Old Jul 23, 2012, 08:46 PM
balsa or carbon is online now
Find More Posts by balsa or carbon
Hot glue held together by foam
balsa or carbon's Avatar
United States, OR, Portland
Joined Aug 2010
Originally Posted by electricrc68 View Post
Nevermind, im going to just use a GWS prop....disregard this post.
Are you flying yet ?
balsa or carbon is online now Find More Posts by balsa or carbon
Old Jul 23, 2012, 08:49 PM
electricrc68 is offline
Find More Posts by electricrc68
The Sweet Aroma of Fuel
electricrc68's Avatar
United States, PA, Downingtown
Joined May 2011
No i still need to order the prop and music wire. Going to order the prop from headsuprc and then ask my LHS to order me the .032" diameter music wire.
EDIT: Well I just ordered the prop and i ordered some music wire from ebay since my dad doesn't want to drive me all the way to the LHS. When they come in, I should be ready for the maiden! Can't wait!
electricrc68 is offline Find More Posts by electricrc68
Old Jul 25, 2012, 04:55 PM
Joined May 2011
Hey, what was the price of the fiberglass reinforced tape that you got? I can't find it at home depot's website so im not sure if they even carry it anymore...
Old Jul 25, 2012, 07:15 PM
Joined Aug 2010
I just bought some at Home Depot ( in the paint department ) , I think it was about $8 .
Old Jul 25, 2012, 07:17 PM
Joined May 2011
Ah okay thanks. I just went there and thats the one i got for $9 after tax as well. Cool!!! I just hinged my control surfaces...now to wait for my prop and music wire to arrive!
Old Jul 25, 2012, 07:41 PM
Joined Aug 2010
If for some reason the music wire takes a long time to get there , you could probably use paper clip wire .
Old Jul 25, 2012, 07:42 PM
Joined May 2011
Oh okay cool thanks. But how would i do that since a paper clip is so small? Attach multiple ones?
Old Jul 25, 2012, 07:51 PM
Joined Aug 2010
One paper clip for Z-bend and one for L-bend , carbon fiber rod ( or bamboo skewer ) in between .
http://www.rcgroups.com/forums/showp...6&postcount=23
Old Jul 25, 2012, 08:09 PM
Joined May 2011
Oh okay thanks. I remember you talking about that....sorry.
Old Jul 27, 2012, 03:21 PM
Joined May 2011
Well i got the prop and music wire in today...will give you a pic when i get it all together!
Old Jul 27, 2012, 04:15 PM
Joined Aug 2010
well i got the prop and music wire in today...will give you a pic when i get it all together!
excellent !
Old Jul 27, 2012, 04:22 PM
Joined May 2011
Hey one thing...i just tested out the motor...its LOUD! Is there any way to quiet it down? I mean, its not too loud, im just worried about the people living near the school i fly at complaining.
Old Jul 27, 2012, 04:43 PM
Joined Aug 2010
Hey one thing...i just tested out the motor...its LOUD! Is there any way to quiet it down? Or maybe it would work as a puller?
Prop -in- slot is going to be a little louder than puller , but the ( BIG ) advantage is that the motor/prop are protected when landing ( or - hopefully not - crashing ) . You can even bring it in for a real nice slow landing ( a little up elevator ) with the prop spinning .
If the noise bothers you a lot you can modify the slot http://www.rcgroups.com/forums/showthread.php?t=1608266
Old Jul 27, 2012, 04:51 PM
Joined May 2011
Thanks i will use that link. Another question..are you sure i must use the 2200mah battery? After calculating something, it seems my flight time will be 13 minutes with a 2200 and 5 minutes with an 800mah. It pulls only 10.4A. Do you think that the 2200 is necessary, or is this all dependent on CG? Also, I think i would like to use this as a puller setup...is this possible?
Old Jul 27, 2012, 05:44 PM
Joined Aug 2010
The CG needs to be 14" from the tip of the nose straight back ( down the center line ) For that airframe to fly well . I'm sure you can achieve that with one 2200mah near the nose , or TWO 800mah all the way up to the nose . If you use the TWO 800mah batteries , plug one in to your ESC and have the other one just go along for the ride for the sake of your CG .
If you wanted to , you could buy or make a parallel harness to connect both 800mah batteries together to make the equivalent of a 1600mah , which will double your flight time . But make ABSOLUTELY SURE it's a "parallel" harness , NOT a "series" harness because a "series" harness doubles the voltage and will toast your ESC .
You can set it up as a puller , but then you risk breaking your propeller - or worse your motor ! Why not go with the prop-in-slot ( that you already have cut in to the airframe ) and protect your prop/motor ?
And don't forget to start with a little up elevator ( reflex ) .
Discussion AWESOME landing gear for DJI F550, easy build and totally sturdy, all parts fit great jasper7821 Multirotor Talk 15 Apr 23, 2012 01:52 PM
Discussion Homemade "rectangular" flying wing, flies great,lightweight,easy to build.watch video avlisogeid Flying Wings 25 Nov 05, 2010 07:46 AM
The SoarStar Foamy from Super Flying Models mrm1 Foamies (Kits) 81 Feb 10, 2010 04:22 PM
Rave Great morning of flying with the Easy Star HillRf Electric Plane Talk 11 Jul 16, 2008 06:03 AM
Discussion 3-4 ch easy flying Foamy suitable for light winds blxpy Foamies (Scratchbuilt) 2 Jun 07, 2008 07:05 AM
