This thread is privately moderated by ztoon13, who may elect to delete unwanted replies.
Old Jul 06, 2012, 12:53 PM
Gone with the Mistral
ztoon13's Avatar
France, PACA, 13
Joined Jun 2012
my TGY9X settings with WLTv911 & WLT v929
The v911 fp helicopter and the v929 quadcopter are able to fly either in Heli or Acro mode when bind with the stock Turnigy 9X Tx. After testing the 2 options, I found no handling advantages (or more reactivity) in using the acro mode over the heli mode.
SYSTEM (TYPE MODE) HELI TYPE1 - (NAME) v911 Indoor
REVERSE (ELE) REV // reversed elevator is needed
THR/CV
NOR L=0% 1=20% 2=40% 3=65% H=85% // take-off position (full thr isn't necessary)
SUBTRIM (THR) -30% // negative value insure no power when thr hold activate
E. POINT (AIL ELE RUD THR) 100% // 100% is enough indoor
THR HOLD (STATE) ACT - (HLD POS) -30% // negative value insure no power when thr hold activate
AUX-CH (CH5) HOV THR
D/R EXP (AIL ELE RUD OFF) D/R=100 EXP=0 - (AIL ELE RUD ON) D/R=65 EXP=0 // off=enough reactivity on=t/o position, precision flight
FAILSAFE (AIL ELE THR RUD) 000% // failsafe active, THR CUT (back left button) is used to cut both motors (servos still working).
TIMER (STATE) ACT - (MIN) 5 - (SEC) 59 // TRN (back right trigger button) is used to start/stop 6min timer (chime start at 5).
PRO <123>
MIX1 (STATE) ACT - (MASTER) GEA - (SLAVE) RUD - (OFFSET) 000 - (UPRATE) 15 - (DNRATE) 15 - (SW) ON // HOV THR (back right rotating button) is used for RUD fine trim.
MIX3 (STATE) ACT - (MASTER) THR - (SLAVE) AIL - (SW) NOR - (CURVE) L=100% 1=67,5% 2=50% 3=50% H=50% // mix used with thr curve position NOR to (try to...) counter-act the fact that I modified the landing skids. switch to position ID1 directly after t/o (well below 1 feet)
SYSTEM (TYPE MODE) HELI TYPE1 - (NAME) v911 Outdoor
REVERSE (ELE) REV
THR/CV
NOR L=0% 1=40% 2=65% 3=82% 4=90% // take-off position (full thr isn't necessary)
ID1 L=10% 1=30% 2=35% 3=67% H=100% // 'acro mode' (10% thr for fast descent, use with thr cutoff button in mind in case of crash, thr will stay at 10% with thr all the way down)
SUBTRIM (THR) -30%
E. POINT (AIL ELE RUD THR) 120% // 120% is real max end points
D/R EXP (AIL ELE RUD OFF) D/R=100 EXP=00 - (AIL ELE RUD ON) D/R=80 EXP=0
TIMER (STATE) ACT - (MIN) 4 - (SEC) 59 // TRN (back right trigger button) is used to start/stop 5min timer (chime start at 4).
SYSTEM (TYPE MODE) HELI TYPE1 - (NAME) QUADv929 3D
REVERSE (ELE-THR) REV // reversed elevator and thr is needed
THR/CV
NOR L=0% 1=17,5% 2=40% 3=65% H=90% // take-off position (full thr isn't necessary)
ID1 L=12,5% 1=22,5% 2=45% 3=72,5% H=100% // 'acro mode' (10% thr for fast descent, use with thr cutoff button in mind in case of crash, thr will stay at 10% with thr all the way down)
E. POINT (AIL ELE) 120% // 120% only for aileron and elevator (I'm not satisfied about rudder reaction, maybe the only (relative) bad thing about the v929)
D/R EXP (AIL ELE RUD OFF) D/R=100 EXP=25 - (AIL ELE RUD ON) D/R=75 EXP=10 // off=full reactivity on=t/o position
TIMER (STATE) ACT - (MIN) 8 - (SEC) 59 // TRN (back right trigger button) is used to start/stop 9min timer (chime start at 8).
ztoon13 is offline Find More Posts by ztoon13
Old Sep 11, 2012, 04:15 PM
Joined Jul 2012
i entered these values in my FS-TH9X. seems i got something backwards or something.
the left throttle seems to be "ON" even when pulled down all the way. the right lever doesn't respond as planned.
would you have an idea of what i got backwards? thnx
UB6uJ is offline Find More Posts by UB6uJ
Old Sep 11, 2012, 06:50 PM
Yo R Wee Too Lo
United States, OH, Cleveland
Joined Oct 2011
I also am confused. insome setups you use the latters gea and in some gyro. then on the fail safe my ail only shows 50%. you also use different terms for the mix 1 2 and 3 and normal or on or id1 or id2. I did subtrim the throttle to -55. thot hold and cut are also confusing to me.
thanks, pretent you are explaining it to a kid then i will understand
thanks tonytester
tonytester is offline Find More Posts by tonytester
Old Oct 23, 2012, 06:40 AM
ztoon13's Avatar
France, PACA, 13
Joined Jun 2012
Sorry for being blind !
Was away from rcgroup recently and didn't notice your comments last time...
Maybe a video is better than try to speak english for me !
A short one including my settings for my v929.
video here (4 min 12 sec)
Olivier
Old Jan 04, 2013, 08:30 PM
Joined Dec 2012
Rudder mix not working on FS TH9x
Thanks the settings work great on my Trunigy 9x
But p. the fly sky the HOV THR - dial will not slave the rudder
I see the can Gear moving on "display" but nothing I try will link it to slave the rudder
FYI. I can slave the rudder to Throttle or pitch
Is this a fly sky bug?
elementary is offline Find More Posts by elementary
Old Jan 13, 2013, 08:54 AM
Joined Dec 2012
Can not make it work on FS-TH9x
PRO <123>
This works fine on my Turnigy 9x but not on my FS-TH9X,
Does anyone know why?
Is there a way to make it work on the FS-TH9x ????
Old Jan 14, 2013, 01:52 AM
Joined Jul 2012
Originally Posted by elementary View Post
PRO <123>
nope, don't know. but if you get your setting on your FS-TH9x with V911 going well for indoor, post them. would like to compare and try them
Old Jan 14, 2013, 03:56 AM
ztoon13's Avatar
France, PACA, 13
Joined Jun 2012
Hi everybody,
Sorry, I updated my 9X to er9x firmware, so I can't help you anymore.
As I have a turnigy 9X, I don't know about the FS-TH9X (I'm not a TX specialist, I just shared my settings...)
Anyway, feel free to use this thread to share your settings if needed.
Olivier
Video Wife Playing with her new Turnigy Short Course Truck GTiDonavan Car Talk 0 Jun 18, 2012 03:01 AM
For Sale Stop Dreaming, Start Playing! Set: Affinity J Bass® with Rumble 15 AMP - $200 Noob Pilot Coop Non R/C Items (FS/W) 0 Apr 14, 2012 01:52 PM
