Old Jul 21, 2012, 10:50 AM
balsa or carbon is offline
Find More Posts by balsa or carbon
Hot glue held together by foam
balsa or carbon's Avatar
United States, OR, Portland
Joined Aug 2010
Originally Posted by electricrc68 View Post
Cool thanks. Yes i got my dynam combo. Sorry, what i was trying to ask about the prop mount is, do i just unscrew those two nuts on the shaft and put the prop there, or is there another prop mount/prop saver i must buy? Not sure if this makes anymore sense....
Yes , you can put the prop right on the motor shaft between the flat washers and nuts . Where the prop is located on that plane it is well protected and there is no need for a prop saver .
balsa or carbon is offline Find More Posts by balsa or carbon
Old Jul 21, 2012, 12:30 PM
electricrc68 is offline
Find More Posts by electricrc68
The Sweet Aroma of Fuel
electricrc68's Avatar
United States, PA, Downingtown
Joined May 2011
Okay cool thanks for all the help! Looks like i have no more questions for now, so im going to show you what i have done so far! Let me know how you like it.
(didn't tape any wires down, so thats why the ESC to Motor wires are hanging into the prop slot )
electricrc68 is offline Find More Posts by electricrc68
Old Jul 21, 2012, 01:02 PM
Joined Aug 2010
Looks GOOD! Don't forget to have the numbers/letters on the prop facing the FRONT of the plane . Also , what size batteries do you have and how many ?
Old Jul 21, 2012, 01:17 PM
Joined May 2011
When you say letters facing the front, then do you mean the letters should be facing the motor, or the servos? I have 2 800mah 11.1v gens ace 20c batteries.
Old Jul 21, 2012, 02:09 PM
Joined Aug 2010
Facing the motor , which will be mounted in FRONT of the prop slot .
You're probably going to have to put BOTH batteries up by the nose to get your CG right . The CG should be about 13-14 inches from the tip of the nose straight back down the center line , and don't forget to put in a little up elevator for reflex . Reflex is needed on a delta to slightly push the tail down , which causes the nose to be slightly up so it can "plane" on the air - much like the tips of water skiis needing to be slightly up above the water surface so the skiis can plane on the water .
Old Jul 21, 2012, 02:12 PM
Joined May 2011
Oh okay thanks. I have some 2200mah 11.1v batteries...would those work as well? Or too heavy? Thanks for the tip on putting in some reflex. How do i know when i have put in enough though? Also, where did you get that wood for mounting the motor? Im thinking of just getting that rather than buying a plastic mount.
Old Jul 21, 2012, 05:53 PM
Joined Aug 2010
The 2200mah 11.1v would probably be the best ones to use for this plane , just make sure your CG is about 13-14" straight back ( down the center line ) from the tip of the nose .
Start with about 1/4" up elevator , then trim as necessary on that first flight ( if there is someone experienced who can trim it for you , that might be good ).
The wood I used for mounting the motor is 4 popsicle sticks taped together , put into the motor mount , then I put a wood screw in the little hole ( drill a pilot hole first so the wood doesn't split ) , and then a little hot glue .
Old Jul 21, 2012, 06:39 PM
Joined May 2011
Okay cool thanks!
Old Jul 21, 2012, 06:58 PM
jroth123 is offline
Find More Posts by jroth123
Joined Oct 2011
By thrown, smooth landing, CG position was found about 42% from TE. Is that becouse 2x dihedral?
jroth123 is offline Find More Posts by jroth123
Old Jul 21, 2012, 07:14 PM
Joined Aug 2010
I don't know , but if it flies well - GREAT ! Show us a video if you can !
Old Jul 21, 2012, 10:12 PM
Nightstone is offline
Find More Posts by Nightstone
20 years on the Internet
Nightstone's Avatar
Joined May 2012
Push or pull... Does it matter? Should fly either way right?
Nightstone
Nightstone is offline Find More Posts by Nightstone
Old Jul 22, 2012, 01:22 AM
Joined Aug 2010
Nightstone
It doesn't matter if it's push or pull ( prop behind or in front of the motor ) , but it does matter that the prop is facing the right direction . Most prop blades have a side that curves out ( the side with the numbers/letters on it ) , and the other side that curves in . For the prop to be most efficient ( most thrust ) the " curved out " side needs to face in the direction you want the plane to travel .
Old Jul 22, 2012, 02:06 AM
Nightstone's Avatar
Joined May 2012
Brain fart on my end. Was thinking the motor was turned around. Prop always faces front.
I decided to just get a Y cable and will finish the build tomorrow. Lets keep it tame for a bit. I did build an elevon model a while back and played with it till i toasted it.
Here is a pic
Will do a vid If i can get the wife to film it.
Nightstone
Old Jul 22, 2012, 12:53 PM
Joined Aug 2010
Here is a pic
Nightstone
Looks good!
Old Jul 23, 2012, 07:38 PM
Joined May 2011
Nevermind, im going to just use a GWS prop....disregard this post.
Discussion AWESOME landing gear for DJI F550, easy build and totally sturdy, all parts fit great jasper7821 Multirotor Talk 15 Apr 23, 2012 01:52 PM
Discussion Homemade "rectangular" flying wing, flies great,lightweight,easy to build.watch video avlisogeid Flying Wings 25 Nov 05, 2010 07:46 AM
The SoarStar Foamy from Super Flying Models mrm1 Foamies (Kits) 81 Feb 10, 2010 04:22 PM
Rave Great morning of flying with the Easy Star HillRf Electric Plane Talk 11 Jul 16, 2008 06:03 AM
Discussion 3-4 ch easy flying Foamy suitable for light winds blxpy Foamies (Scratchbuilt) 2 Jun 07, 2008 07:05 AM
