Old Sep 11, 2012, 11:42 PM
Nightstone is offline
Find More Posts by Nightstone
20 years on the Internet
Nightstone's Avatar
Joined May 2012
Originally Posted by balsa or carbon View Post
Here is the shorter , wider version of the Simple $ Tree Jet . The original is 20" wide , 30" long . This one is 30" wide , 20" long - makes for a slower roll rate and easier handling .
Looks great Al. It still blows me away that a simple piece of triangular foam flies so well.
Here is a long vid from yesterdays sunset AP flight shot by my wife. Its kinda long and may be a bit boring. But it shows how well the plane flies. Its like a big slow kite. I have it trimmed so that it does big circles in case I have a power issue. The stability is just amazing and blows me away every time I fly it. Btw... check out how slow this plane can fly.
SEAPSunset (16 min 30 sec)
Nightstone
Nightstone is offline Find More Posts by Nightstone
Old Sep 12, 2012, 02:17 AM
balsa or carbon is online now
Find More Posts by balsa or carbon
Hot glue held together by foam
balsa or carbon's Avatar
United States, OR, Portland
Joined Aug 2010
http://www.youtube.com/watch?v=8tJ_0...ature=youtu.be
Nightstone
Awesome plane ! Nice , relaxing flying . Was there any wind ? Sometimes I like the adrenaline rush of speed , other times I like that kind of relaxing flying . A couple of months ago I got this reclining lawn chair from Walmart - great for the long , relaxed flights and easy on the neck !
http://www.walmart.com/ip/Dining-Chairs/12526795
balsa or carbon is online now Find More Posts by balsa or carbon
Old Sep 13, 2012, 03:46 AM
K2XR10 is offline
Find More Posts by K2XR10
ski bum
Joined Oct 2009
I really love your latest changes! I'd like to put one together. Did you make the sweep exactly 45 deg? Do you plan on posting a basic drawing, or a couple more dimensions, like the distance between fuselage strakes or the chord of the elevons?
K2XR10 is offline Find More Posts by K2XR10
Old Sep 13, 2012, 01:55 PM
Joined Aug 2010
Here's the thread for the Simple Dollar Tree Jet ( SDTJ ) .http://www.rcgroups.com/forums/showthread.php?t=1717147
Everything is the same as the original narrow version , I just turned the DT foam board 90* and made the first cuts from top center to bottom left corner , then top center to bottom right corner . Elevons 1 1/2" just like the narrow one , etc. I put the strakes right alongside the prop slot , so how far apart they are depends on how wide you make the prop slot ( which depends on how big your prop is ) . I cut the three points ( nose and wing tips ) off 'cause they seem to just get bent eventually anyway . Making planes is not an exact science for me , I just sort of go for it ! If it works , great ! If not , try something else ! But I learn something every time .
Old Sep 15, 2012, 12:24 PM
K2XR10 is offline
ski bum
Joined Oct 2009
Thank you! I should have realized that you were talking about a different plane.
Do you think your latest modifications to the Dollar Tree Jet or your latest version of the Super Easy results in a better plane? Is the Dollar Tree Jet more of a handful?
Old Sep 15, 2012, 02:47 PM
Joined Aug 2010
The shorter , wider DT Jet has a slower roll rate than the original narrower one , so it is a little easier to handle . If you're comparing both wide and narrow jets to the Super Easy , the SE is MUCH easier to fly than the jets because the SE is a high dihedral wing ( inherent stability ) rudder/elevator slow flyer , and the jets are flat mid wing ( no inherent stability ) elevon speedsters .
Are you building an SE or Simple DT Jet ? If you are a beginning RC flyer go with the Super Easy . If you have some experience flying with ailerons or elevons then go for a jet .
Old Sep 17, 2012, 04:05 PM
Nightstone's Avatar
Joined May 2012
Hey Al
I figured out why some of my planes were having a rough time flying. When I setup elevon mixing in my DX6i I followed an online guide that seemed pretty popular. Lots of thank you's and it worked great etc. Well come to find out the guide was wrong in a few areas. I'm kind of $#%*&^% but ultimately its my own fault. Never take what you read on the internet for granted... Whew...
The first part of the vid shows the servo moving 50% one direction and 100% the other. This is with the rates in both directions kept even on the elev mix. Telling someone to keep them even is a recipe for disaster because as you can see it does not keep them even. As you move the rates up they finally level out at 125%. So they have to be at this level to work properly. Same goes for the Aiel mix.
So... now I know why some of my planes where not pulling up. Bringing those rates down on a first flight was just a recipe for disaster. One would go down and one would not. Real messed up.
Well at least its fixed now and i'm going back to a few of my failed experiments for another go at them. That and rebuilding my f22 since it took the brunt of figuring this out.
Incorrectmix (0 min 30 sec)
Nightstone
Old Sep 18, 2012, 01:44 PM
Joined Aug 2010
Hey Al
http://www.youtube.com/watch?v=5bvC5...ature=youtu.be
Nightstone
Yeah , I still haven't figured out everything on the DX6i yet . Just the other day I learned to use sub trim when doing the initial set up on a plane . And a ( newbie ) flying buddy of mine got himself aDX7 that's even MORE complicated than the DX6i - guess who gets to figure that one out !?! As you said , $#%*&^% !!!
