Old Jul 05, 2012, 03:57 PM
Ich Bin is offline
Find More Posts by Ich Bin
Ich Bin's Avatar
Appleton, WI
Joined May 2009
Help!
Anyone have any 0% fuel I can buy?
I didn't realize how hard it would be to find castor oil for the methanol. I got several gallons of methanol from the race track, but now I can only order the high end oil online. Also the only castor oil I can find locally is at walgreens for $5 per 4 oz. That is way expensive.
So if anyone has any I could buy to get me through the weekend, until my oil arrives next week I would appreciate it.
Eric Heinz
Call my cell please. 920- four, seven, zero, 41 eight seven.
Ich Bin is offline Find More Posts by Ich Bin
Old Jul 05, 2012, 07:42 PM
tr miller is offline
Find More Posts by tr miller
T.R. miller
tr miller's Avatar
USA, WI, Appleton
Joined Nov 2008
I think galaxy has klots, did you try there?
tr miller is offline Find More Posts by tr miller
Old Jul 05, 2012, 10:08 PM
Jason_WI is offline
Find More Posts by Jason_WI
Cox Engine Hoarder
Jason_WI's Avatar
Neenah, Wisconsin, United States
Joined Jun 2004
I remember seeing castor oil at Walmart in the pharmacy section. Make sure it is without sugar added. It may not be degummed as well as the SIG castor and can varnish up faster on a hot day. I think it is a wash mixing your own fuel. Does the race track have nitro methanol there?
Jason
Jason_WI is offline Find More Posts by Jason_WI
Old Jul 06, 2012, 11:15 AM
knighttwister is offline
Find More Posts by knighttwister
end user
knighttwister's Avatar
USA, WI, Neenah
Joined Feb 2006
wade should have the castor you need.
knighttwister is offline Find More Posts by knighttwister
Old Jul 06, 2012, 12:18 PM
Ich Bin is offline
Ich Bin's Avatar
Appleton, WI
Joined May 2009
Thanks everyone, I bought Craig's remaining supply.
also Galaxy does have Klotz. Only the 20% castor though, and the full synthetic. I bought the last 20% castor quart he had. Galaxy did not have pure castor, but since he stocks Klotz, they make a pure castor, FYI. I have enough castor to break it in, and enough 20% castor, to run for awhile. Then I can have Wade order some Klotz pure castor for when my current stock runs out.
Should have called Galaxy. Didn't think they would stock Klotz in a million years.
Old Jul 06, 2012, 12:20 PM
Ich Bin is offline
Ich Bin's Avatar
Appleton, WI
Joined May 2009
Jason
The race track does not sell it. I went on a saturday, and bought some off a guy who uses it in his dragster. Just went into the pits, and asked around. He claims there is a speed shop in DePere where you can buy it, for about $3 per gallon. When I googled it, I couldn't find the exact business or location.
Eric
Old Jul 07, 2012, 11:14 AM
Cykhoi1 is offline
Find More Posts by Cykhoi1
James Gang #1
Cykhoi1's Avatar
USA, WI, Appleton
Joined Jan 2005
FYI Eric, If you're running this in you're Moki 2.1, Byron's Originals used to market an FAI "SuperTigre blend" that was 60/40 Castor/Synthetic blend (total 16% oil) that was recommended for Mokis if they were already broken-in. I remember running some through mine as a trial once with good results (22X8 prop).
If memory serves me correct (BIG IF) Soap grade Castor is de-gummed well enough to use for lube. This link is a source.
http://www.soapgoods.com/Castor-Oil-...-226.html#desc
16 Gal castor is $336 (using 10oz castor per gal of mixed fuel= 204 gal treated @ $1.65 per gal + cost of syn oil.). Good group rate maybe
Also, I used to buy methanol at the Speed shop in Freedom for about $3.00/ gal. Not sure if it's still available.
BTW, I've got about a quart & half of Sig Castor sitting on my shelf you can have.
Cykhoi1 is offline Find More Posts by Cykhoi1
Wanted These blades-anyone have any? SCOOTER4lyf Aircraft - Electric - Helis (FS/W) 7 May 09, 2012 03:27 AM
Discussion Help I can't find any info on this engine anywhere can anyone help? wet banshee Engines 6 Mar 11, 2012 09:11 AM
Discussion Does anyone have any experience rewinding an E-flite 450 motor? 3D Romeo Electric Motor Design and Construction 0 Mar 10, 2012 11:42 PM
Discussion Anyone have any experience with these motors? steest Foamies (Scratchbuilt) 16 Mar 10, 2012 11:14 PM
Discussion Anyone know where I can buy 0.03 solid carbon sheets bfraser Composites Fabrication 14 Aug 17, 2005 09:48 AM
