2 is offline Find More Posts by sirbow2
Old Jul 10, 2012, 07:30 PM
sirbow2 is offline
Emress
Joined Nov 2011
sorry bout my previous post saying MULTI wasnt supported by AVR yet, what i meant was that the GUI for BLHeli doesnt support MULTI yet, you can still program ESCs with the AVR, but you'd have to use TX sticks to calibrate.
i got my first ESC programmed!.... but its not working.... its not bricked because i can still reflash it... weird. hopefully the guys at helifreaks can help
Old Jul 10, 2012, 08:05 PM
charbot is offline
Joined Oct 2006
heh, glad you're willing to test it all out. keep us posted.
Old Jul 11, 2012, 08:08 AM
dragonfly_heli is offline
Find More Posts by dragonfly_heli
Joined Jun 2012
Originally Posted by sg1anubis View Post
I usually take a set of standard 0.1" header pins and bend them in to align with the pads. Instead of soldering I'll just hold it on, assuming that the pins are all in a row. It may be possible to power the esc through the servo leads and not have to connect VDD or GND, that would greatly simplify the wiring.
What advantages would their be for flashing a SILabs based esc, isn't the refresh rate already 490Hz?
Howdy,
I solve this problem using this JTAG 'connectorless' connector, all it requires is three little holes and a ten-pin IDC pad pattern on the board. It is a very slick and inexpensive solution for programming Atmel based boards. And are really neato as they are inexpensive too and easy to implement.
See: http://www.tag-connect.com/tag-conne...DC-TG2050IDCNL
tron
pedigree hackin'gineer
dragonfly_heli is offline Find More Posts by dragonfly_heli
Old Jul 11, 2012, 09:53 AM
sirbow2 is offline
Emress
Joined Nov 2011
35$ yikes.....
Old Jul 11, 2012, 10:47 AM
sirbow2 is offline
Emress
Joined Nov 2011
YESH! it works! i will update the first post with a guide soon.
Old Jul 11, 2012, 12:38 PM
charbot is offline
Joined Oct 2006
Congratulations! you are using 25 amp right?
Old Jul 11, 2012, 01:24 PM
sirbow2 is offline
Emress
Joined Nov 2011
yeah 25A
Old Jul 12, 2012, 07:55 PM
sirbow2 is offline
Emress
Joined Nov 2011
i have updated the first post with the tutorial. heres the link: http://www.rcgroups.com/forums/showp...78&postcount=2
Old Jul 18, 2012, 05:49 AM
Propheta13 is offline
Find More Posts by Propheta13
Joined Jul 2012
Hello all. I have Turnigy Plush ESC's and clone of Silabs USB debugger (with 4 pin connector). Can i flash my ESC's someway?
Propheta13 is offline Find More Posts by Propheta13
Old Jul 18, 2012, 02:11 PM
sirbow2 is offline
Emress
Joined Nov 2011
yes you can. the pins that you need from the programmer cable are:
7.................C2CK
2 or 3 or 9..GND
4.................C2D
follow the toolstick part of the guide here, except you will be using your adapter.
Old Jul 20, 2012, 05:56 AM
Joined Jul 2012
Thank's alot. Sorry i forget to say that i have Plush 30A, will this instruction suit to it?
Old Jul 20, 2012, 09:27 AM
sirbow2 is offline
Emress
Joined Nov 2011
you can use the plush 6A hex for now, but the startup might be rough until the proper hex files for different amperages are released. after the prop gets spinning, its is good. i found this was because of bad a ESC.
i have also attached a 25A hex that works on 18A and 25A for sure 30A plush most likely too!
Old Jul 24, 2012, 06:45 AM
Magnetron1 is offline
Find More Posts by Magnetron1
Michele Ardito
Magnetron1's Avatar
Italia, Puglia, Massafra
Joined Jan 2012
Has this file been checked on a HK Plush 25A v3.1?
Magnetron1 is offline Find More Posts by Magnetron1
Found forget the plush, i need 5x 30 amp esc that i can flash, no plush !!! crash8384 Aircraft - Electric - Multirotor (FS/W) 14 Jun 25, 2012 04:10 AM
Discussion is it possible to flash the Flycam Blackboard w/ 4.7kk X betito Multirotor Talk 2 May 03, 2012 03:12 PM
Discussion Silabs 8051 ESC (Turnigy Subperbrain) Firmware nickax Multirotor Talk 2 Jan 30, 2012 12:11 AM
Sold 2 Turnigy Plush 10 amp ESCs + 1 Turnigy 5A UBEC + 1 Turnigy Programming Card - $21 shawn595 Aircraft - Electric - Power Systems (FS/W) 2 Apr 02, 2011 01:30 PM
Discussion Is it possible to convert TURNIGY Plush 30A ESC's from PWM to TWI/I2C control benbois DIY Electronics 0 Dec 17, 2008 12:56 PM
