Old Jul 05, 2012, 01:49 PM
sparks59 is offline
Find More Posts by sparks59
Sic itur ad Astra
sparks59's Avatar
United Arab Emirates, Abu Dhabi, Abu Dhabi
Joined Aug 2009
Build Log
Britkit Build off 2012 -Veron Coupe'
So finally I have succumbed to the pressures and got around to making a start on the Coupe.
I fancied the idea, just for a change, of building something the size it was meant to be, rather than upsizing to ease the installation of electric power and RC equipment.
Of course, this may be tough with a 20" span lightweight rubber jobby, so, to keep the wing load in check, I may stretch the wing a tad and add an extra rib and I plan to increase the chord by a similar proportion. It would probably be easier to upsize the whole thing by 20%, but I would like to keep the original size where possible.
The current plan is to pop a little 1811 'dentist drill' motor in, with a 6A esc. A 2s lipo of 180 - 350mAh, or as big as I can depending on finished mass.
I would like to do it 2channel, rudder and motor...but this plan is a moveable feast, well more of a small snacklette really.
Anyway, plan printed andthe sticks for the first side are laid down and the PVA is drying off now while I post this and lubricate the tonsils with a glass of Tetley's finest. No George, not the Tea!
sparks
sparks59 is offline Find More Posts by sparks59
Old Jul 05, 2012, 02:33 PM
sparks59 is offline
Sic itur ad Astra
sparks59's Avatar
Joined Aug 2009
I must be tired. Title of the thread..Frog build off. What have I been drinking?
Sorted now, normal service will be resumed presently...
sparks
Old Jul 05, 2012, 02:56 PM
Sundancer is offline
Find More Posts by Sundancer
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
That's a chubby little number Sparks, glad to see it and will be following with interest. Link to your thread posted in the Build Off thread.
We don't drink Tetleys tea Sparks - strictly Taylors of Harrogate Yorkshire tea imported via our bi-monthly Tesco order! You can buy it here but would need a mortgage for a small box - and French tea bags produce a brew so weak it needs support!
Sundancer is offline Find More Posts by Sundancer
Old Jul 05, 2012, 03:05 PM
sparks59 is offline
Sic itur ad Astra
sparks59's Avatar
Joined Aug 2009
Totally agree on the Chai front. I can get by on Tetley Tea here, but anytime i'm home, or if visitors are coming here, I always ask if they'll bring a big box of Yorkshire Tea! The Liptons really doesn't produce the right sort of brew, I imagine it is similar to the French stuff.
Anyway, news on the build.
I fed some numbers into Flieslikeabeagle's webocalc just to get some targets, ideas for power and weight. Argghhhh. For this to fly in the sedate manner that I'd like, its going to have to be 3.5oz or so. ....That might be a tall order as I was sort of expecting it to be 5 or 6.
Although a smaller lipo and one less servo will help.
sparks
Old Jul 05, 2012, 03:19 PM
Sundancer's Avatar
South-west France
Joined Sep 2007
Yep, there ain't no substitute for a bit of wing area. I was looking at building a Tom Thumb for R/E/T, but I think it will only be really practical if I get some really ultralight kit. Even the stuff I have used in the Witch and Sportster (10 gram motor, 6A ESC, 300 2S lipo, two 3.6 gram servos and a teeny weeny Orange 2.4 Rx) would take it over the weight I would want. Another model in the same size range I would like to build, the Smeed Flipper bipe, would be a bit better due to the extra wing area (had one back in the day with a magnetic actuator, rudder only, and a TD010, it is cute enough to give you a nosebleed).
One thought; using a 5 x 3 GWS prop on the 1811, I get vast lengths of run from my 300m lipo and it is only pulling less than 3 amps, so if you can find, say, a 120 or 150 2S with a 25C rating it would be OK and save a lot of weight.
Old Jul 05, 2012, 03:29 PM
Harry D is offline
Find More Posts by Harry D
TLAR Aviation
Harry D's Avatar
Canada, AB, Edmonton
Hey, Sparks, watching with interest. I'll be going "mini" for this build-off too, with a KeilKraft Dandy. I will also be keeping to the original size, which is 21" span. Seems to me these little things are pretty trivial builds as such, and the real challenge is building down to weight rather than "cheating" in some way. The "maximum all-up weight for good performance" of the Dandy is said to be 2 oz.
