Espritmodel.com Heli Air
Old Aug 20, 2012, 02:21 AM
Do You Grok This
Nightstone's Avatar
United States, AZ, Phoenix
Joined May 2012
Originally Posted by balsa or carbon View Post
That's frustrating ! Do you have any airframes built ?
Not yet... painted a bunch of foam over the weekend. The rest will go fast once the parts get here.
Nightstone
Nightstone is offline Find More Posts by Nightstone
Old Aug 20, 2012, 02:14 PM
tripleup05's Avatar
United States, GA, Grayson
Joined Mar 2008
Think one of the "blue wonder" type of motors would work on this plane?
http://www.hobbyking.com/hobbyking/s...idProduct=8617 1300kv
http://www.hobbyking.com/hobbyking/s...idProduct=8618 1500kv
http://www.hobbyking.com/hobbyking/s...idProduct=8619 1700kv
http://www.hobbyking.com/hobbyking/s...idProduct=8620 3000kv
tripleup05 is offline Find More Posts by tripleup05
Old Aug 20, 2012, 04:14 PM
USA, IL, Wheaton
Joined Oct 2010
I think you would want to build a standard sized Super Easy as light as possible, if you wanted to use these motors as they are all well under 100 Watts input power. The 1500 Kv one has max current spec of 8 Amps with a 3S battery, and the thrusts seem awfully optimistic.
If you take the paper off Dollar Tree foam and use as little reinforcement as possible, I think you might be able to do it.
Look at Nightstone's tape covered, no paper, version earlier on.
DuPageJoe is offline Find More Posts by DuPageJoe
Old Aug 20, 2012, 07:23 PM
or maybe foam
balsa or carbon's Avatar
United States, WA, Vancouver
Joined Aug 2010
Originally Posted by tripleup05 View Post
Slim1357 made one with the 3000kv Blue Wonder - it does VTO's !
http://www.rcgroups.com/forums/showt...7#post22377737
http://www.rcgroups.com/forums/showt...4#post22381464
balsa or carbon is offline Find More Posts by balsa or carbon
Old Aug 20, 2012, 09:16 PM
USA, IL, Wheaton
Joined Oct 2010
Thanks for the reminder Al
Looks like Slim took the paper off the foam board to save weight. He also took a chance using a 3S battery. The Hobby King Specs say 2S only. Using the small prop must have kept the motor from toasting.
Joe
Old Aug 20, 2012, 11:22 PM
or maybe foam
Joined Aug 2010
Joe
Yeah , I noticed that about the 2S in the specs !
Old Aug 21, 2012, 12:54 AM
Do You Grok This
Nightstone's Avatar
Joined May 2012
I put this on my original. 730g of thrust on a 7x6 prop. It was way overkill with the paper off.
http://www.hobbyking.com/hobbyking/s...idProduct=5423
I have this motor on the Diamond SE with elevons. Goes vert with no issues on a 6x3 3s.
http://www.hobbyking.com/hobbyking/s...cro_Motor.html
These are both very cheap motors and perform really well. I liked the quality of the Emax so much I picked up a 28-05 and a 28-22.
Nightstone
Old Aug 21, 2012, 01:24 AM
Do You Grok This
Nightstone's Avatar
Joined May 2012
Got my motors/esc's in Al. Did the soldering tonight. Got consulting over the next few days so may be the weekend before I can build again. Its coming...
Nightstone
Old Aug 21, 2012, 01:15 PM
or maybe foam
Joined Aug 2010
Nightstone
Awesome ! So you're going for more speed on the next build , right ? If you're curious about the speeds you're getting , there are cell phone apps that listen to the sound of your jet going by and calculate the speed from the doppler effect . There's also a device that you can put on the plane that uses GPS to give you a readout of your top speed .http://www.velocity-rc.com/cgi-bin/v...59&cid=3&idx=1
Old Aug 21, 2012, 10:14 PM
slim1357's Avatar
United States, OR, Portland
Joined Dec 2010
Joe
I used packing tape to laminate the foam after peeling the paper off. Gives it a lot more resiliency IMO. The 3000 kv motor is fun but is a trade off between flight time and raw power. I have a 5x5 prop on it now and I get like 2-3 minutes tops on a 450 mah 3s. I get about 5 with an 800 mah 2s but it can't VTO.
slim1357 is offline Find More Posts by slim1357
Old Aug 22, 2012, 02:16 AM
Do You Grok This
Nightstone's Avatar
Joined May 2012
I just got that motor. Can it handle a 3s? Some folks were reporting burning the motors up because of the fine wire.
I'm just now realizing that the higher amperage draw will deplete batteries faster. Most of my current motors are 15a and below. Now I have 2 that will run in the 20's but suck my batteries dry in an instant. I may have to order a few bigger batteries.
Im really liking this motor so far. Seems like the best of both worlds. Cheap too.
http://www.hobbyking.com/hobbyking/s...idProduct=5428
Nightstone
Old Aug 22, 2012, 02:19 AM
Do You Grok This
Nightstone's Avatar
Joined May 2012
Speed on the next build. Will more than likely have short flight times due to the amp draw. I'm going to go with another 3/4 size model. I have 2 smaller 3k kv motors now.
Nightstone
Old Aug 22, 2012, 08:00 AM
tripleup05's Avatar
Joined Mar 2008
Joe
Over on the Adrenaline Rush thread (http://www.rcgroups.com/forums/showthread.php?t=380270) we run the 3000kv version on our little hotliners. Most use a 4.75x4.75 prop with a 800mah 3S 40C. It makes for a killer combination! It draws around 20amps, and other than crash damage, I haven't read about a single motor failing. Not that it hasn't (or couldn't) happen, but I haven't read any complaints, and many of us are running that setup. I'm not sure why Hobby King specs it so low, but it can take some abuse!
Old Aug 22, 2012, 12:23 PM
or maybe foam
Joined Aug 2010
Nightstone
Yeah , that's the trade-off for the need for speed - shorter flight times . But what an exciting 3-4 minutes , especially when you can hear people watching go "WHOAA!!!"
Old Aug 22, 2012, 04:23 PM
Do You Grok This
Nightstone's Avatar
Joined May 2012
Built a quick f-22 a day or so back and test flew it this morning ( 3 flights ). I was dissapointed. After flying that Diamond shaped SE I guess im spoiled now. The F-22 was less maneuverable, Took alot more throttle to fly with the same motor, Could not fly as slow. Felt more like I was pushing a chunk of foam around versus flying a plane. It sure looks nice and seems real popular but I don't think its a keeper. Just not my flying style.
That KFm wing really makes a difference. Now I think I know where my next design is going to go as far as the SE goes...
Plane number 3 is on the Way lol.
Nightstone
Discussion AWESOME landing gear for DJI F550, easy build and totally sturdy, all parts fit great jasper7821 Multirotor Talk 15 Apr 23, 2012 01:52 PM
Discussion Homemade "rectangular" flying wing, flies great,lightweight,easy to build.watch video avlisogeid Flying Wings 25 Nov 05, 2010 07:46 AM
The SoarStar Foamy from Super Flying Models mrm1 Foamies (Kits) 81 Feb 10, 2010 04:22 PM
Rave Great morning of flying with the Easy Star HillRf Electric Plane Talk 11 Jul 16, 2008 06:03 AM
Discussion 3-4 ch easy flying Foamy suitable for light winds blxpy Foamies (Scratchbuilt) 2 Jun 07, 2008 07:05 AM
