Go Back   RC Groups > External Feeds > Mailing Lists > EFLIGHT Mailing List
Old Nov 13, 2003, 04:01 AM   #1
DRR
Guest
Posts: n/a
[EFLT] Using Automotive battery charger as a power supply?
This message from "DRR" <astronut@cinci.rr.com> brought to you by EFLIGHT!
I have read and heard that this should not be done, that it may damage the charger. Why is this so?
--- StripMime Report -- processed MIME parts ---
multipart/alternative
text/plain (text body -- kept)
text/html
*** Any complaints or problems? Send an email to monitor@ezonemag.com
*** For help with list commands go to http://www.ezonemag.com/pages/mailhelp.htm
*** For the list rules go to http://www.ezonemag.com/pages/mailrule.htm
Old Nov 13, 2003, 05:14 AM   #2
radar jammer
Greebe's Avatar
Send a message via ICQ to Greebe Send a message via AIM to Greebe Send a message via MSN to Greebe Send a message via Yahoo to Greebe
because it produces spiky power in so much as it'll tear up the electronics due to being totally unfiltered and half wave rectified. Lead acid batteries don't mind this, but it's next to the worst thing you could do.. the worst would be powering a charger with raw AC
Greebe is offline Find More Posts by Greebe   Reply With Quote
Old Nov 13, 2003, 07:02 PM   #3
Pete Foss
Guest
Posts: n/a
Re: [EFLT] Using Automotive battery charger as a power supply?
This message from Pete Foss <petefoss@yahoo.com> brought to you by EFLIGHT!
> EFLIGHT!
Because there is not enough filtering of the original AC power. You
can usually run a airplane battery charger off a battery that is being
charged however. That will smooth out the power to the airplane charger.
Pete Foss
Skymasters RC of Michigan
http://www.skymasters.org
Old Nov 13, 2003, 07:02 PM   #4
B12Boy@aol.com
Guest
Posts: n/a
This message from B12Boy@aol.com brought to you by EFLIGHT!
It depends on the charger as well. Some are more tolerant of imperfect DC
power than others. I ran my hobbico mark2 charger on my car batt charger for
over a year with no problems other than the fact that since the car chargers
output was not voltage regulated, if I put too high a load on it, ( fast
charging) the car chargers output voltage would drop too far and cause the hobbico
to blow its own fuse.
Slow charging worked fine however.
I'm now using one of the cosel power supplies and no longer have that
problem. $19 well spent IMHO. <A HREF="http://ramboy.com/cosel.htm">Al-Tech</A> Nice to be able to fast charge at home.
Dean in Milwaukee
text/html
Question Using a car battery charger as a power source. What's the problem. Boeingdvr Batteries and Chargers 11 May 05, 2006 08:38 PM
Using my car charger as a power supply question cat5 Batteries and Chargers 24 Nov 17, 2005 09:14 PM
Astro Charger as a Power Supply Jim Keller EFLIGHT Mailing List 2 Dec 01, 2003 07:03 PM
using a car battery charger as a power source? foss1997 Power Systems 14 Jan 10, 2002 10:56 AM
battery charger as 12v power supply sandman Power Systems 6 May 09, 2001 04:15 AM
Bored? Want to fight?
Join the RCGroups clan!
