Old Aug 22, 2012, 04:27 PM
Nightstone is offline
Find More Posts by Nightstone
20 years on the Internet
Nightstone's Avatar
Joined May 2012
Originally Posted by tripleup05 View Post
Over on the Adrenaline Rush thead (http://www.rcgroups.com/forums/showthread.php?t=380270) we run the 3000kv version on our little hotliners. Most use a 4.75x4.75 prop with a 800mah 3S. It makes for a killer combination! It draws around 20amps, and I don't know if there has been a motor failure yet. I'm not sure why Hobby King specs it so low, but it can take some abuse!
Thanks Man... Thats what I want to hear. I have 3 3s 800mah batteries. Just don't want to cook it right after getting it.
I love this hobby!!!!
Nightstone
Nightstone is offline Find More Posts by Nightstone
Old Aug 22, 2012, 04:44 PM
DuPageJoe is offline
Find More Posts by DuPageJoe
USA, IL, Wheaton
Joined Oct 2010
Nightstone
I hope those 800mAh batteries are rated at least 25C, if Slim's 20 A draw is correct.
Do you use a Wattmeter?
Safety First
Joe
DuPageJoe is offline Find More Posts by DuPageJoe
Old Aug 22, 2012, 06:10 PM
slim1357 is offline
Find More Posts by slim1357
slim1357's Avatar
United States, OR, Portland
Joined Dec 2010
Nightstone
I plan on making a 1/2 or 3/4 scale super ez and putting the 3000kv motor on that too. Make sure your batteries are well secured. I lost my last 2 1000mah 3s batteries pulling Gs.
slim1357 is offline Find More Posts by slim1357
Nightstone's Avatar
Joined May 2012
Originally Posted by DuPageJoe View Post
Nightstone
Safety First
Joe
They are rated 20-30c so should be okay if I don't go WOT The whole flight.
Nightstone
Old Aug 22, 2012, 06:11 PM
slim1357 is offline
slim1357's Avatar
Joined Dec 2010
Al I've been thinking these would be fun for combat. Maybe streamers or just trying to bash the other guy out of the air?
Old Aug 22, 2012, 07:12 PM
balsa or carbon is online now
Find More Posts by balsa or carbon
Hot glue held together by foam
balsa or carbon's Avatar
Joined Aug 2010
Let's do it! I think other Tim would go for it , he loves using his SE for just screwing around - flying under goals , spiraling down until it almost hits the ground then pulling out of it , etc. The SE design will probably save the electronics most of the time if it goes down hard .
balsa or carbon is online now Find More Posts by balsa or carbon
Old Aug 22, 2012, 08:48 PM
tripleup05 is offline
Find More Posts by tripleup05
tripleup05's Avatar
United States, GA, Grayson
Joined Mar 2008
Nightstone
Safety First
Joe
On the Adrenaline Rush thread, Hance was originally recommending the Turnigy Nano-Tech 460mah 25C-40C for the 3000kv Blue Wonder/Turnigy/Hextronic (whatever you want to call it). They weren't holding up that well for those who flew often. When Hobbyking released the 850mah 40C (http://www.hobbyking.com/hobbyking/s...arehouse_.html) most went to that battery, and it has worked out great.
tripleup05 is offline Find More Posts by tripleup05
Old Aug 22, 2012, 08:56 PM
tripleup05's Avatar
Joined Mar 2008
Quick and dirty with supplies on hand. 3000 kv version of blue wonder motor. 4.75x4.75 prop. Took about 3 hours with a few beer breaks. Maiden tomorrow AM.
Is that a full size SE, Slim? I have cut mine out and put packing tape over it. Now all I have to do is assemble the sucker. I just can't see the little 4.75x4.75 driving this thing, though!
Old Aug 23, 2012, 01:02 AM
Nightstone's Avatar
Joined May 2012
Over on the Adrenaline Rush thread (http://www.rcgroups.com/forums/showthread.php?t=380270) we run the 3000kv version on our little hotliners. Most use a 4.75x4.75 prop with a 800mah 3S 40C. It makes for a killer combination! It draws around 20amps, and other than crash damage, I haven't read about a single motor failing. Not that it hasn't (or couldn't) happen, but I haven't read any complaints, and many of us are running that setup. I'm not sure why Hobby King specs it so low, but it can take some abuse!
