Old Jan 02, 2013, 05:39 PM
balsa or carbon is online now
Find More Posts by balsa or carbon
Hot glue held together by foam
balsa or carbon's Avatar
United States, OR, Portland
Joined Aug 2010
Increased wing area SE
Just made an SE with increased wing area ala Nightstone/psguardian . With an 1800mah 3s it's a real nice , slow floater ! And I like having a little extra room on the keel .
Sorry for the lousy video , it's done with a photo camera that also shoots video - has a small view finder . Saving up for a GoPro !
Large SUPER EASY RC paper airplane (2 min 18 sec)
balsa or carbon is online now Find More Posts by balsa or carbon
Old Jan 02, 2013, 05:47 PM
psguardian is offline
Find More Posts by psguardian
If I build it, it will fly
United States, NY, East Rochester
Joined Jan 2012
I can't wait to get mine in the air.. Might happen tomorrow afternoon.
~psguardian
psguardian is offline Find More Posts by psguardian
Old Jan 02, 2013, 06:24 PM
Joined Aug 2010
~psguardian
Be sure to set up low rates and some expo for the rudder - it's REAL touchy !
Old Jan 02, 2013, 06:36 PM
Joined Jan 2012
Did you reduce the dihedral like I did? I think my peak was only 3.5"-4" off the table. Where did you put CoG on that one?
~psguardian
Old Jan 02, 2013, 06:44 PM
Joined Aug 2010
~psguardian
Yeah , mild dihedral . It still self-rights just fine . CG is just ahead of the prop slot .
Did you see my other post on the SE step by step thread ? I have an extra Y harness if you want it . If you're used to steering with your right thumb , I would stick with that .
Old Jan 02, 2013, 07:02 PM
Joined Jan 2012
Glad the milder dihedral won't make it harder to handle. I'm fine with left stick rudder, thank you for the offer though. I'm starting to give myself whiplash going thread to thread hehe, but this plane is worth it.
~psguardian
Old Jan 04, 2013, 07:48 AM
Banjo5 is offline
Find More Posts by Banjo5
Canada, ON, Merrickville-Wolford
Joined Jun 2012
One trick I used when I was getting ready to transition from a two channel glider to one with ailerons was to mix aileron to rudder at 100% (for the RE glider). Then either stick worked for rudder so I could work on getting used to using my left stick, but the right one was still there for old times sake (aka emergencies).
cheers,
Andrew
Banjo5 is offline Find More Posts by Banjo5
Old Jan 04, 2013, 11:33 AM
Joined Jan 2012
Since i'm doing elevon mixing between the elevator & aileron channels, putting aileron at 000/000 I don't think this will work for me, though I will test it out.
I put her up yesterday, too windy... Don't argue with mother nature when you're flying a cordless kite. She wins almost every time LoL. $2-$3 worth of airframe bit the dust, damage looked less at the field than when I got it home. Might be salvageable, if not oh well hehe $3 was worth the two 5sec arguments with mother nature. If for nothing other than a cheap lesson about calm weather airframes vs more 'resistant' airframes.
Repairing or rebuilding will happen, a calm weather day will be selected for the maiden.
~psguardian
Old Jan 04, 2013, 12:05 PM
Joined Aug 2010
~psguardian
psguardian , since the GSE is meant to be a ( disposable ) practice plane , if you're going to build a new airframe I would leave off the tape covering . Tape over paper just adds unnecessary weight , the paper keeps the foam board stiff enough . I just put some tape on the keel bottom edge for ground contact .
Old Jan 04, 2013, 12:41 PM
Joined Jan 2012
A fine point... I'm soo worried about moisture I over weigh the frame... Tape I use does weigh almost as much as the paper... Rebuild it is, once I get more glue sticks LoL.
~psguardian
Old Jan 04, 2013, 12:57 PM
Joined Aug 2010
~psguardian
Yeah , I noticed on my GSE that when it lands on wet grass only the keel and the front 6" or 8" of a wing come into contact with the wet grass .
Old Jan 04, 2013, 04:06 PM
Joined Jan 2012
No hope of glue sticks today, only 2 left.... REPAIR!!!
peeled bottom of both wings, trimmed fubar portion of keel off, installed servos through foam rather than on foam, added up-trim via control shortening control rods, all better now.
New AUW - 717gr... 25oz!!! I made it!!!
And today is much calmer than yesterday... Maiden maybe this afternoon, maybe tomorrow morning, we'll see how it goes.
~psguardian
Old Jan 04, 2013, 04:35 PM
Joined Aug 2010
~psguardian
Excellent ! Good luck on re-maiden !
Old Jan 04, 2013, 09:08 PM
Joined Jan 2012
Took it out to PIR. Nice n calm. Had up elevator built into the rod length but was still nose heavy. Came in to reposition Batt & knocked motor off. Hot glue & packing tape don't get along LoL. Going to cut tape & paper off of mounting area when I get more glue.
But it did fly a small circuit before popping the mount off.
~psguardian
Old Jan 04, 2013, 10:03 PM
Joined Aug 2010
" But it did fly a small circuit before popping the mount off."
So how did it fly other than being nose heavy ?
Discussion AWESOME landing gear for DJI F550, easy build and totally sturdy, all parts fit great jasper7821 Multirotor Talk 15 Apr 23, 2012 01:52 PM
Discussion Homemade "rectangular" flying wing, flies great,lightweight,easy to build.watch video avlisogeid Flying Wings 25 Nov 05, 2010 07:46 AM
The SoarStar Foamy from Super Flying Models mrm1 Foamies (Kits) 81 Feb 10, 2010 04:22 PM
Rave Great morning of flying with the Easy Star HillRf Electric Plane Talk 11 Jul 16, 2008 06:03 AM
Discussion 3-4 ch easy flying Foamy suitable for light winds blxpy Foamies (Scratchbuilt) 2 Jun 07, 2008 07:05 AM
