Old Jul 06, 2012, 07:28 AM
kkphantom is offline
Find More Posts by kkphantom
kkphantom's Avatar
Australia, WA, Perth
Joined Nov 2010
Britkit Build Off. Veron Tipsy Nipper
Here goes the Nipper, I've been as busy as a dog burying a bone in a marble floor lately but things seem to have calmed down so let's see what we can do with this kit. I'm of two minds as to how I want to control this model and how to power it, I've been somewhat inspired by Phil Green and his clever little single channel encoders so I've ordered one and could put it in a s/c push button set. Of course I could go for the safer option and use that in a Mercury Wizard or Veron Sky Skooter that I also have kits for and use my standard 9g servos and Spektrum radio for the Nipper, any suggestions? The second thing of course, is how to power it? I have several electric motors like the one I used in the KK Gipsy or I could dig out one of my diesels and build it as a stinker, I'll see what any of you guys think and carry on building in the meantime.
kkphantom is offline Find More Posts by kkphantom
Old Jul 06, 2012, 07:44 AM
Sundancer is online now
Find More Posts by Sundancer
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
Good-oh Gary. Subscribed and watching with interest, link posted to Build Off thread.
Sundancer is online now Find More Posts by Sundancer
Old Jul 06, 2012, 07:50 AM
Reginald is offline
Find More Posts by Reginald
Reginald's Avatar
Belgium
Joined Aug 2004
I did own a full size Tipsy and a model, not sure if it was Veron but it was powered with an OS FS 160 twin
Reginald is offline Find More Posts by Reginald
Old Jul 06, 2012, 07:55 AM
kkphantom's Avatar
Joined Nov 2010
That might make mine somewhat nose heavy!
Old Jul 06, 2012, 09:55 AM
RFJ is online now
RFJ
Find More Posts by RFJ
RFJ
RFJ's Avatar
Northern Ireland
Joined Dec 2004
May have been the Pegasus kit from the mid 1980s.
A friend of mine built his own 1/4 scale version and flew it in the 1978 Woodvale FAI World Scale Champs. It had flown well in testing apart from being a bit wobbly on the ground due to the rather narrow track sprung undercarriage. Unfortunately it crashed during the event after achieving a very good static score. As I was carrying the wreckage back to the pits a reporter from a Japanese model magazine, thinking I was the unfortunate builder, bowed, put a hand firmly on my shoulder and said (cue stereotypical Japanese accent)... "You be strong man again"
Sound advice I think you will agree and a phrase I still like to use when comforting anyone in a similar situation ...unless it was an ARTF.
Ray
RFJ is online now Find More Posts by RFJ
Old Jul 06, 2012, 10:09 AM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
Saw a 'real' one do an aerobatic routine at an airshow way back in England. Kinda 'slow motion' aeros, but it's a cute aircraft, a little 'different' and good to see this kit re-appear like this.
Would have been inclined to keep the kit and do a little re-arrangement of the internal works with 'modern' balsa to make it lighter, but at least with RC, it'll land with a degree of decorum and not get beaten up like a FF version would. Something like this needs a little more power to do loops and rolls, like the real thing.
Good luck with her
D
Dereck is offline Find More Posts by Dereck
Old Nov 29, 2012, 06:39 AM
kkphantom's Avatar
Joined Nov 2010
Work so far.....
Not a lot to write about, the Valkyrie has taken up so much of my modelling time but I'm determined to get it finished after so many false starts and once its done I can get stuck into all the other models I've been putting off. Anyway, here's the Nipper so far and I guess I should get it done by close of play and for simplicity it will have a little diesel up front and rudder only radio just as she was intended by Phil Smith.
Old Nov 29, 2012, 09:02 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
Glad you are back on the case Gary, it looks as if at least half the work is done - the easy half! Still 5 weeks to go though.
Old Dec 08, 2012, 01:23 AM
kkphantom's Avatar
Joined Nov 2010
I've spent more than a little time on the cowling but I'm pleased with the results. All the carving is done now so it's onto finishing. The fuselage will be traditional tissue and dope, painted in acrylic lacquer and the flying surfaces are going to be covered in tissue over doculam and also painted in white lacquer with red trim.
Old Dec 08, 2012, 06:33 AM
sparks59 is offline
Find More Posts by sparks59
Sic itur ad Astra
sparks59's Avatar
United Arab Emirates, Abu Dhabi, Abu Dhabi
Joined Aug 2009
Good to see the little diesel poking its head out from the cowl!
sparks
sparks59 is offline Find More Posts by sparks59
Old Dec 08, 2012, 07:19 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
Is that a Dart lurking in there? I'm really glad this little classic is going to be in the judging!
Old Dec 08, 2012, 07:20 AM
kkphantom's Avatar
Joined Nov 2010
Thanks Sparks, it's an early Allbon dart, should chug around nicely I reckon!
Old Dec 09, 2012, 10:43 AM
John38 is offline
Find More Posts by John38
Southampton, UK
Joined May 2007
my early red head dart is pulling my 38" span mamselle around free flight on low throttle very easily so you should have no problem with the tipsy.
just dont fill the tank unless you have rc - wonderfulcats 2nd video shows my dart powered mamselle flying on the last 1/8th" bottom of tank here at 8 mins into video http://www.rcgroups.com/forums/showthread.php?t=1781953
john
John38 is offline Find More Posts by John38
Old Dec 10, 2012, 02:39 AM
kkphantom's Avatar
Joined Nov 2010
I'm glad to hear the dart will be powerful enough, I'm going for rudder only, using a Controlaire Mule single channel set converted to 2.4Ghz with one of Phil Green's terrific little actuator emulator set-ups. I've covered the tail surfaces and primed the fuselage, so hopefully I'll make the deadline! I've never used doculam before, It's so easy to apply and get a neat finish, I'm a definite convert! KBO! (hehe)
Build Log Britkit build off Fleetwing 65" rabidrue1 Vintage & Old-Timer Designs 69 Nov 16, 2012 08:23 AM
Build Log Britkit Build Off April 2012 - Veron Deacon cd_webb Vintage & Old-Timer Designs 66 Sep 22, 2012 06:54 AM
Build Log BritKit Build Off 2012 - Mercury Crusader RFJ Vintage & Old-Timer Designs 66 Jul 28, 2012 06:34 AM
Build Log Britkit Build off 2012 -Veron Coupe' sparks59 Vintage & Old-Timer Designs 49 Jul 22, 2012 08:20 AM
Build Log "BritKit" Build Off 2012 - Veron Phoenix RFJ Vintage & Old-Timer Designs 37 Jun 08, 2012 05:28 AM