I looked at some of those videos in that thread. Holy cow do those things move. You can barely see the thing flying. Cool link man.
Nightstone
Old Aug 23, 2012, 11:39 AM
praymond is offline
Find More Posts by praymond
praymond's Avatar
New Hampshire-seacoast area
Joined Jun 2005
Has anyone used a 1500kv blue wonder yet? I'd think that would be a good motor for a full size EZ with a 7x6 APC style prop on 3 cells. if not not built too heavy
praymond is offline Find More Posts by praymond
Old Aug 23, 2012, 03:17 PM
Nightstone's Avatar
Joined May 2012
I was on hobby king today looking at my AX-2306N-2000 motor. There is not much info on it. When at the bottom of the page I see " Click here to see all reviews". Duh... I realize now that alot of these posted specs are not all together fully correct. Folks in there were running 7x6 props on this motor. Big difference from my 6x3. So I went out with a 6x5 prop. Big difference. Motor was totally cool.
Battery was hot though.
How hot is too hot for a battery? These were 3s 800mah 20-30c.
This is making me realize I need some higher C batteries prior to making a rocket with that 3000 kv motor. That and a watt meter.
Nightstone
Old Aug 23, 2012, 04:25 PM
USA, IL, Wheaton
Joined Oct 2010
Weight of real DollarTree foam board
Back on Post #126, I described the start of my Super Easy build with some foam board from my basement stock which was marked Elmer's and weighed about 230 grams per 20 X 30 inch sheet (1.95 ounces/sq ft) with the paper on.
http://www.rcgroups.com/forums/showp...&postcount=126
Today, I found my closest Dollar Tree, and they had foam board from R.L. Adams Plastics of Wyoming MI that weighed 114 grams per sheet (0.97 ounces/ sq ft) with the paper on. Considering that the full size Super Easy uses a bit over 5 square feet of foam board I could have saved about 5 ounces by picking the right source.
Your scale is a good friend, you just got to use it.
Joe
Old Aug 23, 2012, 04:48 PM
USA, IL, Wheaton
Joined Oct 2010
LiPo Battery Temperature
Nightstone
According to the LiPo safety guidelines in my Venom Charger manual, the maximum discharge temperature is 140 F or 60 C. That's fairly hot to the touch.
You need to let the battery cool befire re-charging, though, because the maximum charging temperature is 110 F or 43 C.
You might find similar guidelines from a battery supplier like Thunderpower.
Joe
Old Aug 23, 2012, 05:00 PM
Joined Aug 2010
Nightstone
Hobbyking USA has these high c batteries http://www.hobbyking.com/hobbyking/s...dProduct=24210 and Banana Hobby has these http://search.bananahobby.com/psearc...hQueryId=82416
Old Aug 24, 2012, 12:53 AM
Nightstone's Avatar
Joined May 2012
DSE Version 2 built and ready for maiden tomorrow. Will get a wife vid. Went with 9 Gram servos. Lots of color lol. Using that motor that was on the first one with a 7x6 prop hope its not too much for it. its a 2000kv motor. It should be quick ( At least at my skill level ). Made this plane Flat with no dihedral. Added a spar. Large KF on top. Small KF underneath.
Should be interesting...
Nightstone
Discussion AWESOME landing gear for DJI F550, easy build and totally sturdy, all parts fit great jasper7821 Multirotor Talk 15 Apr 23, 2012 01:52 PM
Discussion Homemade "rectangular" flying wing, flies great,lightweight,easy to build.watch video avlisogeid Flying Wings 25 Nov 05, 2010 07:46 AM
The SoarStar Foamy from Super Flying Models mrm1 Foamies (Kits) 81 Feb 10, 2010 04:22 PM
Rave Great morning of flying with the Easy Star HillRf Electric Plane Talk 11 Jul 16, 2008 06:03 AM
Discussion 3-4 ch easy flying Foamy suitable for light winds blxpy Foamies (Scratchbuilt) 2 Jun 07, 2008 07:05 AM