Old Sep 19, 2012, 02:21 AM
Nightstone's Avatar
Joined May 2012
Here is the fix for the DX6i and elevons. It fixes everything correctly. Tried it today and it works great. Not sure if your doing it this way or not. It just really ^$#@% me off that Spektrum has known about the issue for over 4 years now and has not fixed it. I'm sure there are lots and lots of wrecked planes because of this. Totally unacceptable from a company. Will not purchase another one of their products again.
http://www.rcgroups.com/forums/showp...2&postcount=35
Nightstone
Old Sep 21, 2012, 09:00 PM
Joined Aug 2010
Nightstone
I haven't had any problems with elevon mixing on mine . The only problem I've had ( in two years of frequent use ) is two broken trim tabs and one broken menu navigation roller - both easy fixes . Replaced them with metal ones from East RC .
Old Sep 24, 2012, 07:12 AM
Nightstone's Avatar
Joined May 2012
Hi Al
I was experimenting again and came up with this plane... Knowing that you need dihedral to make a rudder work better I started wondering if polyhedral would work as well. Not seeing many delta designs with polyhedral I decided to give it a go. I wanted self righting, Protected prop and motor, Able to handle winds ( Delta ), Something my son in law can fly and not lawn dart in to the ground.
Some things I was unsure of was the effects of the elevated motor and the prop wash across the elevator and rudder. Well it ended up fine.
I ended up with a plane that flies very well at any speed... Check out my hover in landing at the end of the video. This was in calm winds.
Anyway... Plane weighs in at 260 grams with the battery ( Its light ). 7 inch prop on a 2000kv motor. 800mah battery for 9-10 minute flight times. Motor is elevated and orientation could be front or back ( Mine was front ). Polyhedral wing tips are not very large yet provide lots of stability and the rudder works great.
I'm calling it an EMPDelta. Elevated Motor Polyhedral Delta.
I'm going to do a water version with floats underneath too. I think the plane would be perfect for this.
Vid was my maiden.
EM Delta (7 min 54 sec)
Nightstone
Old Sep 24, 2012, 09:41 AM
DuPageJoe is offline
Find More Posts by DuPageJoe
USA, IL, Wheaton
Joined Oct 2010
Nightstone
Great job! Flys good, and motor forward helps with balancing the weight of all that foam in the rear. What are dimensions? Still 30" long X 40" span? Is wing covered with tape or paper? Keeping the dihedral joints at the tips keeps the strength of the sheet across the middle. What is motor wattage rating? Have you gotten your watt meter yet? Prop looks like a GWS EP 7038. Am I right? With 2000 rpm/V, I'm figuring a 2S battery will turn that prop above 10,000 rpm to give enough thrust. Sure flies like there's plenty.
Thanks for the new version.
Joe
DuPageJoe is offline Find More Posts by DuPageJoe
Old Sep 24, 2012, 10:44 AM
Joined Aug 2010
Hi Al
Vid was my maiden.
http://www.youtube.com/watch?v=2jvQd...ature=youtu.be
Nightstone
I like it ! Looks like it would be great for beginning builders/flyers . Looking forward to seeing the water version !
Old Sep 24, 2012, 08:33 PM
Nightstone's Avatar
Joined May 2012
Originally Posted by DuPageJoe View Post
Nightstone
Joe
Thanks Joe
Yep that motor up top is kinda cool. you can put it where ever you want to balance the plane however you want. Size wise its 2 inches smaller than the full size. I cut off 2 inch strips off each wing for the bottom strips. I used scrap for the rudder and EPP/DT sandwich for the mount. Paper is off and the foam is taped. The motor is a HK USA store cheapo using a 3s 800Mah. I just got my watt meter an hour or so ago and should have watt info soon.
Here is a full throttle run I did this morning ( Winds were 5-9 according to airport near by ). It flew surprisingly well at full throttle. No idea how fast it was going but it seemed to be moving right along. It was very stable at full speed with no bad habits that I could see. The video is of it doing laps around my flying field. Its tame enough for my son in law yet fast enough to give the illusion that hes flying a fast plane ( Wink, Wink ).
EmoDelta2 (1 min 53 sec)
Here is the motor. Cheap motor that I really like. Have 3 of these and they work great not to mention being crash resistant.
http://www.hobbyking.com/hobbyking/s...arehouse_.html
Nightstone
Old Sep 24, 2012, 11:53 PM
Nightstone's Avatar
Joined May 2012
Well got to test that motor a few minutes ago. Anyways... So much for Hobby Kings posted specs of 7.3 amps and a 5x3 prop. I'm getting 17.87 amps and 203 watts. I have run this motor with a 6030, 6050, 7030, 7060 prop without blowing them up. I don't do whole flights at full throttle though.
When I got this motor I kind of guessed at the esc and went with a 20a. Glad I did because I really underestimated the amperage this motor pulls. If I had went with HK's specs I would have a cooked ESC right now. well guessing days are over now...
Oh... before I forget. I picked up a Turnigy meter that tests it all.
Nightstone
Discussion AWESOME landing gear for DJI F550, easy build and totally sturdy, all parts fit great jasper7821 Multirotor Talk 15 Apr 23, 2012 01:52 PM
Discussion Homemade "rectangular" flying wing, flies great,lightweight,easy to build.watch video avlisogeid Flying Wings 25 Nov 05, 2010 07:46 AM
The SoarStar Foamy from Super Flying Models mrm1 Foamies (Kits) 81 Feb 10, 2010 04:22 PM
Rave Great morning of flying with the Easy Star HillRf Electric Plane Talk 11 Jul 16, 2008 06:03 AM
Discussion 3-4 ch easy flying Foamy suitable for light winds blxpy Foamies (Scratchbuilt) 2 Jun 07, 2008 07:05 AM
