View Poll Results: Will this RC Harrier jet ever be built or work?
I think it will work. I have 20$ to burn so here you go. 8 14.55%
I think it will work but you don't have the skills to do it so no $ for you. 4 7.27%
I would help with sponsorship but your plane kind of looks like crap. 4 7.27%
LOL another dead Harrier thread! Nice try loser. Get a job and buy your own damn stuff. 39 70.91%
Voters: 55. You may not vote on this poll
Old Dec 30, 2012, 08:33 AM
Winging it Ò>
leadfeather's Avatar
Joined May 2006
Congratulations! Looks really good.
Will the Chinese need to invest the full $20 to get the plans and secrets?
leadfeather is offline Find More Posts by leadfeather
Latest blog entry: Quick Stick
Old Dec 30, 2012, 03:11 PM
RCvertt's Avatar
Joined Aug 2007
Originally Posted by Marlbororman View Post
That flys really nice mate. Looks like you got it dialed in too. Love the vertical take off and landing too.
Edit... I would be frightened to fly with all them light posts about though lol
Thanks. It works better than I thought it was going to
It's a four diamond baseball park so it's fairly big. Gets a little tight when in forward flight though since the plane goes much faster. The plane is so small that you wouldn't be able to see it if it went much further. I have plans to to fix that eyesight problem though
Thanks!
China gets it for the low price of 10$ if they act now. Lockheed still has a chance for the low low price of 2 million.
RCvertt is offline Find More Posts by RCvertt
Old Dec 31, 2012, 07:16 AM
Winging it Ò>
Joined May 2006
$10 for this technology is a great deal for China.
Seriously though, folks who have not attempted a transitioning VTOL aircraft will not appreciate what a great achievement you have made here. Transitioning VTOL is one of the most difficult thing you can do in RC, and to do what you have done with only two motors/fans is really great and impressive.
I noticed that fans are tilted inward quite a bit. Is this part of the "secret technology" or is the stable hovering due to something else? Or do I need to line up behind Lockheed and China with money in hand to find out?
Old Dec 31, 2012, 10:05 AM
touch 'n go or slam 'n stop?
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
Looks like possibly the fans tilt inwards from the force of the thrust bowing the foam wing upwards a bit.
bhoov128 is offline Find More Posts by bhoov128
Old Jan 02, 2013, 07:27 PM
RCvertt's Avatar
Joined Aug 2007
Thanks for the kind words LF. bhoove is right. To save on weight there is no carbon rod in the wing so it and the pods flex a little under the weight of the aircraft when hovering. It adds some stability in forward flight I think since it acts like dihedral. I have a little more testing to do before I release the secret sauce.
Old Jan 26, 2013, 08:04 PM
RCvertt's Avatar
Joined Aug 2007
Osprino had his last flight yesterday due to a lost prop saver in flight. The plane suffered a lot of damage but not to worry as thankfully the prop floated safely to the ground with no damage
I'll try to get the vid uploaded to my youtube channel but probably won't post the vid here as my language gets a little colorful at the end as I express my deep admiration for for prop savers.
Old Jan 26, 2013, 08:49 PM
Retardedly intelligent
foam and tape's Avatar
beavercreek,ohio
Joined Jan 2007
Ouch!!! damn that plane was doing awesome. I've had that prop launch happen with one of my tri copters, They sure can spin fast once a prop is thrown. At least V2 will be better! (and switch out for a shaft setup or prop collets)
Youtube! Youtube! Youtube!
foam and tape is offline Find More Posts by foam and tape
Old Jan 26, 2013, 09:21 PM
United States, AZ, Tucson
Joined Nov 2010
you should definitely post plans, files, programming and tips to build that harrier....
Jwmflying14 is online now Find More Posts by Jwmflying14
Old Jan 27, 2013, 04:16 AM
Damn this gets addictive.
Thechittyfather's Avatar
United Kingdom
Joined Oct 2011
Damn. Sorry to hear about the osprino.
Hope nothing but foam was damaged. Looking forward to V2
Thechittyfather is offline Find More Posts by Thechittyfather
Old Jan 27, 2013, 08:10 AM
Winging it Ò>
Joined May 2006
I'll try to get the vid uploaded to my youtube channel but probably won't post the vid as my language gets a little colorful a the end as I express my deep admiration for for prop savers.
Prop floated safely to the ground, sounds like the prop saver worked.
I've had the same thing happen a couple of time on a Tricopter. I stuck with the prop savers but I swapped in longer prop saver bolts and double up on the rubber bands; so far so good.
Too bad about the crash. Your work with bicopter stability is really good. Don't give up! VTOL still needs all the pioneers it can get.
Old Jan 28, 2013, 02:08 PM
RCvertt's Avatar
Joined Aug 2007
Originally Posted by foam and tape View Post
...Youtube! Youtube! Youtube!
Check my youtube channel for Last Flight Of The AwesomSprey Definitely going with collets soaked in red lock tight or motors with threaded shafts.
Originally Posted by Jwmflying14 View Post
...you should definitely post plans, files, programming and tips to build that harrier....
It's a strange looking Harrier at the moment but I'll work on making that info available.
Originally Posted by Thechittyfather View Post
...Hope nothing but foam was damaged...
Just my confidence and general will to live, but nothing important
I need a plane saver I will give a shout out to GWS though. These 8 inch three bladed props work great. Very light an strong compared to others I have seen. Looks like they only go up to 10 inches though and I'm thinking of going with 13 inch if I can find some. Master Airscrew are the only 13 inch ones I have seen but they are a little heavier than the GWS so I'm not sure about them.
Old Jan 28, 2013, 02:25 PM
Joined Nov 2010
hmm... I was more interested in the V22 Osprey!
Old Jan 29, 2013, 11:37 PM
RCvertt's Avatar
Joined Aug 2007
It's glued back together and flyable again. I'm working on making the Osprey info available.
Note to self. Don't put a poll in your thread again
Old Jan 30, 2013, 02:24 AM
United Kingdom
Joined Oct 2011
Nice one mate. So the R and D for the harrier continues.
Have you done any more work on it or have you just been concentrating on the Osprino?
Old Jan 30, 2013, 01:41 PM
bhoov128's Avatar
Joined May 2012
If I had my guess, the osprino is research-in-motion for the harrier
Discussion harrier jump jet (vtol) 63 nova Foamies (Scratchbuilt) 49 Jul 15, 2012 11:53 PM
Harrier Jump Jet Plans? P6Mole Fuel Jet Talk 9 May 05, 2011 05:47 PM
Harrier Jump Jet Plans?? P6Mole Electric Ducted Fan Jet Talk 4 Feb 08, 2005 10:08 AM
Harrier Jump Jet Lewist Electric Ducted Fan Jet Talk 94 Dec 07, 2004 10:03 PM
Av8 B Harrier Jump Jet balsaduster Electric Ducted Fan Jet Talk 45 Dec 29, 2002 04:40 PM
