Old Jul 05, 2012, 03:39 PM
ailevin is offline
Find More Posts by ailevin
Redondo Beach, CA
Joined Jan 2007
Question
450 Thread Lock and Maintenance (Answered)
I recently built a 450 Sport V2 super combo--great kit and happy with the heli. I am still in hovering and beginning front to back and side to side movement. As I've said elsewhere, if I am doing any 3D it is because I've lost control.
I check over the heli after each outting, and I often find something that has come loose even though I have used the blue thread lock. It's usually not "falling out" loose, but when I give it a little tension check it just isn't tight anymore. So far the culprits have been, an inner swash ball, a lower mixer arm pivot screw, and the screw that holds one of the bearings that the flybar rocker arm rocks on.
Am I doing something wrong with the thread lock, or should I expect a certain rate of thread locked parts becoming loose?
Alan
ailevin is offline Find More Posts by ailevin
Old Jul 05, 2012, 05:47 PM
Dr.M is offline
Find More Posts by Dr.M
Dr.M's Avatar
United States, WA, Issaquah
Joined May 2011
Oil is the enemy of threadlock. Clean the screws with alcohol before installation. Put threadlock on "inside" threads whenever possible, such as inside nuts or threaded mounting holes.
Then, for those screws that are close to bearings or other oiled parts, expect that oil will seep in and the threadlock will eventually fail. Check feathering shaft bolts and tail grip bolts/nuts often - you don't want those to come flying out in the air.
Congrats on your attentive maintenance though. Do keep an eye on all screws. I check all screws on all my helis every 15 flights or so just to make sure they still sit well.
Dr.M is offline Find More Posts by Dr.M
Old Jul 06, 2012, 02:48 PM
ailevin is offline
Redondo Beach, CA
Joined Jan 2007
Thanks for the quick response. Oil vs. thread lock explains the areas of loosening that I've seen. Also, I did not methodically clean each part in alcohol before applying thread lock during the build.
While I am asking questions, do thread locked screws and bolts have to be torqued down at all, or is snug plus thread lock enough?
Alan
Discussion Any recommendations for thread lock compund dwhall47 Beginner Training Area (Heli-Electric) 1 Jun 28, 2012 03:39 PM
Discussion Best methods of Thread Locking? Best types of threadlock? carl1864 Beginner Training Area (Aircraft-Electric) 5 Jun 21, 2012 05:04 PM
Question Taking over a locked sticky thread. Jonathan Bradbury Site Suggestions / Complaints 1 May 09, 2012 05:57 PM
Mini-HowTo Thread Lock Tutorial For Helis frivilousteamrc Beginner Training Area (Heli-Electric) 1 Mar 30, 2012 11:45 PM
Discussion Thread Lock Rotor Head 450 clone Dannyrevs Electric Heli Talk 5 Feb 11, 2011 05:57 AM
