Old Aug 26, 2012, 11:10 AM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
Just what I need - another project that I didn't design!
This overgrown paper airplane is cute, and there's two sheets of $store board in my shop.
Do you take the paper off the foamboard, or just use it as it comes? From my limited 'foaming', I recall that the paper is a significant portion of the weight of a sheet.
Now I need to have a scrat around for a suitable motor. This could be my second foamie, aft the inevitable NutBall - which everyone seems to have at least one of!
D
Dereck is offline Find More Posts by Dereck
Old Aug 26, 2012, 12:51 PM
balsa or carbon is online now
Find More Posts by balsa or carbon
Hot glue held together by foam
balsa or carbon's Avatar
United States, OR, Portland
Joined Aug 2010
Originally Posted by Nightstone View Post
Al...
Here is the good, bad and broken all over the ground. First vid is my maiden on the revamp. Notice I reduced the size of the elevons. I did not go crazy on this first flight because of the winds. winds were around 10 and very thermal like ( Bumpy ). Flight went fine.
http://www.youtube.com/watch?v=BScmt...ature=youtu.be
Then I let my son in law fly. He claimed he was ready to fly a non beginner plane and one that has no self righting. He did fine on the F-22 I have. But it does not really fly and is more like pushing a chunk of foam around. That and its slower. So anyways... he talked up a storm at the house about how ready he was... a short while later he got a large slice of humble pie.
http://www.youtube.com/watch?v=k12Q3...ature=youtu.be
I'm going to rebuild it this week. I think its a nice stepping stone for me in my quest to get better at flying. My son in law is going back to flying a regular Super Easy.
Nightstone
Enjoyed the first video , Diamond SE flies great ! Second video - whoops ! If you both have the same radio you could use a training wire ( any extension wire 3mm male both ends ) . I use that whenever somebody wants to try one of my jets or 3D planes .
balsa or carbon is online now Find More Posts by balsa or carbon
Old Aug 26, 2012, 12:57 PM
Joined Aug 2010
D
I leave the paper on and add carbon rod reinforcement . Others have taken paper off and put packing tape on . With paper on you'll probably want at least 200 watts , higher kv to keep the prop (slot) small .
Old Aug 26, 2012, 07:30 PM
Nightstone is offline
Find More Posts by Nightstone
20 years on the Internet
Nightstone's Avatar
Joined May 2012
Made a new one for the son in law... I was going to just do a regular one then went a bit wacko on it. 57g motor, 1200kv, 9 inch prop. 800g thrust. Put elevons on it but they are smaller. Also has a bottom KF. Will post vid when we make one. Should do vertical takeoffs with ease. Was lifting off in the living room at 1/2 throttle lol.
I'm calling this one the SEherc.
Nightstone
Nightstone is offline Find More Posts by Nightstone
Old Aug 26, 2012, 08:42 PM
Nightstone's Avatar
Joined May 2012
Okay... That did not work so well lol. That big motor torc's way to much to the left and the elevons do not have enough authority. So the answer is the original RET configuration.
This is how we learn.
Nightstone
Old Aug 26, 2012, 10:51 PM
Joined Aug 2010
Nightstone
Interesting how a little tiny rudder on the keel can do so much !
You know what might be fun to try on an SE - TWIN motors counter-rotating to cancel out each others torque . Now that the idea is my head I'm gonna have to try it ! Only question is - side by side or pusher-puller ....
Old Aug 27, 2012, 01:12 AM
Nightstone's Avatar
Joined May 2012
Pusher puller would be a trip... One on each end.
Nightstone
Old Aug 27, 2012, 01:48 AM
Joined Aug 2010
Nightstone
You make the pusher-puller , I'll make the side by side !
Old Aug 27, 2012, 09:37 AM
eboggs59 is offline
Find More Posts by eboggs59
Arkansas
Joined Dec 2004
Bottom Rudder Effectivness
Balsa or Carbon - I seen that you had mentioned that "how a little tiny rudder on the keel can do so much" in a previous post. That got me thinking about how that would have an effect on the aircraft in regards to directional turning torque. Now I'm not by any means an aircraft designed or anything like that, but I have put together a set of drawings that explains my opinion on the bottom (keel) rudder effectivness. I 'm not sure but I think if the keel design gets hit by a cross wind, it may also tend to roll towards the wind instead of away from the wind like a top rudder might want to do.
Ed
eboggs59 is offline Find More Posts by eboggs59
Old Aug 27, 2012, 12:27 PM
slim1357 is offline
Find More Posts by slim1357
slim1357's Avatar
Joined Dec 2010
D
I prefer paper off for two reasons. It reduces weight and I never have to deal with de-laminations of the paper. Some of my other builds with paper on ( a nutball for example) had issues where the paper would start to pull up and repair was difficult to impossible because of this. With a plane like the super easy though, experimentation is a good idea to see what you like. I find that laminating with clear and colored packing tape both makes the foam less likely to break and provides an orientation aid. I have nosed in my super easy many many times and I can just straighten out the nose and throw her back in the air.
