Old Jul 27, 2012, 05:47 PM
electricrc68 is offline
Find More Posts by electricrc68
The Sweet Aroma of Fuel
electricrc68's Avatar
United States, PA, Downingtown
Joined May 2011
Okay thank you! Do you think this airframe would be able to work with a puller? I really don't like the noise, and i tried to do what they said in the link to no avail.
electricrc68 is offline Find More Posts by electricrc68
Old Jul 27, 2012, 06:23 PM
balsa or carbon is offline
Find More Posts by balsa or carbon
Hot glue held together by foam
balsa or carbon's Avatar
United States, OR, Portland
Joined Aug 2010
Are you running the motor up indoors or outdoors ? It probably won't be as bothersome outdoors , and you can always use earplugs .
The airframe will work as a puller , but then your motor/prop won't be protected . This guy made his a puller and it looks like he put some kind of skid under the nose .
RC Paper Airplane (part 6) Final Version Flight (3 min 19 sec)
balsa or carbon is offline Find More Posts by balsa or carbon
Old Jul 27, 2012, 07:17 PM
Joined May 2011
Thanks. I ran it outside and inside....both i thought were pretty loud. I mean, i would hate to loose my flying site due to me making too much noise. Its okay if its not protected...i will try my best to be gentle on the maiden. Do you think that i should get some scrap foam and fill up the prop slot again?
Old Jul 27, 2012, 08:10 PM
Joined Aug 2010
I don't think leaving the prop slot open will make much difference aerodynamically .
If you do make it a puller , it will change where you position the battery because the weight of the motor will be all the way up front . So once the motor is attached to the nose , check the CG ( still need to be 14" straight back down center line ) and place the battery on the fuselage in a spot ( forward or backward ) to get the correct CG , the LOWER ( closest to the ground ) the better to have the most pendulum effect .
Old Jul 27, 2012, 08:16 PM
Joined May 2011
Okay thank you. My prop slot is pretty big though....should i still be fine? When you say lower, do you mean it should balance out with the nose down, or am i deciphering that incorrectly?
Old Jul 27, 2012, 08:35 PM
Joined Aug 2010
To have the correct CG , the plane should balance LEVEL on the CG , with the nose no higher or lower than the tail . But placing the battery close ( 1/2" or so ) to the bottom edge of the fuselage will give you the most pendulum effect ( good for self-righting ) . Just think in terms of : if you had a stick sticking straight up from the top of the plane and put the battery at the top of that stick , then if you held the plane by the tail and nose , the weight of the battery would make the plane want to flip upside down ( pendulum effect ) .
Old Jul 27, 2012, 08:50 PM
Joined May 2011
Oh okay thanks. Now about the prop slot again...even if its sort of big, it shouldn't effect the flight characteristics?
Old Jul 27, 2012, 09:03 PM
RCAddict16 is offline
Find More Posts by RCAddict16
United States, VA, Ashburn
Joined Apr 2012
Thinking of building this plane...... what did you use in the way of pushrods? I have a park 450 890 kv, two parkzone DSV130 mg servos, a 30 amp ESC. I would be running an 8x6 on 3S 2200's...... how big should it be?
RCAddict16 is offline Find More Posts by RCAddict16
Reply With Quote  (Disabled)
Old Jul 27, 2012, 10:26 PM
Joined Aug 2010
If you think it might be a problem go ahead and fill it in with some scrap foam .
Old Jul 27, 2012, 10:29 PM
Joined May 2011
Thanks. Thats what i did. Now im going to test the sound tomorrow outside...then im going to see if it would be better with the 8x4 prop instead of the 7x6 i bought as well. Not sure if the 7x6 has enough power to pull the plane...mine became a little heavy. Then, im going to try to maiden it tomorrow.
Old Jul 27, 2012, 10:38 PM
Joined Aug 2010
I use carbon rods for pushrods , but any kind of pushrod used on RC planes will do .
Are you asking how big the plane should be for those electronics ? I would say that if you make it as shown in this thread your electronics will work fine for this plane .
Old Jul 28, 2012, 12:00 AM
Nightstone is offline
Find More Posts by Nightstone
20 years on the Internet
Nightstone's Avatar
Joined May 2012
Got her finished today and did the maiden. Winds were 10 with Gusts to 15. She flew great in the wind. With few airplanes available that a new person can fly in the wind this makes this plane a real "GEM". This is now my windy day trainer. Highly Recommended.
I flew my maiden with no expo thinking the small control surfaces would not make her real responsive. My dihedral also was not very great. She is extremely touchy. Add expo if its your first flight. She is also very fast and you can get yourself into trouble quick.
Thank You for this great and simple windy day flier.
I modified my plane a bit with the control surfaces in the back. I cut off the wing tips. I added an Epp nose add on for rough landings.
Mine is built out of DT Foam. Hot glue gun used. Has no support rods of any kind. Is covered in Heavy duty scotch packing Tape. FC 28-12 Motor, 20a Esc. 2 5g servos and 1 9G for the rudder. 7x6 Prop. 1500Mah 3s. CG is exactly at 14 inches from the nose.
Here are some pics and a video. Audio track was replaced due to wind. Wife got tired of filming half way through but turned it back on for the landing.
video 2012 07 27 19 07 14 (3 min 39 sec)
Nightstone
Nightstone is offline Find More Posts by Nightstone
Old Jul 28, 2012, 01:56 AM
Joined Aug 2010
http://www.youtube.com/watch?v=x_421...ature=youtu.be
Nightstone
I'm glad your SUPER EASY flew well ! Video looks great ! Thanks !
Al
Old Jul 28, 2012, 11:31 AM
Joined Aug 2010
Show us some photos and video if you can !
Al
Old Jul 28, 2012, 12:46 PM
Joined May 2011
Yep i will see if i can! Too hot to maiden it today though. Im also running into another problem...when i start up the motor, the plane pulls down toward the ground...why does it do this? I tried giving it more up thrust, but its still doing this.
Discussion AWESOME landing gear for DJI F550, easy build and totally sturdy, all parts fit great jasper7821 Multirotor Talk 15 Apr 23, 2012 01:52 PM
Discussion Homemade "rectangular" flying wing, flies great,lightweight,easy to build.watch video avlisogeid Flying Wings 25 Nov 05, 2010 07:46 AM
The SoarStar Foamy from Super Flying Models mrm1 Foamies (Kits) 81 Feb 10, 2010 04:22 PM
Rave Great morning of flying with the Easy Star HillRf Electric Plane Talk 11 Jul 16, 2008 06:03 AM
Discussion 3-4 ch easy flying Foamy suitable for light winds blxpy Foamies (Scratchbuilt) 2 Jun 07, 2008 07:05 AM