So while waiting for the plans to arrive, I've been researching lightweight equipment. So far, I've found: receiver 2g, 2 servos at 1.7g each, motor 4g, ESC 4g. Lipo will be 2s240, 12g, pack made up by me to save a bit of weight (may go smaller on the lipo if I have to). So total power train plus RC gear should be around 24g or about 0.9 oz.
Can I bring the rest of it in under an ounce or so? We will see.
Hope to get some tips from your build.
Harry D is offline Find More Posts by Harry D
Old Jul 05, 2012, 04:44 PM
sparks59 is offline
Sic itur ad Astra
sparks59's Avatar
Joined Aug 2009
Welcome Harry,
An ounce is going to get you thinking light!
For sure I'm going to have to think light on this, but it still needs to be able to support the gear and not fold up on the first landing. The heavy thing at the moment is the battery, i'll only need around 2.5 amps with a 5x3 prop (as George mentioned, it should give enough for these tiddlers) if I can get it to 3.5oz AUW, and then a 200 2s lipo will be fine. Think my 5g servo is going to be too much I'm sort of stuck with the rx at the moment but there'll be something available i'm sure.
watch this space..
sparks
Old Jul 06, 2012, 12:05 PM
sparks59 is offline
Sic itur ad Astra
sparks59's Avatar
Joined Aug 2009
Had a good day at the board today. Made some progress. Both wings and most of the fuselage are well advanced.
sparks
Old Jul 06, 2012, 04:11 PM
Sundancer's Avatar
South-west France
Joined Sep 2007
Gosh, Billy Whizz rides again!!
Old Jul 07, 2012, 06:25 AM
sparks59 is offline
Sic itur ad Astra
sparks59's Avatar
Joined Aug 2009
I was fairly surprised myself how much can be done on a small model when you get a full day at it.
sparks
Old Jul 08, 2012, 08:32 AM
rabidrue1 is online now
Find More Posts by rabidrue1
Blueplaidcanard flyer
sdy. ny
Joined May 2007
Its going to be a cute little bugger.
rabidrue1 is online now Find More Posts by rabidrue1
Old Jul 08, 2012, 09:45 AM
sparks59 is offline
Sic itur ad Astra
sparks59's Avatar
Joined Aug 2009
Yes! Thanks Rab, I thought so too.
I have increased the span by adding another rib and made the trailing edge a tad thicker to increase the chord.
To maintain the balance, I have inreased the horizontal stabiliser span and chord a little also. I'm hoping my fiddling will not upset any purist modellers out there, or more importantly for me, detract from the overall cute look of the Coupe.
sparks
Old Jul 08, 2012, 10:28 AM
brokenspar is offline
Find More Posts by brokenspar
The dog ate my clearance
brokenspar's Avatar
Joined Jan 2004
Looking good. We'll be watching!
brokenspar is offline Find More Posts by brokenspar
Old Jul 08, 2012, 10:45 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
I know I've seen that fuselage profile somewhere before Sparks, and after some brain bashing I THINK it was on a magazine published design by Keith Laumer, the Cyrano. I have it somewhere but my filing system is chaotic, so I had a look for other Laumer designs and sure enough there is a biplane called Lula-Bi which is very similar in profile to the Coupe. Coincidence or was Phil inspired by Keith - or vice-versa?
Old Jul 08, 2012, 10:54 AM
RFJ is online now
RFJ
Find More Posts by RFJ
RFJ
RFJ's Avatar
Northern Ireland
Joined Dec 2004
Mine must be less so - but only slightly
Cyrano from Aeromodeller July 1960.
Ray
RFJ is online now Find More Posts by RFJ
Build Log Frog Build Off Oct 2011-April 2012 - MAMBA Sundancer Vintage & Old-Timer Designs 104 Nov 26, 2012 07:57 AM
Build Log Britkit Build Off April 2012 - Veron Deacon cd_webb Vintage & Old-Timer Designs 66 Sep 22, 2012 06:54 AM
Discussion POLL for FROG Build Off Oct 2011 - April 2012 Sundancer Vintage & Old-Timer Designs 22 May 18, 2012 11:51 AM
Discussion Frog Build Off Oct 2011-April 2012 - Vanda Mk. 2 vega Vintage & Old-Timer Designs 13 Apr 29, 2012 09:15 AM
Build Log FROG build-off Oct 2011 - April 2012; ZEPHYR Sundancer Vintage & Old-Timer Designs 75 Mar 09, 2012 12:49 PM
