Old Jul 06, 2012, 05:16 PM
topforce is offline
Find More Posts by topforce
USA
Joined Feb 2002
Help!
Why does my blade mqx fly like s@#t?!
After several crashes and dorks, my blade mqx flies horribly! At hover or slow forward flight its fine. How ever,, at high throttle it wigs out, starts tik tocking, goes into a wicked cycle of over correction and then crashes.
Reason I am concerned is it takes high throttle to flip or roll the little bugger,, and as of now, al I got is about up to 2/3 throttle before it starts freaking out.
topforce is offline Find More Posts by topforce
Old Jul 06, 2012, 05:22 PM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Check your motors all spin freely with the same lack of resistance. Make sure all of your blades are tracking nicely, bend them if not. Check the gears. Try a fresh battery.
Balr14 is offline Find More Posts by Balr14
Old Jul 06, 2012, 07:21 PM
fred_dot_u is offline
Find More Posts by fred_dot_u
Joined Apr 2008
After a few crashes, your motors and your props are not as evenly matched as they were when new. As a result, the mini-computer-brain on board the mQx has a much rougher time getting power levels correct at full throttle. When you go full throttle, let's say that one motor is giving the highest level of the four. The other three are close but not spot-on. That means the "high" motor is going to start to cause a flip. The gyro circuit on the mQx is going to try to compensate, but it over-corrects and you get what you've experienced. The above description is for one motor, but if you've got two that provide full power and two that don't, you can really have a handful.
After losing one somewhere in the neighborhood trees, my replacement was very nearly perfectly balanced. It still had some, as you put it, tick-tocking when I went full throttle. My lesson after another out-of-control flight termination from such behavior is no full throttle.
fred_dot_u is offline Find More Posts by fred_dot_u
Old Jul 10, 2012, 01:45 AM
gitit20 is offline
Find More Posts by gitit20
gitit20's Avatar
Joined May 2012
Mine flies just fine only time i ever get what your talking about is at full throttle the fact is its not brush-less thus not as precise...
however check for twisting of the arms I once split mine down the side and it would twist and cause it to go one direction or the other but not as bad as you described They will twist a bit but should not be very easy to do so more then 1/8 turn if you can get more twist and its easy to do so then you prob should replace you arm. its easy and parts are cheap all over ebay
gitit20 is offline Find More Posts by gitit20
Old Jul 18, 2012, 02:51 PM
topforce is offline
USA
Joined Feb 2002
Alright,, so i replaced all 4 props and its flying much better. I think 1 or 2 of the arms are cracked though. CA did not fix them, and they do twist just a bit more than the other 2 arms.
Old Jul 18, 2012, 11:28 PM
tfmkevin is offline
Find More Posts by tfmkevin
Joined Mar 2011
I just want to know what you did to get it to tick-tock. That would be awesome!!
tfmkevin is offline Find More Posts by tfmkevin
Old Jul 19, 2012, 01:16 AM
topforce is offline
USA
Joined Feb 2002
It was like a reverse tick tock as if the fulcrum were above and the arcing path of the heli was below. It would swing side to swaying and rocking. All I had to do was give full throttle and it would do it. Now with all 4 new props its much better. But the aftermarket body its got has thrown off the balance.
Old Jul 29, 2012, 10:21 AM
topforce is offline
USA
Joined Feb 2002
Well, I crashed the s#$t out of it again.
Old Jul 29, 2012, 10:26 AM
TS00 is offline
Find More Posts by TS00
Ape-pilot Extraordinaire
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
If you don't crash once in a while, you're not flying hard enough
TS00 is offline Find More Posts by TS00
Old Jul 29, 2012, 11:25 PM
gitit20 is offline
gitit20's Avatar
Joined May 2012
Oh ya haha my poor MQX had been to hell and back...
Help! CRASHED my DJI F550 Hexacopter, don't know why. broke a blade but why? jasper7821 Multirotor Talk 26 Jul 11, 2013 12:52 PM
Discussion Why I didn't fly today! ?? Kimber Electric Plane Talk 71 Jul 01, 2012 07:39 AM
Discussion Why Does My Plane Need So Much Uptrim? krexken Electric Plane Talk 18 Jun 30, 2012 04:35 PM
Discussion Why does my smaller motor give more thrust ? DaN_Th3_MaN 3D Foamies 13 Jun 17, 2012 12:50 PM
Discussion Why does my Trex can't fly straight asm_ Mini Helis 9 Oct 23, 2007 09:08 AM