I decided to try some larger batteries with the 3000 kv motor. I have a 5.5x4.5 apc prop and I used both a 2s and 3s 2200 mah battery. The 2s is probably just about perfect although I liked having the extra power that the 3s provided despite the extra weight. Even with the cog in the right spot it still felt a bit leaden and needed lots of power on to maintain flight. I think I prefer the floatiness you get with a lighter setup.
slim1357 is offline Find More Posts by slim1357
Old Aug 27, 2012, 01:26 PM
Joined Aug 2010
Ed
I think you nailed it Ed !
Old Aug 27, 2012, 01:49 PM
DuPageJoe is offline
Find More Posts by DuPageJoe
USA, IL, Wheaton
Joined Oct 2010
Slim
I've been working with the Dollar Tree foam lately, and I made a couple observations that back up what your finding.
A sheet of DT foam with paper on weighs 114 grams (27 grams / sq ft). With paper off, it weighs 53 grams (12.7 grams per square foot), so if you can stand the decreased rigidity you get quite a weight saving.
Adding tape adds weight besides helping rigidity. I used some thin colored packing tape on another project with a 2.3 square foot wing and taping it both sides added 27 grams. That's 5.9 grams per square foot, or nearly 50 grams added to a DT foam sheet taped both sides. You're still ahead 10 grams over the paper covered sheet ant the tape is way more water resistant.
Joe
DuPageJoe is offline Find More Posts by DuPageJoe
Old Aug 27, 2012, 07:27 PM
FlyingW is offline
Find More Posts by FlyingW
Build more, websurf less
FlyingW's Avatar
Long Valley, NJ, USA
Joined Dec 2001
balsa or carbon,
Nice design. I twice tried unsuccessfully over the years to make an electric paper plane. The first time 15 years ago it was too heavy with nicads.
The second time this past Winter. I tried one with the motor on the nose of an airframe of similar size as yours. This one glided well and the elevons controlled her well without power. But when the power was applied, she heeled over to the left every time. After several tries and even dropping her off a second-story deck and powering up after the glide was well established, I conceded that the behavior came from the P-factor forces at the prop. I suppose there is a long moment from the CG to the prop location - so much so that the airplane's aerodynamics at the skinny end cannot overcome the P-factor.
Problem solved with your motor mounted amidships. Probably would still be a problem with a push-pull/front-back arrangement as the front motor would still provide the unwanted sideward forces. Side by side would be fun especially if we could hang the motors on nacelles under the wing so that the props would spin more quietly in clear air.
Thanks for sharing; I've got two pieces of foamboard and your instructions ready to go as well.
Paul
FlyingW is offline Find More Posts by FlyingW
Old Aug 27, 2012, 08:22 PM
Joined Aug 2010
Originally Posted by FlyingW View Post
balsa or carbon,
Paul
Looking forward to seeing your SUPER EASY ! If you can , post a video along with some pictures .
Al
Old Aug 28, 2012, 09:14 AM
Nightstone's Avatar
Joined May 2012
Its been a rough few days for me Al... Son in law drills my DSE2 in and then yesterday my original DSE went in.
I was out flying yesterday. Was being a bit rough and flying hard when one of the elevon control horns broke loose. Horns were made out of cut up floppy disks. Anyways... Not a total loss. bent the nose a tiny bit as she ran into the side of the hill. Had to go get my wife to go fetch her as I stepped on a metal rod from one of the grand kids toys over the weekend and its not fully healed yet.
I thing i'm going to go with 2 horns per elevon on the rebuild. Split them and Y them together. Should work okay right?
I really like that original diamond shaped plane. Slow, fast and highly maneuverable.
Nightstone
Discussion AWESOME landing gear for DJI F550, easy build and totally sturdy, all parts fit great jasper7821 Multirotor Talk 15 Apr 23, 2012 01:52 PM
Discussion Homemade "rectangular" flying wing, flies great,lightweight,easy to build.watch video avlisogeid Flying Wings 25 Nov 05, 2010 07:46 AM
The SoarStar Foamy from Super Flying Models mrm1 Foamies (Kits) 81 Feb 10, 2010 04:22 PM
Rave Great morning of flying with the Easy Star HillRf Electric Plane Talk 11 Jul 16, 2008 06:03 AM
Discussion 3-4 ch easy flying Foamy suitable for light winds blxpy Foamies (Scratchbuilt) 2 Jun 07, 2008 07:05 AM
